Home » Eclipse Projects » Eclipse Platform » CVS Repository View no longer works
| CVS Repository View no longer works [message #274339] |
Wed, 20 October 2004 10:48  |
Originally posted by: rkennedy.appriss.com
I haven't had any problems with this view before, but for some reason no=
w, =
I can't view the CVS repository in Eclipse. I have to open up WinCVS to=
do any work with my projects. I have been able to view/label/etc. from =
within Eclipse, but not anymore. If I refresh the view on HEAD, Eclipse=
starts working on something, but it doesn't return with a tree of childr=
en.
Bad thing is, I don't know of anything that I did to stop this feature =
from working. Has anyone else experienced this problem? If so, what's=
the solution to get this working again?
Any help is appreciated....thanks.
Randy Kennedy
Software Engineer
Appriss Inc.
| Re: CVS Repository View no longer works [message #274427 is a reply to message #274416] |
Thu, 21 October 2004 09:28   |
You may also want to check the log file o see if errors are occurring.
If there is still no indication of what has gone wrong, you can follow
the steps at this URL to get a client/server communication trace which
may reveal what is wrong.
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-vcm-home/docs/online/cvs_features2.0/cvs-faq.html#misc_ 0
Michael
Robert Klemme wrote:
>>"Randy Kennedy" <rkennedy@appriss.com> schrieb im Newsbeitrag
> news:opsf6bfeo5kmnvmn@rkennedy_tyan.appriss.com...
> now,
> children.
> Things that could have gone wrong:
> - you changed your personal firewall's config to deny access for javaw
> - you changed your repository config
> - CVS changed on the CVS server (version, config)
> Did you open the CVS console? Could you see anything interesting there?
> Kind regards
> robert
| Re: CVS Repository View no longer works [message #274819 is a reply to message #274427] |
Thu, 28 October 2004 18:57   |
Thanks for the extra information concerning the debug feature. Didn't =
realize that was capable; however, even after enabling that feature, =
there's nothing on the screen or in the .log file that indicate problems=
I didn't see any Java exceptions or anything that would cause my editor =
to =
just stop working for the CVS view... ;-(
On Thu, 21 Oct 2004 09:28:06 -0400, Michael Valenta =
<Michael_Valenta@ca.ibm.com> wrote:
> You may also want to check the log file o see if errors are occurring.=
> If there is still no indication of what has gone wrong, you can follow=
> the steps at this URL to get a client/server communication trace which=
> http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-vcm-h=
ome/docs/online/cvs_features2.0/cvs-faq.html#misc_0
> Michael
>>> I haven't had any problems with this view before, but for some reaso=
n
>> now,
>>> I can't view the CVS repository in Eclipse. I have to open up WinCV=
S =
>>> to
>>> do any work with my projects. I have been able to view/label/etc. f=
rom
>>> within Eclipse, but not anymore. If I refresh the view on HEAD, =
>>> Eclipse
>> children.
>>> Bad thing is, I don't know of anything that I did to stop this featu=
re
>>> from working. Has anyone else experienced this problem? If so, wha=
t's
>> - you changed your personal firewall's config to deny access for ja=
vaw
>> Did you open the CVS console? Could you see anything interesting =
>> there?
>> Kind regards
>> robert
Randy Kennedy
Software Engineer
Appriss Inc.
| Re: CVS Repository View no longer works [message #274836 is a reply to message #274819] |
Fri, 29 October 2004 09:09   |
The trace output should go to stdout. You should at least see some trace
information on stdout. If your not seeing anything, perhaps you launched
Eclipse without the required parameters (i.e. use java.exe and not
javaw.exe and include the -debug and -consolelog options).
Michael
> problems. I didn't see any Java exceptions or anything that would
> cause my editor to just stop working for the CVS view... ;-(
>> occurring. If there is still no indication of what has gone wrong,
>> you can follow the steps at this URL to get a client/server
>> communication trace which may reveal what is wrong.
>> Michael
>>> now,
>>>> WinCVS to
>>>> Eclipse
>>> children.
>>> there?
>>> Kind regards
>>> robert
| Re: CVS Repository View no longer works [message #274876 is a reply to message #274836] |
Fri, 29 October 2004 13:57   |
Sorry for the confusion. Yes, I did see information going to the stdout=
but after reviewing it, all messages indicated that it was able to =
converse with CVS, but the tree in Eclipse never expanded. It was actin=
g =
like it was going to do something, but it never did. The plus indicator=
disappeared, and there was no tree information present.
I was hoping to see a Java exception or something in the stdout log, but=
nothing of the sort. I'm kind of at a loss.
