Home » Archived » Eclipse Process Manager (Stardust) » How to use maven dependencies in eclipse stardust dynamic web project?(When I convert the dynamic web project to maven project, it fails to build)
How to use maven dependencies in eclipse stardust dynamic web project? [message #1486433] Mon, 24 November 2014 22:12 Go to next message
I followed the tutorial here to create a stardust web dynamic project and it all works fine.
I converted the project to a Maven project using eclipse m2e plugin and after that the project fails to build. It turns out that stardust standard libraries are not included anymore in the project.
Could you please help and assist to convert the stardust eclipse dynamic web project to a maven project?
Re: How to use maven dependencies in eclipse stardust dynamic web project? [message #1486897 is a reply to message #1486433] Tue, 25 November 2014 06:28 Go to previous messageGo to next message
Hi Melissa,
the easiest way to work with a Stardust maven WAR project on Eclipse WTP is to use the maven Stardust Spring WAR archetype as a basis.
1. generate the maven project using the archetype
2. run maven package to complete all downloads
3. use "import existing maven project" in Eclipse
4. make sure the correct maven profile is enabled in the resulting Eclipse maven project (if applicable)
5. add dependencies on other eclipse (maven) projects as needed to includ custom jars
6. Add maven project to regular WTP server
Does that work for you?
Best regards
Rob
Re: How to use maven dependencies in eclipse stardust dynamic web project? [message #1487835 is a reply to message #1486897] Wed, 26 November 2014 00:24 Go to previous messageGo to next message
Thanks Rob.
I have built this maven archetype before and I noticed that the Rules Management Perspective is missing. So we have to stick with the eclipse war export.
Is there a way to include Rules Management Perspective in this archetype?
[Updated on: Wed, 26 November 2014 00:25] by Moderator
Re: How to use maven dependencies in eclipse stardust dynamic web project? [message #1487848 is a reply to message #1487835] Wed, 26 November 2014 00:39 Go to previous messageGo to next message
Melissa,
please check if adding the dependency
<groupId>org.eclipse.stardust.ui.web</groupId>
<artifactId>stardust-rules-manager</artifactId>
<version>2.0.1</version>
to your archetype result does the trick.
Best regards
Rob
Re: How to use maven dependencies in eclipse stardust dynamic web project? [message #1489997 is a reply to message #1487848] Thu, 27 November 2014 16:38 Go to previous messageGo to next message
Hi Rob,
Thank you. The project now has the rules management perspective.
Melissa
Re: How to use maven dependencies in eclipse stardust dynamic web project? [message #1490253 is a reply to message #1489997] Thu, 27 November 2014 21:48 Go to previous messageGo to next message
I have written the steps I did to build the stardust portal using maven archetype and deploy it to a server.
Generate a new project using mvn archetype:
mvn archetype:generate -DarchetypeGroupId=org.eclipse.stardust.deploy.jee.archetypes -DarchetypeArtifactId=tc7-ipp-portal-war -DarchetypeVersion=2.0.1 -DgroupId=org.eclipse.stardust.test -DartifactId=stardust-portal-war -Dversion=1.0-SNAPSHOT -DarchetypeRepository=http://download.eclipse.org/stardust/maven/releases
Go your project directory and build your project.
mvn clean package
Import project to eclipse.
If you want to replace the location of the jackrabbit repository (default location: c:/tmp/repository) modify the jackrabbit config file (ipp-portal/src/main/webapp/WEB-INF/config/ipp/spring/jackrabbit-jcr-context.xml)
<bean id="carnotJackrabbitRepository" class="org.eclipse.stardust.vfs.jcr.spring.JackrabbitRepositoryStartupBean">
      <property name="jndiName" value="jcr/ContentRepository" />
      <property name="repositoryConfig" value="/WEB-INF/jackrabbit/repository.xml" />
	  <property name="repositoryHome" value="<new jackrabbit repository>" />
   </bean>
Deploy to server and check if the project starts successfully.
However, if you ran into this runtime error during server start up :
Caused by: java.lang.ClassNotFoundException: org.apache.derby.jdbc.ClientXADataSource
	at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1702)
	at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1547)
	at org.springframework.util.ClassUtils.forName(ClassUtils.java:260)
	at org.springframework.beans.factory.support.AbstractBeanDefinition.resolveBeanClass(AbstractBeanDefinition.java:416)
	at org.springframework.beans.factory.support.AbstractBeanFactory.doResolveBeanClass(AbstractBeanFactory.java:1296)
	at org.springframework.beans.factory.support.AbstractBeanFactory.resolveBeanClass(AbstractBeanFactory.java:1267)
	... 42 more
In ipp-portal/src/main/webapp/WEB-INF/config/ipp/spring/carnot-spring-ds-context.xml
Replace
<bean id="carnotXaAuditTrailDataSourceLocalURL" class="org.apache.derby.jdbc.ClientXADataSource" lazy-init="true">
      <property name="serverName" value="localhost" />
      <property name="portNumber" value="1527" />
      <property name="databaseName" value="ipp" />
      <property name="user" value="carnot" />
      <property name="password" value="ag" />
   </bean>
with
<bean id="carnotXaAuditTrailDataSourceLocalURL" class="org.apache.derby.jdbc.EmbeddedXADataSource">
   <property name="databaseName" value="carnot" />
</bean>
If you want to include other dependecies just add it to the pom.xml of your project. Hope this helps.
[Updated on: Thu, 27 November 2014 21:49] by Moderator
Re: How to use maven dependencies in eclipse stardust dynamic web project? [message #1490296 is a reply to message #1490253] Thu, 27 November 2014 22:36 Go to previous message
Thank you for the clear configuration summary, Melissa. We will see how that can be consolidated with the documentation and wiki.
Best regards
Rob
Previous Topic:How to control a manual activity, rendering and input-validation
Next Topic:Data mapping could not be resolved during model deployment
Current Time: Tue Aug 05 19:57:04 EDT 2025
Powered by FUDForum. Page generated in 0.04259 seconds
