| ClassNotFound SaxParserFactory when starting eclipse [message #270333] |
Mon, 06 September 2004 17:42  |
Originally posted by: wmoore2242.netscape.net
I get the following errors when starting eclipse:
!SESSION Sep 06, 2004 15:17:56.397
eclipse.buildId=I200406251208
java.version=1.3.1_06
!ENTRY org.eclipse.osgi Sep 06, 2004 15:17:56.407
!MESSAGE Error registering XML parser services.
!STACK 0
java.lang.ClassNotFoundException: javax.xml.parsers.SAXParserFactory
at java.net.URLClassLoader$1.run(URLClassLoader.java:195)
at java.net.URLClassLoader.findClass(URLClassLoader.java:183)
at java.lang.ClassLoader.loadClass(ClassLoader.java:294)
at java.lang.ClassLoader.loadClass(ClassLoader.java:250)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:310 )
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:115)
org.eclipse.core.runtime.adaptor.EclipseAdaptor.registerEndo rsedXMLParser(EclipseAdaptor.java:272)
org.eclipse.core.runtime.adaptor.EclipseAdaptor.frameworkSta rt(EclipseAdaptor.java:253)
org.eclipse.osgi.framework.internal.core.SystemBundleActivat or.start(SystemBundleActivator.java:61)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$1 .run(BundleContextImpl.java:958)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:954)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:937)
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:553)
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:477)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:273)
org.eclipse.osgi.framework.internal.core.StartLevelManager.l aunch(StartLevelManager.java:243)
org.eclipse.osgi.framework.internal.core.SystemBundle.resume (SystemBundle.java:166)
org.eclipse.osgi.framework.internal.core.Framework.launch(Fr amework.java:425)
at org.eclipse.osgi.framework.internal.core.OSGi.launch(OSGi.ja va:51)
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:216)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:127)
at java.lang.reflect.Method.invoke(Native Method)
at org.eclipse.core.launcher.Main.basicRun(Main.java:183)
at org.eclipse.core.launcher.Main.run(Main.java:644)
at org.eclipse.core.launcher.Main.main(Main.java:628)
!ENTRY org.eclipse.osgi Sep 06, 2004 15:17:56.668
!MESSAGE Startup error
!STACK 1
java.lang.NoClassDefFoundError: org/xml/sax/helpers/DefaultHandler
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:488)
at java.security.SecureClassLoader.defineClass(SecureClassLoade r.java:106)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:243)
at java.net.URLClassLoader.access$100(URLClassLoader.java:51)
at java.net.URLClassLoader$1.run(URLClassLoader.java:190)
org.eclipse.core.runtime.adaptor.PluginConverterImpl.parsePl uginInfo(PluginConverterImpl.java:552)
org.eclipse.core.runtime.adaptor.PluginConverterImpl.fillPlu ginInfo(PluginConverterImpl.java:111)
org.eclipse.core.runtime.adaptor.PluginConverterImpl.convert Manifest(PluginConverterImpl.java:655)
org.eclipse.core.runtime.adaptor.EclipseBundleData.generateM anifest(EclipseBundleData.java:219)
org.eclipse.core.runtime.adaptor.EclipseBundleData.loadManif est(EclipseBundleData.java:177)
org.eclipse.core.runtime.adaptor.EclipseBundleData.getManife st(EclipseBundleData.java:159)
org.eclipse.core.runtime.adaptor.EclipseBundleData.loadFromM anifest(EclipseBundleData.java:266)
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultBu ndleData.initializeNewBundle(DefaultBundleData.java:77)
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultAd aptor$1.begin(DefaultAdaptor.java:451)
org.eclipse.osgi.framework.internal.core.Framework.installWo rkerPrivileged(Framework.java:746)
org.eclipse.osgi.framework.internal.core.Framework$2.run(Fra mework.java:664)
org.eclipse.osgi.framework.internal.core.Framework.installWo rker(Framework.java:715)
org.eclipse.osgi.framework.internal.core.Framework.installBu ndle(Framework.java:659)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.i nstallBundle(BundleContextImpl.java:219)
org.eclipse.core.runtime.adaptor.EclipseStarter.installBundl es(EclipseStarter.java:800)
org.eclipse.core.runtime.adaptor.EclipseStarter.loadBasicBun dles(EclipseStarter.java:429)
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:222)
!ENTRY org.eclipse.osgi Sep 06, 2004 15:17:56.678
!MESSAGE Bundle
initial@reference:file:c:/eclipse/plugins/org.eclipse.core.runtime_3.0.0/
[1] was not resolved.
| Re: ClassNotFound SaxParserFactory when starting eclipse [message #270658 is a reply to message #270337] |
Wed, 08 September 2004 15:09  |
Originally posted by: donb.rossgroupinc.com
I got it to work by looking in the FAQs under running eclipse and setting
the -vm option.
<user@domain.invalid> wrote in message news:chin8l$jos$1@eclipse.org...
> Please read the header on the download page before you download files to
> see what the requirements are. You will need a 1.4.1 level or higher
> Java runtime or Java development kit (JDK) installed on your machine in
> order to run Eclipse.
> norwood sisson
> > BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> > !STACK 0
> > at java.security.AccessController.doPrivileged(Native Method)
> > at
> > at
r.java:253)
> > at
> > at
xtImpl.java:958)
> > at
> > at
xtImpl.java:937)
> > at
> > at
lManager.java:477)
> > at
> > at
Manager.java:243)
> > at
va:166)
> > at
> > at
> > at
216)
> > at
> > !STACK 1
> > at
> > at
> > at
> > at
> > at
undleData.java:219)
> > at
eData.java:177)
> > at
Data.java:159)
> > at
undleData.java:266)
> > at
> > at
> > at
ramework.java:746)
> > at
> > at
ava:715)
> > at
ava:659)
> > at
> > at
r.java:800)
> > at
ter.java:429)
> > at
222)
> > at
> > !MESSAGE Bundle
FUDForum. Page generated in 0.23987 seconds