On Fri, 29 Oct 2004 09:09:52 -0400, Michael Valenta =
> The trace output should go to stdout. You should at least see some tra=
ce =
> information on stdout. If your not seeing anything, perhaps you launch=
ed =
> Eclipse without the required parameters (i.e. use java.exe and not =
> Michael
>> Thanks for the extra information concerning the debug feature. =
>> Didn't realize that was capable; however, even after enabling that =
>> feature, there's nothing on the screen or in the .log file that =
>> indicate problems. I didn't see any Java exceptions or anything tha=
t =
>> would cause my editor to just stop working for the CVS view... ;-(
>>> You may also want to check the log file o see if errors are =
>>> occurring. If there is still no indication of what has gone wrong, =
>>> you can follow the steps at this URL to get a client/server =
>>> http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-vcm=
-home/docs/online/cvs_features2.0/cvs-faq.html#misc_0 =
>>> Michael
>>>>> I haven't had any problems with this view before, but for some rea=
son
>>>> now,
>>>>> I can't view the CVS repository in Eclipse. I have to open up =
>>>>> WinCVS to
>>>>> do any work with my projects. I have been able to view/label/etc.=
>>>>> from
>>>>> Eclipse
>>>> children.
>>>>> Bad thing is, I don't know of anything that I did to stop this =
>>>>> feature
>>>>> from working. Has anyone else experienced this problem? If so, =
>>>>> what's
>>>> - you changed your personal firewall's config to deny access for =
>>>> javaw
>>>> there?
>>>> Kind regards
>>>> robert
Randy Kennedy
Software Engineer
Appriss Inc.
| Re: CVS Repository View no longer works [message #274928 is a reply to message #274876] |
Mon, 01 November 2004 09:03   |
The problem is that Eclipse parses text messages from the server to
determine what to show in the repositories view. If it gets a message it
doesn't understand, it is silently ignored. It is possible that the
server is communicating directories in a format that is unknwon to
Eclipse. What version of the CVS server are you using? If you post what
was received, I can match it up with what was expected to see if there
was a difference.
Michael
> stdout, but after reviewing it, all messages indicated that it was able
> to converse with CVS, but the tree in Eclipse never expanded. It was
> acting like it was going to do something, but it never did. The plus
> indicator disappeared, and there was no tree information present.
> but nothing of the sort. I'm kind of at a loss.
>> trace information on stdout. If your not seeing anything, perhaps you
>> launched Eclipse without the required parameters (i.e. use java.exe
>> and not javaw.exe and include the -debug and -consolelog options).
>> Michael
>>> that would cause my editor to just stop working for the CVS
>>> view... ;-(
>>>> Michael
>>>>> now,
>>>>>> WinCVS to
>>>>>> Eclipse
>>>>> children.
>>>>>> feature
>>>>>> what's
>>>>> javaw
>>>>> interesting there?
>>>>> Kind regards
>>>>> robert
| Re: CVS Repository View no longer works [message #275654 is a reply to message #274928] |
Wed, 10 November 2004 11:47   |
Sorry for taking so long to reply back. I'm currently using CVS version=
1.11.1p1. When I click on HEAD to refresh the view, the Process view =
shows that it's attempting to retrieve the HEAD children, but the childr=
en =
are never displayed in the CVS view. Here's the stdout information that=
I =
receive:
Valid-responses ok error M E Checked-in Valid-requests Template Set-stic=
ky =
Clear
-static-directory Module-expansion Set-static-directory Clear-sticky =
New-entry M
erged Removed Updated Remove-entry Update-existing Copy-file Created =
Notified Mo
d-time
valid-requests
Valid-requests Root Valid-responses valid-requests Repository Directory =
Max-dotd
ot Static-directory Sticky Checkin-prog Update-prog Entry Kopt =
Checkin-time Modi
fied Is-modified UseUnchanged Unchanged Notify Questionable Case Argumen=
t =
Argume
ntx Global_option Gzip-stream wrapper-sendme-rcsOptions Set expand-modul=
es =
ci co
update diff log rlog add remove update-patches gzip-file-contents stat=
us =
rdiff
tag rtag import admin export history release watch-on watch-off watch-ad=
d =
watch-
remove watchers editors init annotate rannotate noop version
ok
Root /srv/rcs/cvs/se
CMD> cvs -n update -d ""
Global_option -n
Argument -d
Directory .
/srv/rcs/cvs/se/
Argument .
Directory .
/srv/rcs/cvs/se/
update
E cvs server: Updating .
E cvs server: New directory `CVSROOT' -- ignored
E cvs server: New directory `anotherTest' -- ignored
E cvs server: New directory `branchtest' -- ignored
E cvs server: New directory `daemons' -- ignored
E cvs server: New directory `demos' -- ignored
E cvs server: New directory `libs' -- ignored
E cvs server: New directory `managers' -- ignored
E cvs server: New directory `products' -- ignored
E cvs server: New directory `projects' -- ignored
E cvs server: New directory `prototypes' -- ignored
E cvs server: New directory `scripts' -- ignored
E cvs server: New directory `stdvinebat.' -- ignored
E cvs server: New directory `tools' -- ignored
ok
RESULT> Status OK: org.eclipse.team.cvs.core code=3D0 ok null
On Mon, 01 Nov 2004 09:03:56 -0500, Michael Valenta =
> The problem is that Eclipse parses text messages from the server to =
> determine what to show in the repositories view. If it gets a message =
it =
> doesn't understand, it is silently ignored. It is possible that the =
> server is communicating directories in a format that is unknwon to =
> Eclipse. What version of the CVS server are you using? If you post wha=
t =
> was received, I can match it up with what was expected to see if there=
> was a difference.
