Home » Archived » IMP » Build lpgparser in org.eclipse.imp.lpg.runtime failed
Build lpgparser in org.eclipse.imp.lpg.runtime failed [message #27127] |
Tue, 10 March 2009 17:12 |
Defert Philippe Messages: 62 Registered: July 2009 |
Member |
I have install the lastest version of IMP with lpg.runtime 2.0.16 on
eclipse ganymede SR2
The build (incremental or full) of lpgParser in
org.eclipse.imp.lpg.runtime failed in LPGKWLexer due his depencies
i try to build it in commandline. The result is :
lpg-win32_x86.exe -include-directory='.
;..;/C:/Downloads/eclipse-jee-ganymede-SR2-win32/eclipse/plu gins/lpg.generator_2
..0.16/templates/java/;/C:/Downloads/eclipse-jee-ganymede-SR 2-win32/eclipse/plugi
ns/lpg.generator_2.0.16/include/java/' LPGParser.g
Options in effect for LPGKWLexer.gi:
ACTION-BLOCK=("","/.","./")
AST-DIRECTORY="" AST-TYPE="Ast" NOATTRIBUTES NOAUTOMATIC-AST
NOBACKTRACK
BYTE CONFLICTS DAT-DIRECTORY="" DAT-FILE="LPGKWLexerdcl.data"
DCL-FILE="LPGKWLexerdcl.xml" NODEBUG DEF-FILE="LPGKWLexerdef.xml"
NOEDIT
NOERROR-MAPS ESCAPE='%' EXPORT-TERMINALS=("LPGParsersym.xml","","")
EXTENDS-PARSETABLE FACTORY="new " FILE-PREFIX="LPGKWLexer" NOFIRST
NOFOLLOW NOGLR NOGOTO-DEFAULT GRM-FILE="LPGKWLexer.gi"
IMP-FILE="LPGKWLexerimp.xml"
INCLUDE-DIRECTORY=".;..;/C:/Downloads/eclipse-jee-ganymede-SR2-win32/eclipse
/plugins/lpg.generator_2.0.16/templates/java/;/C:/Downloads/ eclipse-jee-ganymede
-SR2-win32/eclipse/plugins/lpg.generator_2.0.16/include/java / "
LALR=1 LEGACY NOLIST MARGIN=0 MAX-CASES=1024 NAMES=OPTIMIZED
NONT-CHECK OR_MARKER='|' OUT-DIRECTORY=""
PACKAGE="org.eclipse.imp.lpg.parser" NOPARENT-SAVE
NOPARSETABLE-INTERFACES
PREFIX="" PRIORITY PROGRAMMING_LANGUAGE=XML
PRS-FILE="LPGKWLexerprs.xml"
NOQUIET READ-REDUCE REMAP-TERMINALS NOSCOPES NOSERIALIZE
NOSHIFT-DEFAULT SINGLE-PRODUCTIONS NOSOFT-KEYWORDS NOSTATES
SUFFIX=""
SYM-FILE="LPGKWLexersym.xml" TAB-FILE="LPGKWLexer.t" NOTABLE
TEMPLATE="KeywordTemplateF.gi" TRACE=CONFLICTS NOVARIABLES NOVERBOSE
NOVISITOR VISITOR-TYPE="Visitor" WARNINGS NOXREF
LPGKWLexer.gi:0:0:0:0:0:0: Error: The template file KeywordTemplateF.gi
could no
t be read.
LPGKWLexer.gi:12:5:12:28:358:381: Error: The include file
KWLexerFoldedCaseMapF.
gi could not be read.
