Home » Archived » Sapphire » How to programmatically add elements to a Sapphire list?
How to programmatically add elements to a Sapphire list? [message #1497003] Wed, 03 December 2014 13:10 Go to next message
Dmitri Pisarenko is currently offline Dmitri PisarenkoFriend
Hello!
I have following model:
public interface IMyModel extends Element {
	ElementType TYPE = new ElementType(IMyModel.class);
	@Type(base=ISomeElement.class)
	@Label( standard = "Some element" )
    ListProperty PROP_SOME_ELEMENTS = new ListProperty( TYPE, "SomeElements" );
    ElementList<ISomeElement> getSomeElements();
    void setSomeElements(final ElementList<ISomeElement> value);
public interface ISomeElement extends Element {
	ElementType TYPE = new ElementType(ISomeElement.class);
	// Name
	@Label(standard = "Name")
	@Required
	ValueProperty PROP_NAME = new ValueProperty(TYPE, "Name");
	Value<String> getName();
	void setName(String name);
When I try to create an instance of IMyModel and then a ISomeElement instance to it, I get an error.
final IMyModel sample = IMyModel.TYPE.instantiate();
final ISomeElement someElement = ISomeElement.TYPE.instantiate();
someElement.setName("Some name");
sample.getSomeElements().add(someElement);
The error is caused by this piece of code in org.eclipse.sapphire.ElementList.add(T):
public boolean add( final T object )
    throw new UnsupportedOperationException();
How am I supposed to add elements to a list programmatically?
Note that I need this to be able to run tests on classes, which use IMyModel as input.
Thanks in advance
Dmitri Pisarenko
Re: How to programmatically add elements to a Sapphire list? [message #1497067 is a reply to message #1497003] Wed, 03 December 2014 14:13 Go to previous messageGo to next message
Greg Amerson is currently offline Greg AmersonFriend
final ISomeElement someElement = sample.getSomeElements().insert();
Re: How to programmatically add elements to a Sapphire list? [message #1497072 is a reply to message #1497067] Wed, 03 December 2014 14:18 Go to previous message
Thanks!
Previous Topic:What class/interface do I need to extend/implement to create a custom Sapphire property editor?
Next Topic:What is the best way to add tree node for an optional xml child element?
Current Time: Fri Apr 26 11:54:26 GMT 2024
Powered by FUDForum. Page generated in 0.03401 seconds
