| What projects do I need to build a base platform eclipse [message #274870] |
Fri, 29 October 2004 13:33  |
Originally posted by: gj.puredge.com
I want to start looking seriously at the Eclipse Source code and the best
place to do this, of cource, is in Eclipse.
I was hoping to import an entire platform (no SDK) into an eclipse
workspace. Is there a list of projects I have to check out of CVS for this?
I've got my cvs repository set up for the dev.eclipse.org:/home/eclipse so
all I need to know is which project(s) to checkout/import.]
Does anyone have an information on this, or is there a doc somewhere that
explains this? I've looked through a lot of stuff at dev.eclipse.org but
can't seen to find what I need to build Eclipse
Any help would be appreciated
| Re: What projects do I need to build a base platform eclipse [message #274881 is a reply to message #274875] |
Fri, 29 October 2004 14:19   |
Thanks for the info.
I followed the instructions and checked out the two projects:
org.eclipse.debug.core
org.eclipse.debug.ui
as described in the instructions into a new empty workspace.
debug.core builds cleanly but unfortunately debug.ui does not. I've got 85
errors in the problems view.
I am running:
Version: 3.0.1
Build id: 200409161125
I have listed a few of the errors below. Is there something else that I
need to do to get this to work?
Severity Description Resource In Folder Location Creation Time
2 The import org.eclipse.ui.console.IPatternMatchListener cannot be resolved
ConsoleLineNotifier.java
org.eclipse.debug.ui/ui/org/eclipse/debug/internal/ui/views/ console line 26
October 29, 2004 11:11:32 AM
2 The import org.eclipse.ui.console.PatternMatchEvent cannot be resolved
org.eclipse.debug.ui/ui/org/eclipse/debug/internal/ui/views/ console line 27
2 IPatternMatchListener cannot be resolved or is not a valid superinterface
org.eclipse.debug.ui/ui/org/eclipse/debug/internal/ui/views/ console line 33
2 The method addPropertyChangeListener(ConsoleLineNotifier) is undefined for
the type ProcessConsole ConsoleLineNotifier.java
org.eclipse.debug.ui/ui/org/eclipse/debug/internal/ui/views/ console line 57
2 The method removePropertyChangeListener(ConsoleLineNotifier) is undefined
for the type ProcessConsole ConsoleLineNotifier.java
org.eclipse.debug.ui/ui/org/eclipse/debug/internal/ui/views/ console line 75
2 PatternMatchEvent cannot be resolved (or is not a valid type) for the
parameter event of the method matchFound ConsoleLineNotifier.java
org.eclipse.debug.ui/ui/org/eclipse/debug/internal/ui/views/ console line 121
2 IConsoleConstants.P_CONSOLE_OUTPUT_COMPLETE cannot be resolved
org.eclipse.debug.ui/ui/org/eclipse/debug/internal/ui/views/ console line 153
2 The import org.eclipse.ui.console.IOConsole cannot be resolved
JavaConsoleTrackerPropertyTester.java
"Darin Swanson" <Darin_Swanson@us.ibm.com> wrote in message
news:cltvt7$hfc$1@eclipse.org...
Here are the instructions provided for the platform debug components.
It will give you an example of setting up a workspace to work on the latest
debug code.
I believe the Navigator code is in the org.eclipse.ui.ide plugin.
HTH
Darins
"Gary J" <gj@puredge.com> wrote in message news:cltveg$gig$1@eclipse.org...
> Now that I think about it, I probably only need to debug one Eclipse
feature
> at a time so I only need to have a few plugins loaded in an eclipse
project.
> In my case I want to debug / step though the Navigator plugin(s). Which
> project(s) contains this code?
> Thanks
news:cltusn$fju$1@eclipse.org...
this?
| Re: What projects do I need to build a base platform eclipse [message #274883 is a reply to message #274881] |
Fri, 29 October 2004 14:54   |
This is a result that debug ui is relying on recent changes in the
org.eclipse.ui.console plugin.
When API is changing (as it is in the org.eclipse.ui.console plugin) the
latest of one plugin will require the latest of the other plugin.
Check out org.eclipse.ui.console
HTH
Darins
"Gary J" <gj@puredge.com> wrote in message news:clu1k1$ki5$1@eclipse.org...
85
> I am running:
> Version: 3.0.1
> Thanks
resolved
26
27
superinterface
33
for
57
undefined
75
121
153
latest
> debug code.
> HTH
> Darins
> feature
> project.
> > Thanks
best
> this?
so
that
but
| Re: What projects do I need to build a base platform eclipse [message #274888 is a reply to message #274870] |
Fri, 29 October 2004 15:21  |
For anyone else who is interested in looking / debugging Eclipse Code I
think I have it more or less figured out.
This only works for the version of Eclipse that you are actually running and
not for the most recent drops of Eclipse
1. Created a new CVS repository
User: anonymous
Password: <none>
Host: dev.eclipse.org
path: /home/eclipse
2. Find out which version of the Plugin you have installed in Eclipse
- Help->About Eclipse Platform->Plugin Details
- Find the plugin you are interested in looking at. Usually it is the same
as your Eclipse but not always
3. Check out the Plugin project from CVS
- Open the "Versions" node of the dev.eclipse.org cvs repository created
earlier
- Find the plugin project
- Look for the same version of the plugin (major releases are near the
bottom)
4. Build Project
- If you checked out the correct version it should build cleanly
- If there are errors in the Problems Viewyou probably checked out
the wrong version of the plugin.
5. Run the plugin.
Open the Run Configuration Manager and create a new configuration under
"Run-time Workbench"
- Under the Plug-ins tab select "Choose plug-ins and fragments..."
- Select the new plugin at the top.
- Check to see that the same plugin is unchecked under "External Plug-ins"
(its probably already unchecked).
- Uncheck any other plugins you don't need so as not to confuse the issue
Click "Run" and it should run.
6. Set beakpoints and Debug the plugin.
I'm sure there are better ways to do this but this worked great for me.
FUDForum. Page generated in 0.04745 seconds
