Re: How to untag a JAR file [message #264026 is a reply to message #264025] |
Thu, 04 September 2008 20:47 |
Originally posted by: codeslave.ca.ibm.com
Not sure if there's a UI way in Eclipse, but you can go commandline like
this:
cvs -d you@server.com:/cvsroot/path tag -d the_bad_tag
On Windows you might be able to do that w/ TortoiseCVS, if you don't use
cygwin.
Dave Alvarado wrote:
> I accidentally checked in a JAR file (into CVS), currently showing up
> under Referenced Libraries, and gave it a tag. How can I remove that
> tag so it does not show up when I pull everything with that tag from the
> CVS repository. I'm using Eclipse 3.4 on Windows XP.
> Thanks, - Dave
Nick Boldt :: Release Engineer, IBM Toronto Lab
Eclipse Modeling :: http://www.eclipse.org/modeling
http://wiki.eclipse.org/index.php/User:Nickb
FUDForum. Page generated in 0.08093 seconds