Options in effect for LPGLexer.gi:
NOBACKTRACK
BYTE CONFLICTS DAT-DIRECTORY="" DAT-FILE="LPGLexerdcl.data"
DCL-FILE="LPGLexerdcl.xml" NODEBUG DEF-FILE="LPGLexerdef.xml" NOEDIT
EXTENDS-PARSETABLE FACTORY="new " FILE-PREFIX="LPGLexer"
FILTER="LPGKWLexer.gi" NOFIRST NOFOLLOW NOGLR NOGOTO-DEFAULT
GRM-FILE="LPGLexer.gi" IMP-FILE="LPGLexerimp.xml"
LALR=15 LEGACY NOLIST MARGIN=0 MAX-CASES=1024 NAMES=OPTIMIZED
PRS-FILE="LPGLexerprs.xml"
SUFFIX=""
SYM-FILE="LPGLexersym.xml" TAB-FILE="LPGLexer.t" NOTABLE
TEMPLATE="LexerTemplateF.gi" TRACE=CONFLICTS NOVARIABLES NOVERBOSE
Options in effect for LPGParser.g:
AST-DIRECTORY="" AST-TYPE="ASTNode" NOATTRIBUTES AUTOMATIC-AST=NESTED
NOBACKTRACK BYTE CONFLICTS DAT-DIRECTORY=""
DAT-FILE="LPGParserdcl.data"
DCL-FILE="LPGParserdcl.xml" NODEBUG DEF-FILE="LPGParserdef.xml"
NOEDIT
NOERROR-MAPS ESCAPE='%' EXPORT-TERMINALS=("LPGParserexp.xml","","")
EXTENDS-PARSETABLE FACTORY="new " FILE-PREFIX="LPGParser" NOFIRST
NOFOLLOW NOGLR NOGOTO-DEFAULT GRM-FILE="LPGParser.g"
IMP-FILE="LPGParserimp.xml" IMPORT-TERMINALS="LPGLexer.gi"
LALR=6 LEGACY NOLIST MARGIN=0 MAX-CASES=1024 NAMES=OPTIMIZED
PACKAGE="org.eclipse.imp.lpg.parser" PARENT-SAVED
PRS-FILE="LPGParserprs.xml"
NOSHIFT-DEFAULT NOSINGLE-PRODUCTIONS NOSOFT-KEYWORDS NOSTATES
SUFFIX=""
SYM-FILE="LPGParsersym.xml" TAB-FILE="LPGParser.t" NOTABLE
TEMPLATE="dtParserTemplateF.gi" TRACE=CONFLICTS VARIABLES NOVERBOSE
VISITOR=PREORDER VISITOR-TYPE="Visitor" WARNINGS NOXREF
the size of lpg-win32_X86.exe is 1224 Ko
My include directory is the default param.
Philippe
Re: Build lpgparser in org.eclipse.imp.lpg.runtime failed [message #27168 is a reply to message #27127] |
Tue, 10 March 2009 17:20 |
Member |
hi,
I download the latest lpg runtime from his project website
(lpg-win32_x86-2_0_16.exe) and the lpg command line version is : Version
2.0.15 (Feb 3 2009).
it may be a start point ?
Philippe
Defert Philippe a écrit :
> Hello,
> .0.16/templates/java/;/C:/Downloads/eclipse-jee-ganymede-SR2 -win32/eclipse/plugi
> NOBACKTRACK
> NOEDIT
> SUFFIX=""
> could no
> t be read.
> NOBACKTRACK
> SUFFIX=""
> NOEDIT
> SUFFIX=""
> Thanks
> Philippe
Re: Build lpgparser in org.eclipse.imp.lpg.runtime failed [message #27245 is a reply to message #27206] |
Wed, 11 March 2009 09:18 |
Member |
I have no error in eclipse in errorLog, the problem seems to come in lpg
runtime.
Eclipse shows 2 problems in lpg code;
The include file KWLexerFoldedCaseMapF.gi could not be read. LPGKWLexer.gi
The template file KeywordTemplateF.gi could not be read. LPGKWLexer.gi
Philippe
jin.phd@gmail.com a écrit :
> right, command line version is 2.0.15 (Feb 3 2009). Because the lpg
> generator run in "external tools". command line or running in eclipse are
> very much the same, if the settings are the same. How about your error log?
> "Defert Philippe" <defert@bayesia.com>
> ??????:gp67hn$7hn$1@build.eclipse.org...
