Debug View does not show Source Code [message #271119] |
Tue, 26 May 2009 15:08 |
Originally posted by: nospam.nospam.org
I have a Jar file, along with the source code that I am using for my
own project. I have attached the source of the Jar such that if I am
editing my Java Code, and I select “Open Declaration” i.e. F3, I get
the appropriate file in the source code of the Jar pulled up.
Now, when I am debugging, and try to step into the same method that I
could formerly reach using F3, it tells me “Source Not Found”. I attempt
to use the “Edit Source Lookup Path”, and add the necessary folder – but
when I add it, it seems empty. I can take it to the actual file, if
there is a way to do this.
Any ideas on how to view the Source Code during Debugging? I am using
Version: 3.4.1.
Thanks a lot,
O. O.
FUDForum. Page generated in 0.09019 seconds
