Home » Eclipse Projects » Eclipse Platform » CTRL+S
CTRL+S [message #273453] Wed, 06 October 2004 11:29 Go to next message
I have a custom editor that I inherited from another group. Everything
works fine, except the editor doesn't respond to the CTRL+S keyboard
shortcut to save.
Is there a way to see who is consuming this event?
Re: CTRL+S [message #273693 is a reply to message #273453] Fri, 08 October 2004 16:15 Go to previous messageGo to next message
> shortcut to save.
Run with key binding debug options. You would need to create a file
some on disk called "options". In it put the following 4 lines:
org.eclipse.ui/debug=true
org.eclipse.ui/trace/contexts=true
org.eclipse.ui/trace/keyBindings=true
org.eclipse.ui/trace/keyBindings.verbose=true
Then, open a command prompt and run Eclipse. Start Eclipse with the
following additional parameter:
-debug C:\path\to\options
This might help. You could also check to see whether
AbstractTextEditor.createActions() is being called.
cheers,
d.
Re: CTRL+S [message #273765 is a reply to message #273693] Mon, 11 October 2004 12:51 Go to previous messageGo to next message
Ok...I ran in debug mode with a break point in the AbstractTextEditor's
createActions function, and that never seems to get called.
Am I supposed to call this, or is this supposed to happen automatically?
Thanks!
"Douglas Pollock" <douglas.pollock@magma.ca> wrote in message
news:ck6s6p$r1e$4@eclipse.org...
> > shortcut to save.
> cheers,
> d.
Re: CTRL+S [message #273872 is a reply to message #273765] Wed, 13 October 2004 09:00 Go to previous messageGo to next message
Did you overwrite it without calling super?
Dani
>Thanks!
>>>shortcut to save.
>>cheers,
>>d.
Re: CTRL+S [message #273900 is a reply to message #273872] Wed, 13 October 2004 11:21 Go to previous message
I did over write the createActions function, but the first line in my
function is super.createActoins();
Am I supposed to call this function somewhere in my code, or does the
Workbench do it for me automatically?
Previous Topic:Assign CTRL+PageUp to another key
Next Topic:Disaster struck!
Current Time: Wed Sep 24 18:16:45 EDT 2025
Powered by FUDForum. Page generated in 0.04957 seconds
