Re: import an xmi file into EMF [message #1488136 is a reply to message #1487156] |
Wed, 26 November 2014 10:41 |
Ed Willink Messages: 7655 Registered: July 2009 |
It depends what YIOU mean by an ecore model.
If you have a valid *.xmi file the Sample Reflective Ecore Editor will
load it, so you have nothing to do.
I'm guessing that CWM might be a profile extension of UML, so in so far
as you can find a UML compatibility between Eclipse UML2 and EA, it
might load in Eclipse UML2 or Papyrus. Search the UML newsgroup for
discussions on EA compatibility. NV=B Eclipse UML2 supports UML 2.2,
2.4, 2.5. EA seems to be UML 2.3.
Once you can load into Eclipse UML2 you can use UML2Ecore to convert to
an Ecore metamodel.
With nothing to look at, it's hard to comment further.
Ed Willink
On 25/11/2014 19:49, lami P wrote:
> Hello,
> I'm a beginner in EMF , i have done an extension of CWM by Entreprise
> architect and i generated the xmi file ,my question is how can i import
> that xmi file into EMF and create an ecore model from that and genered
> it ?
> Any help on how this can be done? :( Thanks
FUDForum. Page generated in 0.03438 seconds
