Create nodes and Reorient Connections programmatically [message #1468655] |
Tue, 11 November 2014 01:30 |
Ricardo \\\"CaWal\\\" Cacheta Waldemarin Messages: 29 Registered: January 2013 |
Hey, guys!
I'm creating an Action for a pop-up menu. The expected behaviour is that it gets a selected node of the diagram and create a new node of a chosen type. After the creation, all attributes must be copied to the new node and all connections mus be reoriented. Then, the old nod must be destroyed.
I've found a way to create the new nodes and destroy the old ones, but I didn't found a way to reorient connections and copy attributes. I'm afraid I'd oversight some important concept of the GMF runtime. Can someone put me in the right tracks?
Bellow I show the action I'm implementing. Hope it helps.
Thank you for your time!
public class OboTermTransformAction implements org.eclipse.ui.IObjectActionDelegate{
private Shell shell;
private oboroeditor.diagram.part.OboroeditorDiagramEditor diagramEditorPart;
private ISelection selection;
private IAction action;
public void run(IAction action) {
EditingDomain editingDomain = this.diagramEditorPart.getEditingDomain();
ISelectionService selectionService =
PlatformUI.getWorkbench().getActiveWorkbenchWindow()
.getSelectionService();
ISelection selection = selectionService.getSelection();
if (selection instanceof IStructuredSelection) {
// asks the user the entity type he wants
Object[] possibilities = {"Term", "Process", "Continuant", "Material", "Immaterial"};
String s = (String) JOptionPane.showInputDialog(
null,
"Transform entities to...",
"Customized Dialog",
JOptionPane.PLAIN_MESSAGE,
null,
possibilities,
"Term");
// gets the selected items
IStructuredSelection iStructuredSelection = (IStructuredSelection) selection;
List<EditPart> selectedElements = iStructuredSelection.toList();
// create a compound command
CompoundCommand cc = new CompoundCommand("Change entities types to " + s);
List<CreateViewRequest> requestList = new ArrayList<CreateViewRequest>();
//changes every object
for(EditPart editPart : selectedElements){
IGraphicalEditPart gEditPart = (IGraphicalEditPart) editPart;
List<EditPart> a = gEditPart.getViewer().getSelectedEditParts();
MessageDialog.openInformation(
shell,
"Readme Example",
"Popup Menu Action executed... I hope..." + gEditPart.getModel() + a.get(0));
// criar um request para a criação do elemento
IElementType iElementType = null;
switch (s) {
case "Term":
iElementType = OboroeditorElementTypes.OboTerm_2016;
break;
case "Process":
iElementType = OboroeditorElementTypes.Process_2009;
break;
case "Continuant":
iElementType = OboroeditorElementTypes.Continuant_2011;
break;
case "Material":
iElementType = OboroeditorElementTypes.Material_2007;
break;
case "Immaterial":
iElementType = OboroeditorElementTypes.Immaterial_2008;
break;
default:
break;
CreateViewRequest termRequest = CreateViewRequestFactory.getCreateShapeRequest(iElementType, gEditPart.getDiagramPreferencesHint());
requestList.add(termRequest);
Point p = gEditPart.getFigure().getBounds().getCenter().getCopy();
termRequest.setLocation(p);
//create the command to create a new term
OboOntologyEditPart diagramEditPart = (OboOntologyEditPart) gEditPart.getParent();
Command createTermCommand = diagramEditPart.getCommand(termRequest);
IAdaptable topicViewAdapter = (IAdaptable) ((List) termRequest.getNewObject()).get(0);
// adds the command to be executed
cc.add(createTermCommand);
//execute all commands and create items
((IGraphicalEditPart)selectedElements.get(0)).getDiagramEditDomain().getDiagramCommandStack().execute(cc);
// reorient all in/out connections and copy all attrributes to new elements
// WHAT GOES HERE???
// apagar os nós antigos
editingDomain.getCommandStack().execute(RemoveCommand.create(editingDomain, gEditPart.getModel()));
public void selectionChanged(IAction action, ISelection selection) {
// TODO Auto-generated method stub
this.action = action;
this.selection = selection;
public void setActivePart(IAction action, IWorkbenchPart targetPart) {
this.diagramEditorPart = (oboroeditor.diagram.part.OboroeditorDiagramEditor) targetPart;
shell = targetPart.getSite().getShell();
FUDForum. Page generated in 0.03112 seconds
