Home » Eclipse Projects » Eclipse Platform » ANT Builder and imported files
ANT Builder and imported files [message #265213] Tue, 03 August 2004 07:25 Go to next message
Originally posted by: dcorbin.machturtle.com
The Ant editor/builder seems to create errors if I open a "fragment" of a
build file, such as one that might be imported into the main file (even if
the fragment is OK other than not being a full file).
Worse, once those errors show up in the Problems view, I can find no way to
get rid of them. Is there some way that I've missed?
David Corbin
Re: ANT Builder and imported files [message #265274 is a reply to message #265213] Tue, 03 August 2004 14:36 Go to previous messageGo to next message
Which version of Eclipse are you using?
In the final 3.0 if a fragment does not contain a top level project element
it will not have problems added to the problems view.
Now are you using <import> or using the entity includes for adding the
fragments in your buildfile?
Of course with the <import> these need to be full fledged build files so is
that what is causing you the trouble?
What is an example of a problem you are getting?
There was some builds prior to 3.0 that would generate errors for
"fragments" as this support was in development.
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=60067
To clean up these markers, the easiest thing I know is to comment out the
entire source and then save the "fragment"
Uncomment and resave and the problems should be gone.
HTH
Darins
"David Corbin" <dcorbin@machturtle.com> wrote in message
news:ceo04h$902$1@eclipse.org...
to
> David Corbin
Re: ANT Builder and imported files [message #265308 is a reply to message #265274] Tue, 03 August 2004 19:36 Go to previous messageGo to next message
I'm definately using 3.0 final release.
> element it will not have problems added to the problems view.
Although I didn't think it had a top level project, it does have one
(without the normal requried attributes).
Definatley <import>.
> is that what is causing you the trouble?
Probably. I suppose I can add the project attributes to the imported file,
even though it's not designed to be used directly.
"No default target specified", "Target foo does not exist in this project".
"Default target list does not exist in this project".
As mentioned above, the import file is not designed to be used alone. It
references targets that are supposed to be define by the importing file.
> HTH
> Darins
David
Re: ANT Builder and imported files [message #265320 is a reply to message #265308] Wed, 04 August 2004 01:14 Go to previous messageGo to next message
Thanks for reporting back.
I was not expecting people to use <import> buildfiles that way but why not
So I have entered https://bugs.eclipse.org/bugs/show_bug.cgi?id=71347
so we can track an enhancement to match how you work
Darins
news:cepaus$i4e$1@eclipse.org...
file,
project".
> > HTH
> > Darins
> David
Re: ANT Builder properties undefined during import [message #268415 is a reply to message #265320] Tue, 24 August 2004 10:39 Go to previous messageGo to next message
I am using the import in a similar way as the original post, except that
I am using a ${VARIABLE} reference to locate the imported file. Things
work correctly when using Ant stand-alone. However, within Eclipse, I
cannot locate a way to tell it how to resolve the variable. It fails in
both the Ant editor and the External Tools.
I've tried:
* setting the variable in Window->Preferences->Ant->Runtime->Properties
* setting the variable in my external environment
The following is a simple example of what I am doing. The build.xml file
is in a separate directory from the included file. When I edit this
within Eclipse it acts like the first runtime case where ${INCLUDES} was
not defined. I am looking for a way within Eclipse to get ${INCLUDES}
defined so it understands what is happening like in the last execution
below in the stand-alone case.
$ pwd
/cygdrive/c/tmp
$ more foo/build.xml bar/included.xml
foo/build.xml
<project name="main" default="all">
<import file="${INCLUDES}/included.xml"/>
</project>
bar/included.xml
<project name="included">
<target name="all">
<echo>Hello World</echo>
</target>
</project>
$ ant -f foo/build.xml ### This fails as expected ###
Buildfile: foo\build.xml
BUILD FAILED
C:\tmp\foo\build.xml:2: Cannot find ${INCLUDES}/included.xml imported
from C:\tmp\foo\build.xml
Total time: 0 seconds
$ ant -f foo/build.xml -DINCLUDES=c:/tmp/bar ### How do I get
### Eclipse/Ant
### to work like this?
all:
[echo] Hello World
BUILD SUCCESSFUL
> Thanks
> Darins
> file,
> project".
>>>HTH
>>>Darins
>>David
Re: ANT Builder properties undefined during import [message #268428 is a reply to message #268415] Tue, 24 August 2004 12:47 Go to previous messageGo to next message
It should work setting the property in
and I can get a successful build with this setup but the property appears to
not be applied when parsing so this result in errors in the editor.
To specify "-DINCLUDES=c:/tmp/bar"
go to the Main tab of your Ant launch configuration and place this argument
in the Arguments pane.
I had success using this for a successful build as well.
For the errors in the Ant Editor, I have logged
https://bugs.eclipse.org/bugs/show_bug.cgi?id=72512
Darins
"Jim Stafford" <jcstaff@apl.jhu.edu> wrote in message
news:cgfjp3$j2d$1@eclipse.org...
