Home » Eclipse Projects » Eclipse Platform » No syntax highlight in Ant Editor for filenames other than build.xml
No syntax highlight in Ant Editor for filenames other than build.xml [message #268593] Wed, 25 August 2004 06:05 Go to next message
Originally posted by: mail.florianstrauch.de
i dont get syntax highlighting in the Ant Editor for files not named
"build.xml".
In my special case i use an antscript named "default.ant" and i allready set
the Ant Editor as assotiated editor for files matching the pattern "*.ant".
The Ant Editor is used for this file (the Ant Outline is shown and working
correctly, Code Assist is also working) but there is no Syntax Highlighting.
Syntax Highlighting is working with ant files named "build.xml" though.
Florian
Re: No syntax highlight in Ant Editor for filenames other than build.xml [message #268697 is a reply to message #268593] Wed, 25 August 2004 12:07 Go to previous message
Thanks Florian.
I have logged this as
https://bugs.eclipse.org/bugs/show_bug.cgi?id=72598
Other extensions I have tried worked fine.
It is some interaction with the file being name "*.ant"
Darins
"FStrauch" <mail@florianstrauch.de> wrote in message
news:cghnpl$pvd$1@eclipse.org...
> "build.xml".
set
"*.ant".
Highlighting.
> Florian
Previous Topic:ANT Builder and imported files
Next Topic:Specifying a classpath in a jardesc file
Current Time: Wed Nov 05 17:00:29 EST 2025
Powered by FUDForum. Page generated in 0.02749 seconds
