Home » Archived » Jubula » MySQL troubles - table node does not exist (Cannot Import unbound_modules_concrete8.0.xml)
MySQL troubles - table node does not exist [message #1498172] |
Thu, 04 December 2014 08:17 |
fab jubulator Messages: 30 Registered: November 2014 |
Member |
If I connect to the MySQL Database it seems that the table "node" is not created.
Can that be fixed?
Can I create the tables manually?
Importing unbound_modules_concrete_8.0...
Error occurred while importing unbound_modules_concrete_8.0:
org.eclipse.jubula.client.core.persistence.PMSaveException: Can't save project.Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.5.1.v20130918-f2b9fc5): org.eclipse.persistence.exceptions.DatabaseException
Internal Exception: com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: Table 'jubula_8.0.node' doesn't exist
Error Code: 1146
Call: INSERT INTO NODE (ID, IS_ACTIVE, COMP_NAME, COMP_TYPE, IS_GENERATED, GUID, COMP_ACTION, COMM_TXT, NAME, PARENT_PROJ, TASK_ID, TIMESTAMP, VERSION, FK_PARAM_INTERFACE, CLASS_ID) VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)
bind => [15 parameters bound]
Query: InsertObjectQuery(org.eclipse.jubula.client.core.model.CapPO@4c04bb57 (store text at mouse position)) :Save of unbound_modules_concrete failed!.
Finished importing projects.
I have since taken a look at the H2 database and the SQL statements, which are incompatible with MySql.
Does Jubula offer some kind of conversion?
Which oracle dmbs do you recommend instead?
We use postgrs and MySql: The ones which don't seem to work properly with Jubula.
[Updated on: Thu, 04 December 2014 11:52] Report message to a moderator
Re: MySQL troubles - table node does not exist [message #1504720 is a reply to message #1498172] |
Tue, 09 December 2014 13:51 |
Member |
If I want to connect my MySQL DB. th econnection fails. The client log says this:
[Worker-0] ERROR o.e.j.c.core.persistence.Persistor - DBVersion: db entry for DBVersion is missing or ambiguous
Does anybody know this?
I've taken a look into the h2 database. It says:
JUBULA PUBLIC DB_VERSION TABLE (null) (null) (null) (null) (null) CREATE CACHED TABLE PUBLIC.DB_VERSION(
ID BIGINT NOT NULL,
MAJORVERSION INTEGER,
MINORVERSION INTEGER,
VERSION INTEGER
Is there possibly a connection?
[Updated on: Tue, 09 December 2014 14:11] Report message to a moderator
Current Time: Fri Apr 26 07:33:41 GMT 2024
Powered by FUDForum. Page generated in 0.03428 seconds
