Home » Archived » IMP » New release of IMP available on eclipse.org
New release of IMP available on eclipse.org [message #26810] |
Tue, 24 February 2009 03:48 |
Robert M. Fuhrer Messages: 294 Registered: July 2009 |
Hi All,
I've just posted a new release of IMP on our eclipse.org update
site (at long last!). The update site location is:
http://download.eclipse.org/technology/imp/updates
We've done quite a bit of debugging over the last several months,
and finally got our IP approvals for the various dependencies on
external tools (like Polyglot and LPG).
The preferences specification language has been enhanced
considerably (with support for new field types, and several
elements are now optional, with sensible defaults).
There is now a "presentation specification language" (more or
less bleeding-edge, which provides fairly concise and declarative
syntax for specifying token coloring, outlining, folding, and
label provider services. It's been a while since I worked on this,
but at last report it was generating sensible-looking working code.
Your mileage may vary.
We've tested this on Eclipse 3.3 and 3.4. We've not had time as
of yet to try it out on 3.5Mx, so any intrepid souls out there
that would like to try and post their experiences would be very
helpful. We've been developing on MacOS, Windows, and Linux, so
hopefully you'll find things working fairly well on these
platforms.
The update site houses not only IMP, but all of the other
features on which IMP depends (which previously you needed to
go to other update sites to retrieve):
- LPG
- Polyglot
- SDF + Box
Also, we've done a bit of reorganization of the features, so that
now the analysis-related code (the "Program DataBase", or PDB,
and friends) have been relocated to separate features.
Finally, as a quick heads-up, there are some minor breaking API
changes to PluginBase (derived classes need to define getLanguageID())
and a couple of other classes.
-- Bob
Robert M. Fuhrer
Research Staff Member
Programming Technologies Dept.
IBM T.J. Watson Research Center
IDE Meta-tooling Platform Project Lead (http://www.eclipse.org/imp)
X10: Productive High-Performance Parallel Programming (http://x10.sf.net)
Re: New release of IMP available on eclipse.org [message #26932 is a reply to message #26810] |
Thu, 05 March 2009 17:18 |
Nicolas Rouquette Messages: 157 Registered: July 2009 |
I installed IMP from the update site below; however, I get these errors
when installing other features:
Cannot complete the install because some dependencies are not satisfiable
"lpg.generator.feature.group 2.0.16" requires
"lpg.generator.linux_x86 [2.0.16]"
"lpg.generator.macosx_x86 [2.0.16]"
This system is a windows platform so it makes sense that the lpg install
didn't include the linux & macosx plugins; however, it seems that p2 now
believes that *all* os/arch-specific versions of the lpg.generator
plugins must be installed.
Is this a bug?
-- Nicolas.
Robert M. Fuhrer wrote:
> Hi All,
> platforms.
> - LPG
> - Polyglot
> - SDF + Box
Re: New release of IMP available on eclipse.org [message #27051 is a reply to message #26810] |
Mon, 09 March 2009 16:56 |
Jin Missing name Messages: 100 Registered: July 2009 |
Great work! As my primary test, the new release works well under the Eclipse
3.5M5. The stability of this release has been much improved in my feeling.
hope imp will end incubation soon.
"Robert M. Fuhrer" <rfuhrer@watson.ibm.com>
??????:gnvqlr$7sf$1@build.eclipse.org...
> Hi All,
> platforms.
> - LPG
> - Polyglot
> - SDF + Box
> Cheers,
> -- Bob
> Robert M. Fuhrer
Re: New release of IMP available on eclipse.org [message #27089 is a reply to message #26810] |
Tue, 10 March 2009 07:04 |
today I check the trunk source to see the behavior, two trivial errors
found, I add a bug to bugizlla as a note[].
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=267771
> Hi All,
> platforms.
> - LPG
> - Polyglot
> - SDF + Box
> Cheers,
> -- Bob
> Robert M. Fuhrer
Re: New release of IMP available on eclipse.org [message #28941 is a reply to message #28904] |
Tue, 14 July 2009 16:07 |
Thanks, Jason! I had assumed that having the appropriate os/arch tags on
the plugin fragments themselves was enough. Happy to be proven wrong,
though, as this solves a long-standing problem.
We've been busy with some bug triage, and have been sorting through the
[many existing bugs, determining their current status. Needless to say,
the install issues were/are high on the priority list.]
