warnings in example project [message #26495] |
Thu, 12 July 2007 21:49 |
Originally posted by: axelDOTazertyA.TlaposteDO.Tnet
Using Eclipse Europa (Windows XP, with Sun JDK 6 update 1), I m
following the example in Ibm Developer Works website, I get the
following 4 warnings (during automatic compilation, I guess) juste
after the creation of the project.
HashMap is a raw type. References to generic type HashMap<K,V> should
be parameterized Transformation/jet2java/org/eclipse/jet/compiled
_jet_transformation.java line 70
Map is a raw type. References to generic type Map<K,V> should be
_jet_transformation.java line 48 1184238926390 13
no valid properties files exist in the localization directory
specified Transformation/META-INF MANIFEST.MF line 6 1184238926671 16
Type safety: The method put(Object, Object) belongs to the raw type Map.
References to generic type Map<K,V> should be parameterized
_jet_transformation.java line 65 1184238926390 14
Maybe these are known bugs (or maybe even not bug at all )...
Re: warnings in example project [message #26946 is a reply to message #26495] |
Tue, 17 July 2007 14:00 |
Paul Elder Messages: 849 Registered: July 2009 |
Axel:
JET generates code that is compatible with Java 2 (ie. Java 1.4), so it does
not use Java generics. Java 5 & 6 issue warnings about this. One possibility
it to change Execution environment of the JET plug-in to J2SE-1.4. The steps
to do this:
1) Open plugin.xml or META-INF/MANIFEST.MF in the 'Plug-in Manifest Editor'
2) On the General tab, click the 'Add' button in the Execution Environment
area
3) Select 'J2SE-1.4', and click OK.
4) Click the 'Update the classpath settings' link (which has the side effect
of saving).
This should get ride of all the warnings but the one in MANIFEST.MF. To
eliminate that, you'd either have to remove the Bundle-Localization header
from MANIFEST.MF, or create a plugin.properties file.
I have created bug 196814
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=196814) that proposes an
enhancement that would eliminate these warnings.
Paul
"Axel" <axelDOTazertyA@TlaposteDO.Tnet> wrote in message
news:f767l6$bf3$1@build.eclipse.org...
> following 4 warnings (during automatic compilation, I guess) juste after
> Regards
FUDForum. Page generated in 0.03748 seconds