> I've tried:
> $ pwd
> /cygdrive/c/tmp
> foo/build.xml
> </project>
> bar/included.xml
> <target name="all">
> </target>
> </project>
> BUILD FAILED
> ### Eclipse/Ant
> all:
> [echo] Hello World
> BUILD SUCCESSFUL
not
> > Thanks
> > Darins
so
> > file,
> > project".
It
> >>>HTH
> >>>Darins
> >>David
Re: ANT Builder properties undefined during import [message #268465 is a reply to message #268428] Tue, 24 August 2004 13:57 Go to previous messageGo to next message
Thanks for the confidence to continue in the face of failure. I was able
to get a few things working and a few other things still seem to be
broken as originally reported.
Setting the Window->Preferences->Ant->Runtime->Properties value for
${VARIABLE} did seem to allow the Ant Build to _run_ correctly. Choosing
the Outline->"project name"->Run->Ant Build automatically built and ran
an external tools "Ant Build" configuration (nice!) and ran successfully.
However, the Ant build file editor and external tools configuration
editor still think that my buildfile is in error.
* The Ant build file editor does not locate the imported file and
appears to not use the defined property the same way the runtime did.
* The external tools editor won't let me run the build file from there
because it says one of my custom tasks is undefined. It is defined at
runtime. The problem just seems to be at editing time.
I think I may be able to resolve the second problem by hand registering
the tasks within Eclipse; even though this is a pain since my included
build files encapsulate this. However, I have less confidence in getting
the Ant build file editor to expand the ${VARIABLE} reference during the
import outside of runtime.
> Thanks
> Darins
>>I've tried:
>>$ pwd
>>/cygdrive/c/tmp
>>foo/build.xml
>></project>
>>bar/included.xml
>> <target name="all">
>> </target>
>></project>
>>BUILD FAILED
>> ### Eclipse/Ant
>>all:
>> [echo] Hello World
>>BUILD SUCCESSFUL
> not
>>>Thanks
>>>Darins
> so
>>>file,
>>>project".
> It
>>>>>HTH
>>>>>Darins
>>>>David
Re: ANT Builder properties undefined during import [message #268467 is a reply to message #268465] Tue, 24 August 2004 14:07 Go to previous messageGo to next message
news:cgfvd2$8cb$1@eclipse.org...
I will work on fixing this up shortly via bug 72512. I do not believe there
is anything you as a user could do to fix this...but I'd be happy if you
proved me wrong :-)
So your tasks are defined in the imported file?
appears to
argument
> > Thanks
> > Darins
> >>I've tried:
> >>$ pwd
> >>/cygdrive/c/tmp
> >>foo/build.xml
> >></project>
> >>bar/included.xml
> >> <target name="all">
> >> </target>
> >></project>
> >>BUILD FAILED
> >> ### Eclipse/Ant
> >>all:
> >> [echo] Hello World
> >>BUILD SUCCESSFUL
> > not
> >>>Thanks
> >>>Darins
the
> > so
> >>>file,
> >>>project".
> > It
file.
> >>>>>HTH
> >>>>>Darins
> >>>>David
Re: ANT Builder properties undefined during import [message #268471 is a reply to message #268467] Tue, 24 August 2004 14:27 Go to previous messageGo to next message
Okay, I'll relax on the editor.
Yes. I have custom tasks defined within the imported file. My main
build.xml files are extremely sparse.
<project name="corebuild_properties">
<taskdef resource="net/sf/antcontrib/antcontrib.properties"/>
<osfamily property="osFamily"/>
Any insight as to how I can get Eclipse better configured to recognize
the custom tasks would be appreciated. Right now, I have osfamily
defined under Window->preferences->Ant->Runtime->Tasks, but comes up
undefined on the external tools editor.
Although it does run under the external tools run button and Outline,
I've just started playing with the Ant view where I can seach and
execute various build.xml files. In this view, the executation fails
because osfamiliy could not be instantiated.
Still plugging away...
> proved me wrong :-)
> appears to
> argument
>>>Thanks
>>>Darins
>>>>I've tried:
>>>>$ pwd
>>>>/cygdrive/c/tmp
>>>>foo/build.xml
>>>></project>
>>>>bar/included.xml
>>>> <target name="all">
>>>> </target>
>>>></project>
>>>>BUILD FAILED
>>>> ### Eclipse/Ant
>>>>all:
>>>> [echo] Hello World
>>>>BUILD SUCCESSFUL
>>>not
>>>>>Thanks
>>>>>Darins
> the
>>>so
>>>>>file,
>>>>>project".
>>>It
> file.
>>>>>>>HTH
>>>>>>>Darins
>>>>>>David
Re: ANT Builder properties undefined during import [message #268474 is a reply to message #268471] Tue, 24 August 2004 14:31 Go to previous messageGo to next message
You have hit the same problem as:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=68373
As indicated in that bug report you can turn off the "incomplete classpath"
errors for the editor as another workaround.