>> hi,
>> Philippe
>>> Hello,
>>> NOBACKTRACK
>>> NOEDIT
>>> SUFFIX=""
>>> NOVERBOSE
>>> could no
>>> t be read.
>>> NOBACKTRACK
>>> NOEDIT
>>> SUFFIX=""
>>> NOEDIT
>>> SUFFIX=""
>>> NOVERBOSE
>>> Thanks
>>> Philippe
Re: Build lpgparser in org.eclipse.imp.lpg.runtime failed [message #27317 is a reply to message #27281] |
Thu, 12 March 2009 17:01 |
Member |
it doesn't work for me,
if i delete "lpgparser.java" and rebuild "lpgparser.g"
the errors were generated and lpgparser.java wasn't generated and there
occurs many errors in eclipse
can you send me your lpg's includepath from your lpg's preference.
mine is :
..;..;${pluginResource:lpg.generator/templates/java};${plugi nResource:lpg.generator/include/java}
Philippe
> The files as mentioned works for me. it is possible that the lpg editor can
> not provide the outline for some grammar files(maybe due to uncompleted
> parsing), but should read them successfully. so your problem seems odd...)
> ??????:gp7vkf$jqi$1@build.eclipse.org...
>> runtime.
>> Philippe
>>> log?
>>>> hi,
>>>> Philippe
>>>>> Hello,
>>>>> NOBACKTRACK
>>>>> NOEDIT
>>>>> NOFIRST
>>>>> SUFFIX=""
>>>>> NOVERBOSE
>>>>> could no
>>>>> t be read.
>>>>> NOBACKTRACK
>>>>> NOEDIT
>>>>> SUFFIX=""
>>>>> NOVERBOSE
>>>>> NOEDIT
>>>>> NOFIRST
>>>>> SUFFIX=""
>>>>> NOVERBOSE
>>>>> Thanks
>>>>> Philippe
Re:[BUG] Build lpgparser in org.eclipse.imp.lpg.runtime failed [message #27741 is a reply to message #27317] |
Fri, 13 March 2009 10:05 |
Member |
I searched and i found :-)
i'm under windows system and eclipse is under java.
the default generated includepath is in java syntax , the folder
separator is '/' but the lpg generator is win32 program and understand
only win32 folder separator AKA '\'
The FIX for win32 is switch java filepath syntax to win32 filepath
syntax of includepath before calling lpggenerator
or something like that
Philippe
> mine is :
> .;..;${pluginResource:lpg.generator/templates/java};${plugin Resource:lpg.generator/include/java}
> Philippe
>>> runtime.
>>> Philippe
>>>> log?
>>>>> hi,
>>>>> Philippe
>>>>>> Hello,
>>>>>> NOBACKTRACK
>>>>>> NOEDIT
>>>>>> NOFIRST
>>>>>> SUFFIX=""
>>>>>> NOVERBOSE
>>>>>> could no
>>>>>> t be read.
>>>>>> NOBACKTRACK
>>>>>> NOEDIT
>>>>>> SUFFIX=""
>>>>>> NOVERBOSE
>>>>>> NOEDIT
>>>>>> NOFIRST
>>>>>> SUFFIX=""
>>>>>> NOVERBOSE
>>>>>> Thanks
>>>>>> Philippe
Re: [BUG] Build lpgparser in org.eclipse.imp.lpg.runtime failed [message #27765 is a reply to message #27741] |
Fri, 13 March 2009 10:06 |
Member |
I 'm under winXP
> Philippe
>> mine is :
>> Philippe
>>>> runtime.
>>>> Philippe
>>>>> log?
>>>>>> hi,
>>>>>> Philippe
>>>>>>> Hello,
>>>>>>> NOBACKTRACK
>>>>>>> NOEDIT
>>>>>>> NOFIRST
>>>>>>> SUFFIX=""
>>>>>>> NOVERBOSE
>>>>>>> could no
>>>>>>> t be read.
