Re: EMF Edit ItemProvider getText method always returns a default string? [message #1468063 is a reply to message #1468052] |
Mon, 10 November 2014 14:45 |
Ed Merks Messages: 33142 Registered: July 2009 |
Jan,
No, that's just the way it is...
On 10/11/2014 3:35 PM, Jan Rosczak wrote:
> Hello,
> I a have an Xcore (1.3) model and I am generating Edit code from it, too.
> When I look in one of the generated ItemProvider classes the method
> getText is generated as follows:
> @Override
> public String getText(Object object) {
> String label = ((GroupViewMappingDescription)object).getName();
> return label == null || label.length() == 0 ?
> getString("_UI_GroupViewMappingDescription_type") :
> getString("_UI_GroupViewMappingDescription_type") + " " +
> label;
> When the label is empty a default string is return which is fine, but
> why is the label prefixed with a default string in the other case?
> Can I do something about that behaviour (which I find strange by the
> way) without touching the generated classes?
> Thanks
> Jan Rosczak
Ed Merks
FUDForum. Page generated in 0.02898 seconds
