Home » Eclipse Projects » Nebula » Implementing rowNumber in CompositeTable
Implementing rowNumber in CompositeTable [message #26604] Sun, 04 February 2007 00:13 Go to next message
Hi Dave,
I tried to implement row numbers in CompositeTable as follows:
1. Use a label as the first child of my row composite.
2. In the refresh method, set the row number as follows:
public void refresh(CompositeTable sender, int currentObjectOffset,
Control rowControl) {
Row row = (Row) rowControl;
row.rowNumber.setText("" + (currentObjectOffset+1));
3. In the deleteRow method of IDeleteHandler(), add table.refreshAllRows()
at the end.
The problem is that deleteRow is called before deletion actually takes
place. So row numbers are one bigger after the deletion position.
If refreshAllRows() is added after line 1197 of InternalCompositeTable
(line 1197 reads internalSetSelection(currentColumn, currentRow, true);),
then row numbers are working fine and step 3 above is not necessary.
Is there a better way to display row numbers? Any potential problems over
the above change in InternalCompositeTable?
John
Re: Implementing rowNumber in CompositeTable [message #26693 is a reply to message #26604] Mon, 05 February 2007 12:55 Go to previous message
I just added
public void rowDeleted(int rowInCollection);
which is called after the delete operation completes to IDeleteHandler.
Thanks for your feedback!
Dave
John Ye wrote:
> Hi Dave,
> table.refreshAllRows() at the end.
> true);), then row numbers are working fine and step 3 above is not
> necessary.
> over the above change in InternalCompositeTable?
> John
Senior Consultant, Trainer
Coconut Palm Software, Inc.
http://www.coconut-palm-software.com
Re: Implementing rowNumber in CompositeTable [message #577339 is a reply to message #26604] Mon, 05 February 2007 12:55 Go to previous message
I just added
Dave
John Ye wrote:
> Hi Dave,
> necessary.
> John
Previous Topic:Grid item updates
Next Topic:[CompositeTable] 0.9.2.1 released
Current Time: Wed Nov 05 15:03:57 EST 2025
Powered by FUDForum. Page generated in 0.03351 seconds
