Home » Modeling » EMF » [XSD] EList of Object as operation return type
[XSD] EList of Object as operation return type [message #1499010] Thu, 04 December 2014 16:18 Go to next message
I have an XSD that contains a couple operations and it is working when I refer to types defined in my XSD. However I'm having difficulties specifying an EList<java.lang.Object> as a return type or any other plain Java type . When I do so using the following markup, the returned type specified in the generated code is EObject.
It all looks like the loss of information happens when I go from the XSD to the ecore but I'm not sure why it is happening since I have seen the following markup in other places including the emf.xsd.
<xsd:annotation>
<xsd:appinfo ecore:key="operations" source="http://www.eclipse.org/emf/2002/Ecore">
<operation name="getValue" type="ecore:EEList{ecore:EJavaObject}">
<parameter name="expression" type="xsd:string" />
</operation>
Thanks in advance,
Pascal
Re: [XSD] EList of Object as operation return type [message #1504513 is a reply to message #1499010] Tue, 09 December 2014 05:13 Go to previous message
Pascal,
On 04/12/2014 10:18 PM, Pascal Rapicault wrote:
Keep in mind that the types such as ecore:EJavaObject must resolve so
you'd need a correspong xsd:import
One trick to try is modify the generated *.ecore to be how you want, and
export it back to an XML Schema and look at the annotations in that *.xsd
> <xsd:annotation>
> </operation>
> Thanks in advance,
> Pascal
Previous Topic:Error while running my Eclipse application
Next Topic:[CDO] Invalid signalID on commit
Current Time: Wed Oct 29 04:36:39 EDT 2025
Powered by FUDForum. Page generated in 0.03430 seconds
