Home » Eclipse Projects » Eclipse Platform » Problems running Eclipse 2.1.3 on AIX using IBM JDK v1.4.2
Problems running Eclipse 2.1.3 on AIX using IBM JDK v1.4.2 [message #265144] Mon, 02 August 2004 19:58 Go to next message
I've been running Eclipse 2.1.3 using IBM's JDK 1.4.0 on AIX 5.1 for
about a year without any problems. My oslevel is up to date (5100-06)
and I've installed all recent patches/fixes from IBM.
Recently, I upgraded to version 1.4.2 of IBM's JDK and I can no longer
build or start a runtime launch. When I try to build a project, I get
the following exception in my error log:
java.lang.IllegalAccessError:
org.apache.xerces.impl.XMLEntityManager$EntityScanner tried to access f
ity from class
When I try to launch a runtime workbench process I get this exception:
java.lang.reflect.InvocationTargetException
Has anyone run into these problems before? Or is IBM Java not backwards
compatible with Eclipse?
-B. Townsend
!ENTRY org.eclipse.core.resources 4 2 Aug 02, 2004 16:35:38.75
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.core.resources".
!STACK 0
ity from class
org.apache.xerces.impl.XMLEntityManager$EntityScanner.getExp andedSystemId(XMLEntityManager
org.apache.xerces.parsers.AbstractDOMParser.startDocument(Un known Source)
org.apache.xerces.impl.xs.XMLSchemaValidator.startDocument(U nknown Source)
org.apache.xerces.impl.XMLNamespaceBinder.startDocument(Unkn own Source)
org.apache.xerces.impl.dtd.XMLDTDValidator.startDocument(Unk nown Source)
org.apache.xerces.impl.XMLDocumentScannerImpl.startEntity(Un known Source)
at org.apache.xerces.impl.XMLEntityManager.startEntity(Unknown
Source)
org.apache.xerces.impl.XMLEntityManager.startDocumentEntity( Unknown Source)
org.apache.xerces.impl.XMLDocumentScannerImpl.setInputSource (Unknown Source)
at org.apache.xerces.parsers.DTDConfiguration.parse(Unknown Source)
at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
org.eclipse.pde.internal.core.plugin.XMLDocumentModelBuilder .parse(XMLDocumentModelBuilder
org.eclipse.pde.internal.core.plugin.DocumentModel.reconcile (DocumentModel.java:129)
org.eclipse.pde.internal.core.plugin.DocumentModel.load(Docu mentModel.java:107)
org.eclipse.pde.internal.core.plugin.DocumentModel.load(Docu mentModel.java:95)
org.eclipse.pde.internal.core.plugin.AbstractPluginModelBase .load(AbstractPluginModelBase.
org.eclipse.pde.internal.core.plugin.WorkspacePluginModelBas e.load(WorkspacePluginModelBas
org.eclipse.pde.internal.builders.ManifestConsistencyChecker .validatePlugin(ManifestConsis
org.eclipse.pde.internal.builders.ManifestConsistencyChecker .checkFile(ManifestConsistency
org.eclipse.pde.internal.builders.ManifestConsistencyChecker .checkThisProject(ManifestCons
org.eclipse.pde.internal.builders.ManifestConsistencyChecker .build(ManifestConsistencyChec
org.eclipse.core.internal.events.BuildManager$2.run(BuildMan ager.java:427)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java(Compiled
Code
at org.eclipse.core.runtime.Platform.run(Platform.java(Inlined
Compiled Code))
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java(Compiled
Code))
Code))
Code))
org.eclipse.core.internal.events.BuildManager$1.run(BuildMan ager.java:151)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java(Inlined
Compi
Compiled Code))
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java(Inlined
Compile
org.eclipse.core.internal.events.BuildManager.basicBuildLoop (BuildManager.java(Compiled
Co
org.eclipse.core.internal.events.BuildManager.build(BuildMan ager.java(Compiled
Code))
org.eclipse.core.internal.resources.Workspace.build(Workspac e.java:181)
org.eclipse.ui.actions.GlobalBuildAction$1.run(GlobalBuildAc tion.java:174)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:101)
!ENTRY org.eclipse.debug.ui 4 120 Aug 02, 2004 16:29:35.471
!MESSAGE Error logged from Debug UI:
!STACK 0
