| Super slow [message #27270] |
Sun, 02 November 2003 20:52  |
Originally posted by: wayne.williams.embarcadero.com
I am running Eclipse 3.0 on a decent box and performace is good. However
with the ajdt plugin it virtually grinds to a halt. With just a single
aspect file an aspectJ build will take at least 5 minutes.
My project is average size, about 1800 class files.
What performance expectations should I have? Is there anything I can do to
improve performance.
One thing I thought was I could reduce the scope of the aspectJ compile by
selecting about 10 classes in the default.lst file. Unfortunatly this
seemed to have no impact.
---Wayne.
| Re: Super slow [message #27859 is a reply to message #27306] |
Tue, 11 November 2003 03:34  |
Hi Andy,
Thanks for the reply. I had tried both your suggestions, I should have =
included that in my original description. Unfortunatly they did not help=
I only resorted to modifying the default.lst when I could not get any =
performance benefit from a new .lst file. I have run eclipse with as muc=
h =
as half a gig and it made virtually no difference performance wise. When=
I =
ran with smaller heaps I did get OutOfMemory erros quite a bit.
It seems to be some strange interaction between AJDT and eclipse because=
I =
am able to build using the AspectJ browser in less than a minute but =
within eclipse it takes at least 7 times as long. I see great potential=
with aspects but the AJDT piece is really important IMHO to get the kind=
of development productivity we need for our project.
---Wayne.
On Fri, 7 Nov 2003 17:41:40 +0000 (UTC), Andy Clement <clemas@uk.ibm.com=
wrote:
> Hi Wayne,
> 1800 classes is a reasonable size project. I can think of a couple of=
> things that might help:
> - Make sure that eclipse has enough memory to run. With the default, =
you
> might not be getting OutOfMemory problems, but it could be Garbage
> Collecting
> itself to death. Try 'eclipse -vmargs -Xmx256M' to start it with more=
> memory.
> - Don't edit the default.lst. Its a special .lst file that is generat=
ed
> every time you click 'build' - it is always generated to contain all t=
he
> resources in your project. If you want to work with a subset of the
> files, you should create a new .lst file using the new BuildConfigurat=
ion
> wizard. We ought to hide the default.lst file so users don't try and
> change it ...
> does that help at all?
> cheers,
> Andy
> AJDT Development.
Using M2, Opera's revolutionary e-mail client: http://www.opera.com/m2/
| Re: Super slow [message #572651 is a reply to message #27270] |
Fri, 07 November 2003 12:41  |
Hi Wayne,
- Make sure that eclipse has enough memory to run. With the default, you
Collecting
memory.
- Don't edit the default.lst. Its a special .lst file that is generated
every time you click 'build' - it is always generated to contain all the
files, you should create a new .lst file using the new BuildConfiguration
change it ...
cheers,
Andy
AJDT Development.
| Re: Super slow [message #572867 is a reply to message #27306] |
Hi Andy,
h =
I =
I =
---Wayne.
wrote:
> Hi Wayne,
you
> Collecting
> memory.
ed
he
ion
> change it ...
> cheers,
> Andy
> AJDT Development.
FUDForum. Page generated in 0.04604 seconds
