Re: I can not deploy models that include a Rule Task [message #1481584 is a reply to message #1481553] |
Fri, 21 November 2014 04:37 |
Dan,
I started a discussion regarding this yesterday. So far the results are:
- Drools was only available under the LGPL license which is not compatible with the Eclipse Public License (EPL). We had to remove the rools runtime artifacts from Stardust because they can only be compiled with drools dependencies. (The modeler's Rules Overlay and Rules Perspective in the portal do not depend on Drools therefore we kept them in, hoping to document a solution for the runtime)
- To make use of the feature now you require the ipp-engine-rules artifact/project which is currently not open-sourced. I am discussing if we could do so on short notice, possibly under a different license on GitHub. I am also checking other alternatives to make this usable for you before we have a long term solution in place. For instance we need to clarify if the current code can compile against the Drools version which is available under Apache 2.0 or if we would have to migrate to that version first.
- Now Drools is available under the Apache 2.0 license. This opens the door for open-sourcing the full feature under EPL with Stardust. We are looking into this. If we can do so then CQs have to be filed and approved by Eclipse legal first. I am afraid this sometimes takes time.
- The earlier Rules Set Invocation Application was deprecated earlier and we removed support in IPP 8.1. The change will make it into Stardust with the February Luna SR2 release.
I will get back to you with the result of the discussion.
Best regards
Rob
FUDForum. Page generated in 0.06646 seconds
