NoSuchMethodError: OfflineMode.setEnabled() since update [message #1497254] |
Wed, 03 December 2014 12:27  |
Since the last update (my installer says Build 689), I cannot run the setup of any deployed Eclipse, the following error is logged after clicking Next on the wizard with the list of task to be executed. The next wizard page is completely empty and the setup stops, with Finish enabled but clicking it does nothing.
!ENTRY org.eclipse.jface 4 2 2014-12-03 18:11:27.824
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.jface".
!STACK 0
java.lang.NoSuchMethodError: org.eclipse.oomph.util.OfflineMode.setEnabled(Z)Z
at org.eclipse.oomph.setup.internal.core.AbstractSetupTaskContext.setOffline(AbstractSetupTaskContext.java:125)
at org.eclipse.oomph.setup.ui.wizards.ConfirmationPage.leavePage(ConfirmationPage.java:384)
at org.eclipse.oomph.setup.ui.wizards.SetupWizard.pageChanged(SetupWizard.java:269)
at org.eclipse.jface.wizard.WizardDialog$9.run(WizardDialog.java:1594)
Is this related to http://git.eclipse.org/c/oomph/org.eclipse.oomph.git/commit/?id=7863d2c2da769aa3d333507315824929c2ad5a08 ?
Is there any workaround?
Thanks!
Re: NoSuchMethodError: OfflineMode.setEnabled() since update [message #1498203 is a reply to message #1498192] |
Thu, 04 December 2014 03:44   |
I also just tested with a fresh installer download (build 690) and couldn't reproduce the problem. Can you try that,
please, and tell me how that goes?
Before you try that, please make a screenshot of your old installer's About dialog and let me see it. Mine looked strange...
Cheers
/Eike
http://www.esc-net.de
Am 04.12.2014 um 09:34 schrieb Eike Stepper:
> Hi Abel,
> It seems I have introduced this problem with commit 1ae5eb2cdbc2f40b0b66fb899627e62f008b340e:
> [453472] Let OfflineMode.setEnabled() return the old enablement value
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=453472
> I got the same message and I could make no sense out of it. So I reverted that change in commit
> 7863d2c2da769aa3d333507315824929c2ad5a08 and I thought now the weird problem should be gone. The revert is almost a
> week ago (Nov 28), but then it seemed that Eclipse's signing service was down over the last weekend and we didn't get
> signed nightly builds promoted. Could it be that your problem goes away if you try to update again? Hmm, probably not;
> I see that you're already updated to build 689. I just updated from 679 to 690 and I don't have that problem.
> I think the root cause must be that plugins org.eclipse.oomph.util and org.eclipse.oomph.setup.core are updated at a
> different/oinconsistent pace. No idea, yet, why that is ;-(
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
> Am 03.12.2014 um 18:27 schrieb Abel Hegedus:
>> !STACK 0
>> Is this related to
>> Thanks!
FUDForum. Page generated in 0.05467 seconds
