Home » Modeling » EMF » Org.xml.sax.SAXException when saving resource(Problem only in RCP application/declarative service)
Re: Org.xml.sax.SAXException when saving resource [message #1471964 is a reply to message #1471931] |
Thu, 13 November 2014 13:39 |
Ed Merks Messages: 33141 Registered: July 2009 |
Thomas,
Comments below.
On 13/11/2014 2:06 PM, Thomas Elskens wrote:
> Hello,
> I'm new to EMF and still studying the basics.
> When I try to save a a resource to an xmi-file in a "normal" plugin,
> this works fine.
> However, when I try to do the same in a declarative OSGi-service
> inside an e4-application, the file remains empty and Eclipse throws an
> SAXException, with following stack :
> Quote:
>> !STACK 0
>> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException:
>> org.xml.sax.SAXParseExceptionpublicId:
>> platform:/plugin/be.groups.test.EMFEdit.modelservice/ressources/employer_resource.xmi;
>> systemId:
>> lineNumber: 1; columnNumber: 1; Premature end of file.
So you're loading from platform:/plugin... Is that correct/intended?
>> at
>> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:319)
>> at
>> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:278)
>> at
>> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:406)
>> at internal.ModelServiceImpl.<init>(ModelServiceImpl.java:44)
>> at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native
>> Method)
>> at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown
>> Source)
>> at
>> sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown
>> Source)
>> at java.lang.reflect.Constructor.newInstance(Unknown Source)
>> at java.lang.Class.newInstance(Unknown Source)
>> at
>> org.eclipse.equinox.internal.ds.model.ServiceComponent.createInstance(ServiceComponent.java:493)
>> at com.sun.glass.ui.InvokeLaterDispatcher$Future.run(Unknown Source)
>> at com.sun.glass.ui.win.WinApplication._runLoop(Native Method)
>> at com.sun.glass.ui.win.WinApplication.lambda$null$141(Unknown
>> Source)
>> at
>> com.sun.glass.ui.win.WinApplication$$Lambda$38/1581147548.run(Unknown
>> Source)
>> at java.lang.Thread.run(Unknown Source)
>> Caused by: org.xml.sax.SAXParseExceptionpublicId:
>> systemId:
>> at
>> com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.createSAXParseException(Unknown
>> Source)
>> at
>> com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.fatalError(Unknown
>> Source)
>> at
>> com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(Unknown
>> Source)
>> at
>> Source)
>> at
>> com.sun.org.apache.xerces.internal.impl.XMLScanner.reportFatalError(Unknown
>> Source)
>> at
>> com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$PrologDriver.next(Unknown
>> Source)
>> at
>> com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown
>> Source)
>> at
>> com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown
>> Source)
>> at
>> com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown
>> Source)
>> at
>> Source)
>> at
>> com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown
>> Source)
>> at
>> com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown
>> Source)
>> at
>> com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown
>> Source)
>> at
>> com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(Unknown
>> Source)
>> at
>> org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:175)
>> at
>> org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:261)
>> at
>> org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1518)
>> at
>> org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1297)
>> at
>> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
>> at
>> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
>> ... 78 more
> My code is as follows :
> public class ModelServiceImpl implements IModelService
> private ComposedAdapterFactory factory = new
> ComposedAdapterFactory(ComposedAdapterFactory.Descriptor.Registry.INSTANCE)
> private EditingDomain domain = new
> AdapterFactoryEditingDomain(factory, new BasicCommandStack()) ;
> private ResourceSet rs = domain.getResourceSet() ; private
> Resource resource =
> rs.createResource(URI.createURI("ressources/employer_resource.xmi")) ;
This URI looks suspicious as well. Where are you expecting this to be
saved? Generally I'd expect URI.createPlatformResourceURI (with the
full path in the workspace) or URI.createFileURI (with the absolute file
system path) to be used.
> public ModelServiceImpl()
> Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().put(Resource.Factory.Registry.DEFAULT_EXTENSION,
> new XMIResourceFactoryImpl()) ;
Doesn't ever modify the global registry in an Eclipse application;
that's only something you'd do in a stand alone program where you don't
need to interact with anyone else. And even then, in this case you
have a resource set, so you can register factories in the resource set's
local registry.
> populateResource() ;
> resource.getContents().forEach(System.out::println);
> try
> resource.save(Collections.EMPTY_MAP); }
> catch (IOException e)
> e.printStackTrace();
> private void populateResource()
> EmployerFactory factory = EmployerFactory.eINSTANCE ;
> Portefeuille p = factory.createPortefeuille() ;
> resource.getContents().add(p) ;
> Any idea why this isn't working in a declarative service... ?
Above you show code that does a save, but in the stack trace earlier
you're doing a load (from an apparently empty file)... I can't say how
the two are related. Is the resource you're saving gove included in the
binary bundle from which you are trying to load it in that earlier stack
trace?
