Home » Archived » Eclipse Communications Framework (ECF) » Which bundles need to be started to enable remote service discovery?
Which bundles need to be started to enable remote service discovery? [message #1483622] Sat, 22 November 2014 14:59 Go to next message
Hello
I am currently playing with the raspberry pi examples. While I was setting up a product to run an Eclipse including the "Raspberry PI GPIO View" following this tutorial, I got into wondering which bundles I need to configure to auto-start to enable remote service discovery.
Here is my current configuration for the IDE:
<configurations>
  <plugin id="ch.ethz.iks.slp" autoStart="true" startLevel="0" />
  <plugin id="org.eclipse.ecf" autoStart="true" startLevel="0" />
  <plugin id="org.eclipse.ecf.discovery" autoStart="true" startLevel="0" />
  <plugin id="org.eclipse.ecf.osgi.services.distribution" autoStart="true" startLevel="0" />
  <plugin id="org.eclipse.ecf.osgi.services.remoteserviceadmin" autoStart="true" startLevel="0" />
  <plugin id="org.eclipse.ecf.osgi.services.remoteserviceadmin.proxy" autoStart="true" startLevel="0" />
  <plugin id="org.eclipse.ecf.provider" autoStart="true" startLevel="0" />
  <plugin id="org.eclipse.ecf.provider.jslp" autoStart="true" startLevel="0" />
  <plugin id="org.eclipse.ecf.remoteservice" autoStart="true" startLevel="0" />
  <plugin id="org.eclipse.ecf.remoteservice.asyncproxy" autoStart="true" startLevel="0" />
  <plugin id="org.eclipse.ecf.sharedobject" autoStart="true" startLevel="0" />
  <plugin id="org.eclipse.equinox.ds" autoStart="true" startLevel="2" />
  <plugin id="org.eclipse.equinox.event" autoStart="true" startLevel="2" />
  <plugin id="org.eclipse.equinox.simpleconfigurator" autoStart="true" startLevel="1" />
  <plugin id="org.eclipse.osgi" autoStart="true" startLevel="-1" />
  <plugin id="org.eclipse.osgi.services" autoStart="true" startLevel="0" />
  <plugin id="org.eclipse.osgi.services.remoteserviceadmin" autoStart="true" startLevel="0" />
  <plugin id="org.eclipse.osgi.util" autoStart="true" startLevel="0" />
  <plugin id="org.eclipse.update.configurator" autoStart="true" startLevel="3" />
</configurations>
Which of these bundles are absolutely necessary to enable remote service discovery?
Thanks!
Smile
Christoph
[Updated on: Sat, 22 November 2014 15:00] by Moderator
Re: Which bundles need to be started to enable remote service discovery? [message #1483724 is a reply to message #1483622] Sat, 22 November 2014 17:05 Go to previous messageGo to next message
Christoph Keimel wrote on Sat, 22 November 2014 14:59
Hello
<configurations>
</configurations>
Thanks!
Smile
Christoph
Hi Christoph.
In this configuration, SLP discovery is being used, and so the SLP provider must be started. That provider is in bundle: org.eclipse.ecf.provider.jslp
Note that ECF has a provider architecture for discovery and distribution, and if other discovery providers (e.g. zookeeper, jmdns, etc.) are used it will generally be necessary to start the appropriate discover provider. Typically, such provider bundles will have ids of the following form: org.eclipse.ecf.provider.*.
Since you don't appear to be using the Equinox plugin registry, it will also be necessary to explicitly start the distribution provider. It appears that you are missing one of the necessary bundles for the ECF generic provider, however. That bundle is: org.eclipse.ecf.provider.remoteservice. Adding and then starting this bundle will make the ECF generic provider available for runtime export of remote services via the ECF generic provider.
Finally, it's necessary to start the org.eclipse.ecf.osgi.services.distribution bundle as this bundle contains the topology manager specified by the OSGi Remote Service Admin R6 specification (which ECF does implement).
So to summarize, it's generally necessary to start
a) the discovery provider (SLP - org.eclipse.ecf.provider.jslp)
b) the distribution provider (ECF generic - org.eclipse.ecf.provider.remoteserviceadmin)
c) The bundle containing the desired topology manager (org.eclipse.ecf.osgi.services.distribution)
Starting these three things will of course result in the starting of dependent bundles, which would account for most of the bundles in your configuration given above.
In many configurations (e.g. the raspberry pi examples) it's easier to autostart all the bundles, and this is why we generally do autostart all bundles. In the OSGi world..especially server-side...this is frequently what is done anyway (start all bundles).
If you would be interested in more info about the hows and whys, please feel free to ask here, or and/or join the ECF dev mailing list:
https://dev.eclipse.org/mailman/listinfo/ecf-dev
Note one other thing. Wim Jongman who presented a raspberry pi demo at EclipseCon...see here
http://eclipseecf.blogspot.com/2014/11/internet-of-things-and-ecf-remote.html
along with me are in the process of making a few minor changes and additions to the raspberry pi GPIO API and implementation...which will hopefully make it easier to use (for you and others). If you would like to follow and/or comment on or contribute to these changes please see here:
https://github.com/ECF/RaspberryPI/pull/2
Scott
Re: Which bundles need to be started to enable remote service discovery? [message #1484439 is a reply to message #1483724] Sun, 23 November 2014 07:40 Go to previous messageGo to next message
Hi Scott
Thanks for the detailed answer and thanks for the tutorials!
> Since you don't appear to be using the Equinox plugin registry, it will also be necessary to explicitly start > the distribution provider.
Which plug-in do I need to start to enable this?
Will this also hook the discovery provider and the topology manager?
This works great and it helps my understanding of what is going on under the hood. Since I am setting up a client that will only consume services, I skipped (b).
I was there. Great presentation ... got me interessted in this technology!
The reason for my interest in this topic comes from this sentence in your tutorial:
The code for this Eclipse plugin is in the test/bundles/org.eclipse.ecf.raspberrypi.test.gpio.ide project. When run in the Eclipse ide, the empty view (no discovered IGPIOPinOutput services) looks like this
Using "Run As > Eclipse Application" doesn't work in my environment, because the remote service is not discovered. The launch configuration in org.eclipse.ecf.raspberrypi.test.gpio.ide doesn't work for me, because I don't have the product "org.eclipse.sdk.ide" in my installation (Eclipse Luna 4.4.1 Standard + EFC SDK - Java8). If I change this to "org.eclipse.platform.ide" the discovery also doesn't work. So I decided to create product definition based on the launch configuration to further fine control which plugins I need and also to hook into the logging to see whats going on (-Dch.ethz.iks.slp.debug=true ).
From this experience I could contribute the product configuration to start the Pin-Client IDE and document this on the tutorial wiki. Are you interessted in this?
Smile
Christoph
Re: Which bundles need to be started to enable remote service discovery? [message #1484566 is a reply to message #1484439] Sun, 23 November 2014 10:14 Go to previous message
Hi Cristoph,
Great that you could work it out.
For the presentation I have created a server (pipolos) that runs on the pi with the required startup configuration [1].
In addition there is the user interface egg client [2] that will discover the remote services.
The *ide* bundle that Scott created is designed to run in the IDE.
Wim
[1] https://github.com/wimjongman/pipolos/blob/master/README.md
[2] https://github.com/wimjongman/eggclient/blob/master/README.md
Previous Topic:How to setup o.e.ecf.examples.raspberrypi.* on the pi
Next Topic:Type of bootstrapping Architechture in OM2M
Current Time: Sat Sep 13 15:13:39 EDT 2025
Powered by FUDForum. Page generated in 0.03949 seconds