>>>>>>> NOBACKTRACK
>>>>>>> NOEDIT
>>>>>>> SUFFIX=""
>>>>>>> NOVERBOSE
>>>>>>> NOEDIT
>>>>>>> NOFIRST
>>>>>>> SUFFIX=""
>>>>>>> NOVERBOSE
>>>>>>> Thanks
>>>>>>> Philippe
Re: Build lpgparser in org.eclipse.imp.lpg.runtime failed [message #575219 is a reply to message #27127] |
Member |
hi,
Philippe
> Hello,
> NOBACKTRACK
> NOEDIT
> SUFFIX=""
> could no
> t be read.
> NOBACKTRACK
> SUFFIX=""
> NOEDIT
> SUFFIX=""
> Thanks
> Philippe
Re: Build lpgparser in org.eclipse.imp.lpg.runtime failed [message #575266 is a reply to message #27206] |
Member |
runtime.
Philippe
>> hi,
>> Philippe
>>> Hello,
>>> NOBACKTRACK
>>> NOEDIT
>>> SUFFIX=""
>>> NOVERBOSE
>>> could no
>>> t be read.
>>> NOBACKTRACK
>>> NOEDIT
>>> SUFFIX=""
>>> NOEDIT
>>> SUFFIX=""
>>> NOVERBOSE
>>> Thanks
>>> Philippe
Re: Build lpgparser in org.eclipse.imp.lpg.runtime failed [message #575287 is a reply to message #27281] |
Member |
mine is :
Philippe
>> runtime.
>> Philippe
>>> log?
>>>> hi,
>>>> Philippe
>>>>> Hello,
>>>>> NOBACKTRACK
>>>>> NOEDIT
>>>>> NOFIRST
>>>>> SUFFIX=""
>>>>> NOVERBOSE
>>>>> could no
>>>>> t be read.
>>>>> NOBACKTRACK
>>>>> NOEDIT
>>>>> SUFFIX=""
>>>>> NOVERBOSE
>>>>> NOEDIT
>>>>> NOFIRST
>>>>> SUFFIX=""
>>>>> NOVERBOSE
>>>>> Thanks
>>>>> Philippe
Re:[BUG] Build lpgparser in org.eclipse.imp.lpg.runtime failed [message #575306 is a reply to message #27317] |
Member |
Philippe
> mine is :
> Philippe
>>> runtime.
>>> Philippe
>>>> log?
>>>>> hi,
>>>>> Philippe
>>>>>> Hello,
>>>>>> NOBACKTRACK
>>>>>> NOEDIT
>>>>>> NOFIRST
>>>>>> SUFFIX=""
>>>>>> NOVERBOSE
>>>>>> could no
>>>>>> t be read.
>>>>>> NOBACKTRACK
>>>>>> NOEDIT
>>>>>> SUFFIX=""
>>>>>> NOVERBOSE
>>>>>> NOEDIT
>>>>>> NOFIRST
>>>>>> SUFFIX=""
>>>>>> NOVERBOSE
>>>>>> Thanks
>>>>>> Philippe
Re: [BUG] Build lpgparser in org.eclipse.imp.lpg.runtime failed [message #575327 is a reply to message #27741] |
Member |
I 'm under winXP
> Philippe
>> mine is :
>> Philippe
>>>> runtime.
>>>> Philippe
>>>>> log?
>>>>>> hi,
>>>>>> Philippe
>>>>>>> Hello,
>>>>>>> NOBACKTRACK
>>>>>>> NOEDIT
>>>>>>> NOFIRST
>>>>>>> SUFFIX=""
>>>>>>> NOVERBOSE
>>>>>>> could no
>>>>>>> t be read.
>>>>>>> NOBACKTRACK
>>>>>>> NOEDIT
>>>>>>> SUFFIX=""
>>>>>>> NOVERBOSE
>>>>>>> NOEDIT
>>>>>>> NOFIRST
>>>>>>> SUFFIX=""
>>>>>>> NOVERBOSE
>>>>>>> Thanks
>>>>>>> Philippe
Current Time: Thu May 09 01:23:11 GMT 2024
Powered by FUDForum. Page generated in 0.04007 seconds
