Home » Eclipse Projects » Eclipse Platform » Which AST parse level should I be using?
Which AST parse level should I be using? [message #268851] Thu, 26 August 2004 11:35 Go to next message
I know that I create a parse with the following code:
ASTParser p = ASTParser.newParser(AST.JLS3);
p.setSource(unit);
CompilationUnit u = (CompilationUnit) p.createAST(null);
This, of course, fails because 1.5 parsing is not yet supported. The
question is, how do I choose the correct parse level? Once 1.5 parsing is
supported, shouldn't there be a setting somewhere that allows me to NOT do
1.5 level compilation? Shouldn't I be getting the current parse level from a
more static location? Has that location already been implemented and I just
haven't found it? Is my code up above totally screwed?
Jim Adams
Re: Which AST parse level should I be using? [message #268855 is a reply to message #268851] Thu, 26 August 2004 11:55 Go to previous messageGo to next message
> p.setSource(unit);
You should use setCompilerOptions(Map options) on the ASTParser.
You can do something like:
ASTParser astParser = ASTParser.newParser(AST.JLS3);
astParser.setSource(unit);
Map options = unit.getJavaProject().getOptions(true);
options.put(JavaCore.COMPILER_SOURCE, JavaCore.VERSION_1_5);
options.put(JavaCore.COMPILER_CODEGEN_TARGET_PLATFORM,
astParser.setCompilerOptions(options);
astParser.setResolveBindings(false);
CompilationUnit u = (CompilationUnit) astParser.createAST(null);
HTH,
Olivier
Re: Which AST parse level should I be using? [message #269030 is a reply to message #268855] Fri, 27 August 2004 11:49 Go to previous messageGo to next message
Does that allow for a fallback to level 2? Or do I really not even need to
do the options.put()? Will I get whatever was set on the project? Isn't that
enough?
"Olivier Thomann" <olivier_thomannNOSPAM@ca.ibm.com> wrote in message
news:cgl101$96j$1@eclipse.org...
> > p.setSource(unit);
is
do
from a
just
> HTH,
> Olivier
Re: Which AST parse level should I be using? [message #269058 is a reply to message #269030] Fri, 27 August 2004 13:47 Go to previous messageGo to next message
The code, as given, does not solve the problem. This still fails with an
exception because Java 1.5 is not supported. I am looking for something that
will allow my code to work even when 1.5 is supported. I have always heard
that you shouldn't use exceptions to handle code flow but it seems that that
is what I am being forced into.
"Jim Adams" <Jim.Adams@sas.com> wrote in message
news:cgnl07$9rj$1@eclipse.org...
that
> enough?
> > > p.setSource(unit);
> is
NOT
> do
> from a
> just
> > HTH,
> > Olivier
Re: Which AST parse level should I be using? [message #269100 is a reply to message #269058] Fri, 27 August 2004 17:58 Go to previous messageGo to next message
Could you please create a bug report against JDT/Core with your test case?
I am assuming that you are using one of the 3.1 integration build,
otherwise it won't work for sure. Most of the 1.5 support is not
included in 3.0.
Olivier
Re: Which AST parse level should I be using? [message #269302 is a reply to message #269100] Mon, 30 August 2004 15:10 Go to previous messageGo to next message
I am NOT using any of the 1.5 support. I don't need the 1.5 support. What I
am trying to do is plan for the future so that, when there IS 1.5 support,
my code doesn't break.
news:cgoako$a3k$1@eclipse.org...
that
heard
that
> included in 3.0.
> Olivier
Re: Which AST parse level should I be using? [message #269304 is a reply to message #269100] Mon, 30 August 2004 15:15 Go to previous message
Bug 72899 was added to address this issue.
that
heard
that
> included in 3.0.
> Olivier
Previous Topic:JBoss-IDE or Lomboz
Next Topic:moving views between folders
Current Time: Wed Nov 05 17:06:38 EST 2025
Powered by FUDForum. Page generated in 0.05868 seconds