I'll apply these fixes to the lpg.generator feature ASAP, and the next
release of LPG will have the fixes.
I'll also fix the 2.0.16 release (which is the latest one for which we
have a proper CQ in place for IMP), and patch the update site.
Again, many thanks Jason for pointing this out!
Jason C Garcowski wrote:
> Hello,
> I don't think it has been committed to LPG, but the fix is to add the
> correct os and arc attributes to those plugins in the feature.xml file
> (which you could do on your local install if you so wished):
> <plugin
> id="lpg.generator.linux_x86"
> download-size="0"
> install-size="0"
> os="linux"
> arch="x86"
> version="2.0.16"
> fragment="true"
> unpack="false"/>
> <plugin
> id="lpg.generator.macosx_x86"
> download-size="0"
> install-size="0"
> os="macosx"
> arch="x86"
> version="2.0.16"
> fragment="true"
> unpack="false"/>
> <plugin
> id="lpg.generator.win32_x86"
> download-size="0"
> install-size="0"
> os="win32"
> arch="x86"
> version="2.0.16"
> fragment="true"
> unpack="false"/>
> HTH,
> jason
- Bob
Re: New release of IMP available on eclipse.org [message #29166 is a reply to message #28941] |
Tue, 14 July 2009 19:10 |
I've updated the feature manifests for the lpg.generator feature in
LPG 2.0.16 and 2.0.17 on the LPG update site. The changes have also
been checked into CVS HEAD on LPG's sourceforge repo.
I've also updated the copies of the lpg.generator feature on the IMP
update site.
Please post if you have good or bad experiences after these changes.
Thanks!
>> Hello,
>> <plugin
>> download-size="0"
>> install-size="0"
>> os="linux"
>> arch="x86"
>> version="2.0.16"
>> fragment="true"
>> unpack="false"/>
>> <plugin
>> download-size="0"
>> install-size="0"
>> os="macosx"
>> arch="x86"
>> version="2.0.16"
>> fragment="true"
>> unpack="false"/>
>> <plugin
>> download-size="0"
>> install-size="0"
>> os="win32"
>> arch="x86"
>> version="2.0.16"
>> fragment="true"
>> unpack="false"/>
-- Bob
Robert M. Fuhrer
Re: New release of IMP available on eclipse.org [message #575093 is a reply to message #26810] |
Is this a bug?
-- Nicolas.
> Hi All,
> platforms.
> - LPG
> - Polyglot
> - SDF + Box
Re: New release of IMP available on eclipse.org [message #575160 is a reply to message #26810] |
> Hi All,
> platforms.
> - LPG
> - Polyglot
> - SDF + Box
> Cheers,
> -- Bob
> Robert M. Fuhrer
Re: New release of IMP available on eclipse.org [message #575185 is a reply to message #26810] |
> Hi All,
> platforms.
> - LPG
> - Polyglot
> - SDF + Box
> Cheers,
> -- Bob
> Robert M. Fuhrer
Re: New release of IMP available on eclipse.org [message #575889 is a reply to message #28904] |
> Hello,
> <plugin
> download-size="0"
> install-size="0"
> os="linux"
> arch="x86"
> version="2.0.16"
> fragment="true"
> unpack="false"/>
> <plugin
> download-size="0"
> install-size="0"
> os="macosx"
> arch="x86"
> version="2.0.16"
> fragment="true"
> unpack="false"/>
> <plugin
> download-size="0"
> install-size="0"
> os="win32"
> arch="x86"
> version="2.0.16"
> fragment="true"
> unpack="false"/>
> HTH,
> jason
- Bob
Re: New release of IMP available on eclipse.org [message #576008 is a reply to message #28941] |
update site.
Thanks!
>> Hello,
>> <plugin
>> download-size="0"
>> install-size="0"
>> os="linux"
>> arch="x86"
>> version="2.0.16"
>> fragment="true"
>> unpack="false"/>
>> <plugin
>> download-size="0"
>> install-size="0"
>> os="macosx"
>> arch="x86"
>> version="2.0.16"
>> fragment="true"
>> unpack="false"/>
>> <plugin
>> download-size="0"
>> install-size="0"
>> os="win32"
>> arch="x86"
>> version="2.0.16"
>> fragment="true"
>> unpack="false"/>
-- Bob
Robert M. Fuhrer
Current Time: Fri Apr 26 05:52:06 GMT 2024
Powered by FUDForum. Page generated in 0.06231 seconds
