Home » Eclipse Projects » Eclipse Platform » [RCP] Internationalizing Plugins - about.ini etc
[RCP] Internationalizing Plugins - about.ini etc [message #268311] Mon, 23 August 2004 16:59 Go to next message
Can about.ini be internationalized? I've created translated files such as..
about_es_ES.properties
about_en_US.properties
...but strings do not seem to be recognized unless they are in
a regular about.properties.
Preston
Re: [RCP] Internationalizing Plugins - about.ini etc [message #268320 is a reply to message #268311] Mon, 23 August 2004 18:02 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
For specific settings in the about.ini it will look in the
about.properties for entries that start with %, for example:
# Property "aboutText" contains blurb for "About" dialog (translated)
aboutText=%featureText
It will look for "featureText" in the about.properties file and use that.
Thanks, Rich Kulp
Re: [RCP] Internationalizing Plugins - about.ini etc [message #268326 is a reply to message #268320] Mon, 23 August 2004 18:43 Go to previous messageGo to next message
Rich,
Yes, but what if I have locale-specific blurbs? My translated externalized
strings don't show up even though I've followed the
<base>_<lang>_<country>.properties standard. For example, if I create an
about_es_ES.properties for Spanish-speaking people in Spain, I would think
a %blurb would be read from it if my LANG variable is es_ES. My issue is
that I can't get a locale-specific about.properties file to work;
externalization works fine if I have a single about.properties.
Preston
Re: [RCP] Internationalizing Plugins - about.ini etc [message #268430 is a reply to message #268326] Tue, 24 August 2004 12:02 Go to previous messageGo to next message
I don't know. It works for us. The only blurb we have in the about.ini
is aboutText, so we have:
about.ini:
about.text=%featureText
and in about.properties
featureText=The text to show for feature text.
I don't know what your LANG variable is, but it will load it from
whatever the current locale for your machine is or from the -nl override
option on eclipse.exe
Thanks, Rich Kulp
Re: [RCP] Internationalizing Plugins - about.ini etc [message #268504 is a reply to message #268326] Tue, 24 August 2004 22:41 Go to previous messageGo to next message
Originally posted by: manahan.NOSPAM.ca.ibm.com
You can try putting in a locale directory
plugins/yourplugin_1.0.0/nl/de/DE/about.properties
That seems to work for me.
Peter
Preston Lee wrote:
> Rich,
> Preston
Re: [RCP] Internationalizing Plugins - about.ini etc [message #268891 is a reply to message #268504] Thu, 26 August 2004 13:41 Go to previous message
Originally posted by: nick_edgar._no.spam.please_.ca.ibm.com
Correct. The about.properties file is resolved using:
Platform.find(bundle, new Path(NLS_TAG).append(propertiesFilename));
where NLS_TAG is "$nl$".
For example, in the en_CA locale, this gets expanded to nl/en/CA.
For more details, see the Javadoc for Platform.find(Bundle, IPath, Map).
See also
http://help.eclipse.org/help30/topic/org.eclipse.platform.do c.isv/guide/product_def_nl.htm
Nick
"Peter Manahan" <manahan@NOSPAM.ca.ibm.com> wrote in message
news:cggu3u$jvd$1@eclipse.org...
> Peter
> Preston Lee wrote:
> > Rich,
externalized
think
> > Preston
that.
Previous Topic:BundleException
Next Topic:How does Eclipse compile files when JRE is configured withing IDE?
Current Time: Wed Oct 29 04:36:41 EDT 2025
Powered by FUDForum. Page generated in 0.05104 seconds
