Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Edapt] Migrator / MigrationReconstructor for Models without XMI Serialization(How to use Edapt on models which are not serialized in XMI files, but in a database using Teneo.)
icon5.gif  [Edapt] Migrator / MigrationReconstructor for Models without XMI Serialization [message #1486656] Tue, 25 November 2014 02:35 Go to next message
Hello everybody,
I have a simple Ecore meta-model and model instances saved to a relational database using Eclipse Teneo / Hibernate. Now, I would like to check if I can use Edapt to migrate from one meta-model version to another, including migration of my model instance data. I checked the tutorial of Edapt and also the source code in the GIT repository and am not sure if I can use Edapt out of the box. To me it seems that Edapt relies on model instances being persistet in either XMI files or a CDO repository. So I would have to write my own Migrator and/or MigrationReconstructor... Is that right or am I completely lost and there's another - much simpler - approach?
Thanks for any hints.
Cheers
Timo
Re: [Edapt] Migrator / MigrationReconstructor for Models without XMI Serialization [message #1489416 is a reply to message #1486656] Thu, 27 November 2014 05:49 Go to previous message
Hi Timo,
your assumption is correct, a direct migration within the database is
not possible with Edapt. A common workaround is a database export to
XMI, a migration and a re-import to the database.
Maximilian
Am 25.11.2014 08:35, schrieb Timo Rohrberg:
> Hello everybody,
> Cheers
> Timo
Maximilian Kögel
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
Previous Topic:[EMFStore] Performance Hit by number of checked out projects
Next Topic:ECP Trigger Validation
Current Time: Sun Nov 09 18:36:20 EST 2025
Powered by FUDForum. Page generated in 0.03196 seconds