org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:283)
org.eclipse.jface.dialogs.ProgressMonitorDialog.run(Progress MonitorDialog.java:357)
at org.eclipse.debug.ui.DebugUITools.launch(DebugUITools.java:4 94)
org.eclipse.debug.ui.actions.AbstractLaunchToolbarAction.run (AbstractLaunchToolbarAction.java:69)
org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:251)
org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPl uginAction.java:207)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:456)
org.eclipse.jface.action.ActionContributionItem.handleWidget Event(ActionContributionItem.java:403)
org.eclipse.jface.action.ActionContributionItem.access$0(Act ionContributionItem.java:397)
org.eclipse.jface.action.ActionContributionItem$ActionListen er.handleEvent(ActionContributionItem.java:72)
org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java (Compiled Code))
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java(Inlined
Compiled Code))
org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va(Compiled
Code))
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java (Compiled Code))
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a(Compiled
Code))
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1385)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:858)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:85)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:58)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:60)
at java.lang.reflect.Method.invoke(Method.java:391)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
Caused by: org.eclipse.swt.SWTException: Invalid thread access
at org.eclipse.swt.SWT.error(SWT.java:2330)
at org.eclipse.swt.SWT.error(SWT.java:2260)
at org.eclipse.swt.widgets.Widget.error(Widget.java:338)
at org.eclipse.swt.widgets.Shell.<init>(Shell.java:234)
at org.eclipse.swt.widgets.Shell.<init>(Shell.java:310)
at org.eclipse.jface.window.Window.createShell(Window.java:335)
at org.eclipse.jface.window.Window.create(Window.java:301)
at org.eclipse.jface.window.Window.open(Window.java:552)
org.eclipse.jface.dialogs.MessageDialog.openError(MessageDia log.java:286)
org.eclipse.pde.internal.ui.launcher.WorkbenchLaunchConfigur ationDelegate.validatePlugins(WorkbenchLaunchConfigurationDe legate.java:453)
org.eclipse.pde.internal.ui.launcher.WorkbenchLaunchConfigur ationDelegate.createWorkspaceRunnerConfiguration(WorkbenchLa unchConfigurationDelegate.
java:184)
org.eclipse.pde.internal.ui.launcher.WorkbenchLaunchConfigur ationDelegate.launch(WorkbenchLaunchConfigurationDelegate.ja va:78)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:156)
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:676)
org.eclipse.debug.ui.DebugUITools.buildAndLaunch(DebugUITool s.java:538)
at org.eclipse.debug.ui.DebugUITools$2.run(DebugUITools.java:48 7)
Re: Problems running Eclipse 2.1.3 on AIX using IBM JDK v1.4.2 [message #265150 is a reply to message #265144] Mon, 02 August 2004 20:18 Go to previous messageGo to next message
http://www.eclipsefaq.org/chris/faq/html/faq108.html
Ed Burnette, co-author, Eclipse in Action
www.manning.com/gallardo
www.eclipsepowered.org
"B. Townsend" <btownsend@rocketmail.com> wrote in message
news:cemkb3$9ll$1@eclipse.org...
> ity from class
Re: Problems running Eclipse 2.1.3 on AIX using IBM JDK v1.4.2 [message #265252 is a reply to message #265150] Tue, 03 August 2004 12:27 Go to previous message
Ed, thanks for the link. One thing that was curious is that the FAQ
mentions "You cannot use Eclipse 2.1 or earlier with an IBM 1.4 VM" but
I was able to run fine with 1.4.0 and Eclipse 2.1.3. I think it was in
versions 1.4.1 and later that this problem shows up.
Thanks again,
-B. Townsend
Previous Topic:Build doesn't work
Next Topic:any german eclipse forum
Current Time: Thu Jul 17 20:52:17 EDT 2025
Powered by FUDForum. Page generated in 0.06575 seconds