> Thomas
Ed Merks
Re: Org.xml.sax.SAXException when saving resource [message #1473059 is a reply to message #1471964] |
Fri, 14 November 2014 09:57 |
Thomas Elskens Messages: 159 Registered: September 2014 Location: Brussels - Belgium |
My explanation about the error was indeed a bit confused : I got it in two cases :
- when using getResource instead of createResource
- when trying to open the (empty) file with the Ecore Editor
About the URI : createURI("resources/employer_resource.xmi") yields the same result as createFileURI("be.groups.test.EMFEdit.modelservice/ressources/employer_resource.xmi"), i.e. an empty file. URI.createPlatformPluginURI("be.groups.test.EMFEdit.modelservice/ressources/employer_resource.xmi") throws an java.net.UnknownServiceException (protocol doesn't support output). Ressources is a map located at the pluginroot (just as in my original plugintest).
I've changed the registry to resourceSet.getResourceFactoryRegistry(), without result.
To make sure, I've done a copy paste of my plugin project (where the resource saving works) in a class of the e4-application, which gives the following code :
public class Debugging
public Debugging()
EditingDomain domain = new AdapterFactoryEditingDomain(new ComposedAdapterFactory(ComposedAdapterFactory.Descriptor.Registry.INSTANCE), new BasicCommandStack());
Resource.Factory.Registry registry = domain.getResourceSet().getResourceFactoryRegistry() ;
registry.getExtensionToFactoryMap().put("testmodel", new XMIResourceFactoryImpl()) ;
Resource resource = domain.getResourceSet().createResource(URI.createURI("ressources/test.testmodel")) ;
Employer emp = factory.createEmployer() ;
Employer emp1 = factory.createEmployer() ;
p.getClients().add(emp) ;
p.getClients().add(emp1) ;
emp.setDenomination("KartoffelFabrik");
emp.setId(23700);
emp.setLocalite("Eupen");
emp.setNoTva("blablabla");
emp.setAdresse("KurFurstenDam 61");
emp1.setDenomination("Au paradis des oignons");
p.setId(50000);
try
resource.save(null);
There are only two minor differences:
- the code here is invoked in a constructor, and in the plugin project, in a public-static-void-main(String[] args)-method
- as suggested, the default registry is no longer used
Hence I'm truly wondering if there is some configuration I should do, some options I should provide to factory and/or registry, to make the saving work ?
Thomas
Re: Org.xml.sax.SAXException when saving resource [message #1473086 is a reply to message #1473059] |
Fri, 14 November 2014 10:23 |
Thomas,
Comments below
On 14/11/2014 10:57 AM, Thomas Elskens wrote:
> Hello,
> two cases :
Demand loading instead of creating a fresh new resource...
An empty file is not well formed XML; all XML parses will barf...
> the same result as
> i.e. an empty file.
URI's don't yield anything... The refer to resources and that reference
is interpreted by the URI converter to interact with the resource.
> output).
So again I'm getting confused of whether you're talking about reading or
writing. Clearly you should not be trying to write into your running
bundle...
> plugintest).
A Map?
> without result.
That's more an issue of corrupting the globally used registry with your
local needs than about whether you'll see the behavior you want.
> public Debugging()
> Resource resource =
Again with this relative URI. It's relative to what? In what content
are you running? Don't use relative URIs for resources.
> emp.setId(23700);
> p.setId(50000);
> try
> resource.save(null); }
Yes, that's a major concern with you relative URIs. What do they mean?
Use an absolute URI (one with a schema) and if the scheme is file: make
sure the file system path itself is absolute as well. Until you get the
right, you will not get good results.
> saving work ?
No, you should be very clear on what your URI denotes. Unless you make
it absolute, it's just not going to give you consistent results in
different scenarios. So again, platform:/resource is used to
accessing the workspace, file:/ is used for accessing the file system,
and platform:/plugin is used to accessing resources in the running
bundle (but don't expect to be able to write to that, only to read from it).
> Thomas
Ed Merks
Re: Org.xml.sax.SAXException when saving resource [message #1473419 is a reply to message #1473307] |
Fri, 14 November 2014 16:09 |
Thomas,
Comments below.
On 14/11/2014 3:13 PM, Thomas Elskens wrote:
> Thanks for the information. Finally it works. Maybe useful information
> for others who are used to Eclipse URL's:
> As suggested, put the resource file in a separate plugin.
> And then I got it to work with the following code :
> URI uri = URI.createPlatformPluginURI(bundle_symbolic_name, false) ;
> // or true, doesn't seem to matter
> uri = uri.appendSegments(new String[] {name_of_folder,name_of_file}) ;
> resource =
> domain.getResourceSet().createResource(CommonPlugin.resolve(uri)) ;
That will likely unjar a jarred bundle, but what's not clear is why you
are trying save to a bundle. That's like trying to update a .class file
in a jar of a running program. It's just not proper design. You ought
not to save state in this way...
> Thanks a lot for the hints !
You never did explain what you're trying to accomplish, but what I see
above seems very odd to me...
> Thomas
Ed Merks
Current Time: Fri Apr 26 06:30:33 GMT 2024
Powered by FUDForum. Page generated in 0.04208 seconds