> Michael
>> Sorry for the confusion. Yes, I did see information going to the =
>> stdout, but after reviewing it, all messages indicated that it was =
>> able to converse with CVS, but the tree in Eclipse never expanded. =
It =
>> was acting like it was going to do something, but it never did. The=
>> plus indicator disappeared, and there was no tree information presen=
t.
>> I was hoping to see a Java exception or something in the stdout log,=
>>> The trace output should go to stdout. You should at least see some =
>>> trace information on stdout. If your not seeing anything, perhaps y=
ou =
>>> launched Eclipse without the required parameters (i.e. use java.exe=
>>> Michael
>>>> Didn't realize that was capable; however, even after enabling that=
>>>> indicate problems. I didn't see any Java exceptions or anything =
>>>> that would cause my editor to just stop working for the CVS =
>>>> view... ;-(
>>>>> occurring. If there is still no indication of what has gone wrong=
>>>>> http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-v=
cm-home/docs/online/cvs_features2.0/cvs-faq.html#misc_0 =
>>>>> Michael
>>>>>>> I haven't had any problems with this view before, but for some =
>>>>>>> reason
>>>>>> now,
>>>>>>> WinCVS to
>>>>>>> do any work with my projects. I have been able to =
>>>>>>> within Eclipse, but not anymore. If I refresh the view on HEAD,=
>>>>>>> Eclipse
>>>>>>> starts working on something, but it doesn't return with a tree o=
f
>>>>>> children.
>>>>>>> feature
>>>>>>> from working. Has anyone else experienced this problem? If so,=
>>>>>>> what's
>>>>>> - you changed your personal firewall's config to deny access fo=
r =
>>>>>> javaw
>>>>>> Did you open the CVS console? Could you see anything =
>>>>>> interesting there?
>>>>>> Kind regards
>>>>>> robert
Randy Kennedy
Software Engineer
Appriss Inc.
| Re: CVS Repository View no longer works [message #275703 is a reply to message #275654] |
Thu, 11 November 2004 09:24  |
The output looks fine. Is there anything in the error log (accessible
from the Error Log view or in the .metadata/.log file within your
workspace). Either there is some other error that is preventing the
modules from showing up or there is a parsing error. If it was the
later, I would think that more people would have seen it.
You can either continue posting here or log a bug report against
Platform CVS if you would prefer to track it there.
Michael
> version 1.11.1p1. When I click on HEAD to refresh the view, the
> Process view shows that it's attempting to retrieve the HEAD children,
> but the children are never displayed in the CVS view. Here's the
> stdout information that I receive:
> Set-sticky Clear
> New-entry M
> Notified Mo
> d-time
> valid-requests
> Max-dotd
> Checkin-time Modi
> Argument Argume
> expand-modules ci co
> status rdiff
> watch-add watch-
> ok
> Global_option -n
> Argument -d
> Directory .
> /srv/rcs/cvs/se/
> Argument .
> Directory .
> /srv/rcs/cvs/se/
> update
> ok
> RESULT> Status OK: org.eclipse.team.cvs.core code=0 ok null
>> it doesn't understand, it is silently ignored. It is possible that
>> the server is communicating directories in a format that is unknwon
>> to Eclipse. What version of the CVS server are you using? If you post
>> what was received, I can match it up with what was expected to see if
>> there was a difference.
>> Michael
>>> It was acting like it was going to do something, but it never did.
>>> The plus indicator disappeared, and there was no tree information
>>> present.
>>> log, but nothing of the sort. I'm kind of at a loss.
>>>> you launched Eclipse without the required parameters (i.e. use
>>>> java.exe and not javaw.exe and include the -debug and -consolelog
>>>> options).
>>>> Michael
>>>>> that feature, there's nothing on the screen or in the .log file
>>>>> that indicate problems. I didn't see any Java exceptions or
>>>>> anything that would cause my editor to just stop working for the
>>>>> CVS view... ;-(
>>>>>> wrong, you can follow the steps at this URL to get a
>>>>>> client/server communication trace which may reveal what is wrong.
>>>>>> Michael
>>>>>>>> reason
>>>>>>> now,
>>>>>>>> WinCVS to
>>>>>>>> HEAD, Eclipse
>>>>>>> children.
>>>>>>>> feature
>>>>>>>> so, what's
>>>>>>> for javaw
>>>>>>> interesting there?
>>>>>>> Kind regards
>>>>>>> robert
Current Time: Sat Oct 25 10:40:14 EDT 2025
Powered by FUDForum. Page generated in 1.06462 seconds
