Home » Eclipse Projects » DSDP - Target Management » Portable RSE - dont save passwords
| Portable RSE - dont save passwords [message #26765] |
Mon, 15 September 2008 14:02  |
I putd the eclipse on my usb flash drive and added some ftp connection.
On the computer that i was added this ftp's - its works, but on another
computer rse asking me to enter password again for this ftp's, on third
computer its asking me again, why?
i want to do portable eclise with portable rse, but two days im breaking
my head, pease help!
| Re: Portable RSE - dont save passwords [message #27005 is a reply to message #26765] |
Tue, 23 September 2008 14:24  |
Hello Dima,
RSE stores its passwords in the Eclipse Keyring, which is stored by
default in the Eclipse Configuration Area, which may in turn default to
a folder below the Windows home directory.
You can change this behavior with the -keyring command-line argument. To
use this, I'd suggest writing a little batch file on your USB key to
launch Eclipse with the additional parameter. See also
http://help.eclipse.org/ganymede/topic/org.eclipse.rse.doc.u ser/tasks/tbeginpass.html
See also scenario #2 ("Shared Installs") on
http://help.eclipse.org/ganymede/topic/org.eclipse.platform. doc.isv/reference/misc/multi_user_installs.html
I guess that your Eclipse Install on the USB Key appears read-only to
Eclipse, that's why it places the configuration area into the user home.
I guess that if you pre-populate a local "Scenario #3 - shared
configuration" area on your stick, the FTP password should also
be taken from that shared configuration.
HTH,
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Dima wrote:
| Re: Portable RSE - dont save passwords [message #577138 is a reply to message #26765] |
Hello Dima,
HTH,
Dima wrote:
Current Time: Sat Oct 25 16:06:37 EDT 2025
Powered by FUDForum. Page generated in 0.04754 seconds