If you have the time to add your details to the bug report, that would be
great. If you don't get to it...I will eventually :-)
Thanks for your help in diagnosing the problem
Darins
news:cgg13u$bbj$1@eclipse.org...
successfully.
there
> > proved me wrong :-)
> > appears to
> > argument
> >>>Thanks
> >>>Darins
that
in
> >>>>I've tried:
file
was
> >>>>$ pwd
> >>>>/cygdrive/c/tmp
> >>>>foo/build.xml
> >>>></project>
> >>>>bar/included.xml
> >>>> <target name="all">
> >>>> </target>
> >>>></project>
> >>>>BUILD FAILED
> >>>> ### Eclipse/Ant
> >>>>all:
> >>>> [echo] Hello World
> >>>>BUILD SUCCESSFUL
why
> >>>not
> >>>>>Thanks
> >>>>>Darins
> > the
files
> >>>so
imported
> >>>>>file,
> >>>>>project".
alone.
> >>>It
> > file.
> >>>>>>>HTH
> >>>>>>>Darins
> >>>>>>David
Re: ANT Builder properties undefined during import [message #268669 is a reply to message #268474] Wed, 25 August 2004 09:56 Go to previous messageGo to next message
Darin,
You are right in that I am hitting two separate errors.
The taskdef issues are the same whether I am using the imports or not. I
have added the details you have requested to
https://bugs.eclipse.org/bugs/show_bug.cgi?id=68373 .
The problems with the variable expansion and imports within the Ant
Editor seem covered by your entry in
Note that in our development environment we try to generalize and
centralize the details of the build system as much as possible away from
the individual components and applications they are building. The build
files within the source trees of the individual projects simply identify
what kind of component it is by importing the correct generalized build
file and supplying a couple of component/application specific
properties. It is rare that a user of the imported build files has any
clue as to how what he/she has imported actually work. That is one
reason why individually registering each ant task within the Ant
preferences is not attractive.
The Ant changes in 3.0 look very promising.
thanks,
jim
> Darins
> successfully.
> there
>>>proved me wrong :-)
>>>appears to
>>>argument
>>>>>Thanks
>>>>>Darins
> that
> in
>>>>>>I've tried:
> file
> was
>>>>>>$ pwd
>>>>>>/cygdrive/c/tmp
>>>>>>foo/build.xml
>>>>>></project>
>>>>>>bar/included.xml
>>>>>> <target name="all">
>>>>>> </target>
>>>>>></project>
>>>>>>BUILD FAILED
>>>>>> ### Eclipse/Ant
>>>>>>all:
>>>>>> [echo] Hello World
>>>>>>BUILD SUCCESSFUL
> why
>>>>>not
>>>>>>>Thanks
>>>>>>>Darins
>>>the
> files
>>>>>so
> imported
>>>>>>>file,
>>>>>>>project".
> alone.
>>>>>It
>>>file.
>>>>>>>>>HTH
>>>>>>>>>Darins
>>>>>>>>David
Re: ANT Builder properties undefined during import [message #268691 is a reply to message #268669] Wed, 25 August 2004 11:58 Go to previous message
Thanks for reporting back Jim.
I will work to resolving these issues.
I have a fix for the variable expansion that I will likely release today.
I hope the workaround of launching from the Ant editor outline is not too
cumbersome.
As well you can use the launch history and favorites once you performed the
build.
Please keep up the reporting of the problems / enhancements you would like
to see in the Ant integration.
Darins
news:cgi5k1$j2m$1@eclipse.org...
> Darin,
> thanks,
> jim
classpath"
be
> > Darins
able
Choosing
ran
> > successfully.
> > there
you
> >>>proved me wrong :-)
registering
getting
the
> >>>appears to
> >>>argument
> >>>>>Thanks
> >>>>>Darins
> > that
Things
I
> > in
> >>>>>>I've tried:
> > file
> > was
${INCLUDES}
execution
> >>>>>>$ pwd
> >>>>>>/cygdrive/c/tmp
> >>>>>>foo/build.xml
> >>>>>></project>
> >>>>>>bar/included.xml
> >>>>>> <target name="all">
> >>>>>> </target>
> >>>>>></project>
> >>>>>>BUILD FAILED
imported
> >>>>>> ### Eclipse/Ant
> >>>>>>all:
> >>>>>> [echo] Hello World
> >>>>>>BUILD SUCCESSFUL
> > why
> >>>>>not
> >>>>>>>So I have entered
> >>>>>>>Thanks
> >>>>>>>Darins
project
one
adding
> >>>the
> > files
> >>>>>so
> > imported
> >>>>>>>file,
> >>>>>>>project".
> > alone.
> >>>>>It
> >>>file.
> >>>>>>>>>HTH
> >>>>>>>>>Darins
> >>>>>>>>David
Previous Topic:Eclipse Plugin and Axis 1.1
Next Topic:No syntax highlight in Ant Editor for filenames other than build.xml
Current Time: Wed Nov 05 17:00:25 EST 2025
Powered by FUDForum. Page generated in 0.06271 seconds
