Home » Newcomers » Newcomers » duplicate configuration & p2 folder
duplicate configuration & p2 folder [message #271974] Sat, 04 July 2009 10:38 Go to next message
After starting Eclipse Ganymede 3.4.2 on Windows Vista, it creates a
'.eclipse' folder in the folder parent to the 'eclipse' folder with the
executable. In this folder the org.eclipse.platform_3.4.0_1619947715
folder is created and therein the duplicate configuration and p2 folders.
How do I change this behaviour (i.e. no '.eclipse' , no duplicates).
Re: duplicate configuration & p2 folder [message #271982 is a reply to message #271974] Sat, 04 July 2009 21:27 Go to previous messageGo to next message
I'm not really sure if you can change where or if you want to place it
somewhere without changing the source code.
However the solution that I found for that ugly file is making it hidden.
Not sure if that helps.
Re: duplicate configuration & p2 folder [message #272004 is a reply to message #271974] Mon, 06 July 2009 12:31 Go to previous messageGo to next message
I wonder if the permissions restrictions in vista have lead to something
like a multi-user installation, as described here:
http://help.eclipse.org/stable/index.jsp?topic=/org.eclipse. platform.doc.isv/reference/misc/multi_user_installs.html
It's just a shot in the dark, but perhaps that information will help you
figure out what's happening.
Eric
Re: duplicate configuration & p2 folder [message #272020 is a reply to message #272004] Mon, 06 July 2009 17:57 Go to previous message
Thanks, the link explained precisely my situation.
I located config.ini in the directory [eclipse]\configuration and changed
the following lines:
osgi.configuration.area=C:/Users/Xxx/Eclipse/configuration
-- this was my original configuration folder
osgi.instance.area.default=@user.home/Documents/Development/ Java/workspaces
-- now the default workspaces dir was correct without having to browse
First I used backslashes with the result that e.g. folders like
UsersXxxEclipseconfiguration were created ... trial and error
Previous Topic:RSE
Next Topic:Passing instances to Eclipse View
Current Time: Mon Oct 27 11:33:08 EDT 2025
Powered by FUDForum. Page generated in 0.32732 seconds
