Home » Language IDEs » Java Development Tools (JDT) » Eclipse hangs on startup
Eclipse hangs on startup [message #1489579] Thu, 27 November 2014 08:48 Go to next message
Hello all!
Every time I restart Eclipse Luna it stops loading at about 30 to 40% of progress bar. Then I have to quit, delete all .lock and .snap files, rename the workspace\.metadata\.plugins\org.eclipse.core.resources, start Eclipse again, close all open windows if necessary, quit Eclipse, restore the previously renamed folder and start Eclipse again. But when I exit Eclipse again it will be the same problem.
I use Windows 7 x64 and Eclipse Luna.
Thanks in advance!
Re: Eclipse hangs on startup [message #1489833 is a reply to message #1489579] Thu, 27 November 2014 13:27 Go to previous message
It probably needs more information to understand what's causing the hang.
Please see https://wiki.eclipse.org/How_to_report_a_deadlock
Stephan
[Updated on: Thu, 27 November 2014 13:27] by Moderator
Previous Topic:Restricting build path dependencies
Next Topic:Error when open file
Current Time: Mon Nov 10 09:47:08 EST 2025
Powered by FUDForum. Page generated in 0.03778 seconds
