"is currently not part of the index" [message #262344] |
Thu, 31 July 2008 22:50 |
Originally posted by: harlan.zamora.yahoo.com
I am new to Eclipse and I running into the the following error when trying
to use the Call Hierarchy in eclipse:
"The file header_PRIV.h is currently not part of the index"
I am working with some complex code that for example purposes I have
simplified for my question to the following:
header.h
class Header
public:
Header();
~Header();
private:
#include "header_PRIV.h"
header_PRIV.h
Example();
AnotherExample()
header.cpp
#include "header.h"
Header::Header()
Header::~Header()
Header::Example()
cout << "Example" << endl;
AnotherExample();
Header::AnotherExample()
cout << "AnotherExample" << endl;
When I use the Eclipse Call Hierchy on either Example() or
AnotherExample() I am unable to see the call tree. I am guessing that the
issue has to do with the way the header.h file includes "#include
"headerFile_PRIV.h" as it's private attribute. I don't see this issue on
public methods, on public methods I can actually see the call tree upwards
and downwards.
I have enabled under my project Indexer preferences "Fast C/C++ Indexer"
as well as "Full C/C++ Indexer", and had the checkmark for "Index all
files". But even after this, I am still unable to use the call tree on the
private methods mentioned.
Is there a way I can tell eclipse to see this or some feature or setting
that I may need to select?
Harlan-
Re: "is currently not part of the index" [message #262347 is a reply to message #262344] |
Fri, 01 August 2008 02:40 |
Originally posted by: codeslave.ca.ibm.com
Sounds like a C/C++ question. Copying CDT newsgroup, eclipse.tools.cdt.
Harlan Zamora wrote:
> trying to use the Call Hierarchy in eclipse:
> header.h
> class Header {
> public:
> Header();
> ~Header();
> private:
> header_PRIV.h
> Example();
> AnotherExample()
> header.cpp
> #include "header.h"
> Header::Header()
> Header::~Header()
> Header::Example()
> AnotherExample();
> the issue has to do with the way the header.h file includes "#include
> on public methods, on public methods I can actually see the call tree
> upwards and downwards.
> the private methods mentioned.
> Thanks
> Harlan-
Nick Boldt :: Release Engineer, IBM Toronto Lab
Eclipse Modeling :: http://www.eclipse.org/modeling
http://wiki.eclipse.org/index.php/User:Nickb
FUDForum. Page generated in 0.08026 seconds
