Home » Archived » XML Schema Definition (XSD) » Specific failure in XSDEcoreBuilder
Specific failure in XSDEcoreBuilder [message #27198] |
Wed, 03 September 2003 04:53  |
Weve been using XSDEcoreBuilder on a trivial schema and now are turning
to some more realistic schemas. However, it choked on a particular
construct, which I have now isolated. The schema
<?xml version = "1.0" encoding = "UTF-8"?>
<xsd:schema xmlns:xsd = "http://www.w3.org/2001/XMLSchema">
<xsd:complexType name = "ServiceCategory">
<xsd:simpleContent>
<xsd:extension base = "xsd:boolean"/>
</xsd:simpleContent>
</xsd:complexType>
<xsd:element name = "DialARide">
<xsd:complexType>
<xsd:complexContent>
<xsd:extension base = "ServiceCategory"/>
</xsd:complexContent>
</xsd:complexType>
</xsd:element>
</xsd:schema>
produces a null pointer exception during XSDEcoreBuilder.generate(), when
it gets to XSDConstants.isAnyType() which is called with a null argument
which is then used as if it is a valid object.
It doesnt seem to matter what is inside the simple content of the base
type (ServiceCategory) we always get the same failure. If however the same
kind of simple extension construct is used directly within an element
rather than as a reference to a separate type, it works OK.
However, I dont have control of the schemas so I have no workaround.
stack trace:
at org.eclipse.xsd.util.XSDConstants.isAnyType(XSDConstants.jav a:1532)
org.eclipse.xsd.ecore.XSDEcoreBuilder.getEClassifier(XSDEcor eBuilder.java:324)
org.eclipse.xsd.ecore.XSDEcoreBuilder.getEClassifier(XSDEcor eBuilder.java:360)
org.eclipse.xsd.ecore.XSDEcoreBuilder.getEClassifier(XSDEcor eBuilder.java:727)
org.eclipse.xsd.ecore.XSDEcoreBuilder.generate(XSDEcoreBuild er.java:902)
Hope someone can help.
Ian Cornwell
Re: Specific failure in XSDEcoreBuilder [message #27273 is a reply to message #27236] |
Wed, 03 September 2003 07:42   |
Sorry Ed,
I got this schema from the UK government so in this case I had taken it on
trust that it was valid!
Thanks for your help.
Ian
Ed Merks wrote:
> Ian,
> Opening this schema in the Sample XML Schema Editor produces this diagnostic:
> XSD: The content type must be the same simple type
> 'http://www.w3.org/2001/XMLSchema#boolean' as that of the base
> Since ServiceCategotry has simple content type, any type derived from it
must also
> have simple content type. It's best to validate your schemas before
attempting to
> derive an Ecore model from it. Not that this is a good excuse for null point
> exceptions.
> By the way, we are doing very extensive rework of the XSD to Ecore so
support a
> much broader range of valid XML schemas. We will make this work available
in the
> 2.0 stream in the coming weeks.
> > <xsd:simpleContent>
> > </xsd:complexType>
> > <xsd:complexType>
> > </xsd:complexType>
> > </xsd:element>
> > </xsd:schema>
> > stack trace:
> > java.lang.NullPointerException
> > at
> > at
> > at
> > at
> > at
> > Ian Cornwell
Re: Specific failure in XSDEcoreBuilder [message #27309 is a reply to message #27236] |
Wed, 03 September 2003 07:50   |
Ed,
On my first reading of your reply I thought you were saying the schema was
invalid, but now I'm not so sure. Are you saying that the restriction
reported by by the sample XML schema editor is an "XML Schema" rule or are
you saying that it is an extra limitation imposed by the current version
of the XSD plugin? (The schema does validate with XSV).
Ian
Ed Merks wrote:
> Ian,
must also
attempting to
> exceptions.
support a
in the
> > <xsd:simpleContent>
> > </xsd:complexType>
> > <xsd:complexType>
> > </xsd:complexType>
> > </xsd:element>
> > </xsd:schema>
> > stack trace:
> > at
> > at
> > at
> > at
> > at
> > Ian Cornwell
Re: Specific failure in XSDEcoreBuilder [message #27337 is a reply to message #27273] |
Wed, 03 September 2003 07:57   |
Ed,
On first reading of your reply I thought you were saying the schema was
invalid, but now I'm not so sure. The rule below - are you saying this is
an "XML Schema" rule or an extra limitation imposed by the current version
of XSD? (The schema does validate with XSV).
Ian
> Ed Merks wrote:
> > Ian,
diagnostic:
> must also
> attempting to
point
> > exceptions.
