| Can't discover UML model from KDM model: exception [message #1479577] |
Wed, 19 November 2014 09:54  |
I have discovered a KDM model from my Android project. This works. But discovering an UML model from this is not possible. I get following error message:
Cannot set feature uml!InterfaceRealization.contract to value org.eclipse.emf.ecore.impl.DynamicEObjectImpl@549e7f73 (eClass: org.eclipse.emf.ecore.impl.EClassImpl@13d2db93 (name: Class) (instanceClassName: null) (abstract: false, interface: false)) (org.eclipse.modisco.kdm.uml2converter_0.12.1.201408191633)
Exception Stack Trace:
org.eclipse.m2m.atl.engine.vm.VMException: Cannot set feature uml!InterfaceRealization.contract to value org.eclipse.emf.ecore.impl.DynamicEObjectImpl@549e7f73 (eClass: org.eclipse.emf.ecore.impl.EClassImpl@13d2db93 (name: Class) (instanceClassName: null) (abstract: false, interface: false))
at A.__applyImplementsToInterfaceRealization(1 : NTransientLink;) : ??#26(KDMtoUML.atl[541:3-541:89])
local variables = {tgt=umlOutput!<notnamedyet>, src=kdmInput!<unnamed>, link=TransientLink {rule = 'ImplementsToInterfaceRealization', sourceElements = {src = kdmInput!<unnamed>}, targetElements = {tgt = umlOutput!<notnamedyet>}, variables = {}}, self=KDMtoUML : ASMModule}
local stack = [umlOutput!<notnamedyet>]
Java Stack:
at org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModelElement.set(ASMEMFModelElement.java:513)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOperation.java:323)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.exec(ASMOperation.java:173)
at org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASMOclAny.java:130)
at org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASMOclAny.java:78)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOperation.java:251)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOperation.java:357)
at org.eclipse.m2m.atl.engine.vm.ASMInterpreter.<init>(ASMInterpreter.java:346)
at org.eclipse.m2m.atl.engine.vm.AtlLauncher.launch(AtlLauncher.java:216)
at org.eclipse.m2m.atl.engine.vm.AtlLauncher.launch(AtlLauncher.java:127)
at org.eclipse.m2m.atl.engine.vm.AtlLauncher.launch(AtlLauncher.java:92)
at org.eclipse.modisco.util.atl.core.internal.AtlLaunchHelper.runTransformation(AtlLaunchHelper.java:194)
at org.eclipse.modisco.util.atl.core.internal.AtlLaunchHelper.runTransformation(AtlLaunchHelper.java:173)
at org.eclipse.modisco.kdm.uml2converter.internal.KdmToUmlConverter.getUML2ModelFromKDMModelWithCustomTransformation(KdmToUmlConverter.java:115)
at org.eclipse.modisco.kdm.uml2converter.internal.KdmToUmlConverter.getUML2ModelFromKDMModel(KdmToUmlConverter.java:80)
at org.eclipse.modisco.kdm.uml2converter.DiscoverUmlModelFromKdmModel.basicDiscoverElement(DiscoverUmlModelFromKdmModel.java:89)
at org.eclipse.modisco.kdm.uml2converter.DiscoverUmlModelFromKdmModel.basicDiscoverElement(DiscoverUmlModelFromKdmModel.java:1)
at org.eclipse.modisco.infra.discovery.core.AbstractDiscoverer.discoverElement(AbstractDiscoverer.java:93)
at org.eclipse.modisco.infra.discovery.core.AbstractModelDiscoverer.discoverElement(AbstractModelDiscoverer.java:183)
at org.eclipse.modisco.infra.discovery.ui.internal.actions.MoDiscoMenuSelectionListener.discovererElement(MoDiscoMenuSelectionListener.java:229)
at org.eclipse.modisco.infra.discovery.ui.internal.actions.MoDiscoMenuSelectionListener$1.run(MoDiscoMenuSelectionListener.java:168)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Caused by: java.lang.ClassCastException: The value of type 'org.eclipse.emf.ecore.impl.EClassImpl@13d2db93 (name: Class) (instanceClassName: null) (abstract: false, interface: false)' must be of type 'org.eclipse.emf.ecore.impl.EClassImpl@25554c2a (name: Interface) (instanceClassName: null) (abstract: false, interface: false)'
at org.eclipse.emf.ecore.impl.EStructuralFeatureImpl$InternalSettingDelegateSingleEObject.dynamicSet(EStructuralFeatureImpl.java:2653)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDynamicSet(BasicEObjectImpl.java:1127)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjectImpl.java:1101)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjectImpl.java:1071)
at org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModelElement.set(ASMEMFModelElement.java:510)
... 26 more
What is the problem?
Many thanks in advance!
| Re: Can't discover UML model from KDM model: exception [message #1480989 is a reply to message #1480920] |
Thu, 20 November 2014 12:09  |
Maybe you could do a quick test with Kepler, or just rebuild your own version of the plugin from the sources (cf. the initial link I sent you).
Concerning the size of the produced Java model, I was referring to the size of the corresponding XMI file. Anyway, if your project is rather small then it should not be so big I guess.
Could you check that you don't have a log file located at the same path than the input Java model?
FUDForum. Page generated in 0.05102 seconds
