Re: [xcore] creating an instance of Map.Entry [message #1478410 is a reply to message #1478395] |
Tue, 18 November 2014 17:06 |
Ed Merks Messages: 33218 Registered: July 2009 |
Joel,
Comments below.
On 18/11/2014 5:50 PM, Joel Greenyer wrote:
> Hi all,
> in my Xcore model I defined a map entry class.
> class MyMapEntry wraps java.util.Map.Entry {
> refers ...
> refers ...
> with the primary purpose to build a "qualified association" (EMap).
> In an operation, I implement an algorithm where would now also like to
> manually create instances of MyMapEntry.
That's easier said than done as you noticed. So first question is, why
do you need to create an entry directly?
> However,
> 1. MyFactory does not exhibit a "createMyMapEntry" method. So I can't
> create an instance that way.
No, because there is no generated API for such things.
> 2. I can't say "new MyMapEntryImpl" -- it says that the constructor is
> not visible.
Indeed.
> What seems to work is the following: MyFactoryImpl has a method
> "createMyMapEntry". So, I can say
> (MyFactory,eINSTANCE as MyFactoryImpl).createMyMapEntry
> My question is now: Is there a better way?
MyFactory.eINSTANCE.create(MyPackage.Literals.MY_MAP_ENTRY). You can
cast the result to org.eclipse.emf.common.util.BasicEMap.Entry<K, V>.
> A cleaner way would probably be to create an additional class
> MyMapEntry2 without "wraps java.util.Map.Entry", which I can use for
> my purposes in the algorithm...
Perhaps you can write your algorithm such that you create entries via
"put"....
> Best regards
> Joel
Ed Merks
FUDForum. Page generated in 0.04154 seconds