> support a
> in the
> > > <xsd:simpleContent>
> > > </xsd:complexType>
> > > <xsd:complexType>
> > > </xsd:complexType>
> > > </xsd:element>
> > > </xsd:schema>
argument
same
> > > stack trace:
> > > at
> > > at
> > > at
> > > at
> > > at
> > > Ian Cornwell
Re: Specific failure in XSDEcoreBuilder [message #27359 is a reply to message #27236] |
Wed, 03 September 2003 08:56   |
[my apology if this appears multiple times, perhaps I am being impatient
with the newsgroup software but I cannot see this post on the server (web
version)]
Ed,
Ian
Ed Merks wrote:
> Ian,
must also
attempting to
> exceptions.
support a
in the
> > <xsd:simpleContent>
> > </xsd:complexType>
> > <xsd:complexType>
> > </xsd:complexType>
> > </xsd:element>
> > </xsd:schema>
> > stack trace:
> > at
> > at
> > at
> > at
> > at
> > Ian Cornwell
Re: Specific failure in XSDEcoreBuilder [message #27900 is a reply to message #27337] |
Wed, 03 September 2003 12:30  |
--------------8A41682EC3F4B0CF212D3B9E
Content-Type: text/plain; charset=iso-8859-1
Ian,
I think you are right. This addition to XSDComplexTypeDefinitionImpl makes sure
the content type is set in the case of empty explicit content:
> etools-diff XSDComplexTypeDefinitionImpl.java
1201a1202
> newContentType =
complexBaseTypeDefinition.getContentType();
When the content type is set, rather than being null, the message goes away and the
null pointer exception doesn't happen. I'll include this fix in the 1.1.1 stream.
Thanks for bringing this to my attention!
Ian Cornwell wrote:
> Ed,
> Ian
> > Ed Merks wrote:
> > > Ian,
> diagnostic:
> > must also
> > attempting to
> point
> > > exceptions.
> > support a
> > in the
> > > > We
Re: Specific failure in XSDEcoreBuilder [message #576776 is a reply to message #27198] |
Wed, 03 September 2003 07:29  |
--------------73C15270C1811EC1516DA013
Ian,
Since ServiceCategotry has simple content type, any type derived from it must also
have simple content type. It's best to validate your schemas before attempting to
exceptions.
By the way, we are doing very extensive rework of the XSD to Ecore so support a
much broader range of valid XML schemas. We will make this work available in the
> We
Re: Specific failure in XSDEcoreBuilder [message #576820 is a reply to message #27236] |
Sorry Ed,
Ian
Ed Merks wrote:
> Ian,
must also
attempting to
> exceptions.
support a
in the
> > <xsd:simpleContent>
> > </xsd:complexType>
> > <xsd:complexType>
> > </xsd:complexType>
> > </xsd:element>
> > </xsd:schema>
> > stack trace:
> > at
> > at
> > at
> > at
> > at
> > Ian Cornwell
Re: Specific failure in XSDEcoreBuilder [message #576861 is a reply to message #27236] |
Ed,
Ian
Ed Merks wrote:
> Ian,
must also
attempting to
> exceptions.
support a
in the
> > <xsd:simpleContent>
> > </xsd:complexType>
> > <xsd:complexType>
> > </xsd:complexType>
> > </xsd:element>
> > </xsd:schema>
> > stack trace:
> > at
> > at
> > at
> > at
> > at
> > Ian Cornwell
Re: Specific failure in XSDEcoreBuilder [message #576901 is a reply to message #27273] |
Ed,
Ian
> Ed Merks wrote:
> > Ian,
diagnostic:
> must also
> attempting to
point
> > exceptions.
> support a
> in the
> > > <xsd:simpleContent>
> > > </xsd:complexType>
> > > <xsd:complexType>
> > > </xsd:complexType>
> > > </xsd:element>
> > > </xsd:schema>
argument
same
> > > stack trace:
> > > at
> > > at
> > > at
> > > at
> > > at
> > > Ian Cornwell
Re: Specific failure in XSDEcoreBuilder [message #576927 is a reply to message #27236] |
version)]
Ed,
Ian
Ed Merks wrote:
> Ian,
must also
attempting to
> exceptions.
support a
in the
> > <xsd:simpleContent>
> > </xsd:complexType>
> > <xsd:complexType>
> > </xsd:complexType>
> > </xsd:element>
> > </xsd:schema>
> > stack trace:
> > at
> > at
> > at
> > at
> > at
> > Ian Cornwell
Re: Specific failure in XSDEcoreBuilder [message #577039 is a reply to message #27337] |
Ian,
1201a1202
> newContentType =
Ian Cornwell wrote:
> Ed,
> Ian
> > Ed Merks wrote:
> > > Ian,
> diagnostic:
> > must also
> > attempting to
> point
> > > exceptions.
> > support a
> > in the
> > > > We
Current Time: Tue Sep 16 19:44:15 EDT 2025
Powered by FUDForum. Page generated in 0.06155 seconds
