Home » Archived » BIRT » Multi series bar chart problem
Multi series bar chart problem [message #262215] Wed, 28 November 2007 07:50 Go to next message
Originally posted by: hector.rios.infor.com
Hi there,
I am a newbie to BIRT and have been trying to build a multi series bar
chart.
I have the following scenario:
Y-axis : amount of sales
X-axis : month and year
I have an optional Y-Series grouping on client segments of which there are
four thus producing a stacked bar chart.
I have managed to produce the chart with a stacked list of bars for each
month where each bar's Y-Series value label displays.
The only problem is that I also need to display the sum of the stacked
bar's
Y-Series values. For example, for the month of November 2007 I have 4 bars
(Client segments) with values of 20, 10, 10, 40 I want to display 80 at
the top of the stacked bar.
Does anyone have an idea of how I can accomplish this?
Any help would be greatly appreciated.
Thanks.
Re: Multi series bar chart problem [message #262353 is a reply to message #262215] Thu, 29 November 2007 09:25 Go to previous messageGo to next message
Hi again,
please does anyone know how I can accomplish this. I'm kind of in a bind
and I haven't found anything in the archives about this.
Thanks again
-Hector
Re: Multi series bar chart problem [message #262614 is a reply to message #262215] Tue, 04 December 2007 07:49 Go to previous messageGo to next message
Hector,
I don't think this is easily feasible in your scenario. Can you file an
enhancement in bugzilla and we will provide a way to do this in the future.
Maybe what you could try is use some script to compute the stack sum and
modify the top label, it's worth a try.
David
"Hector" <hector.rios@infor.com> wrote in message
news:c6e1e32a64ff052fdfc7f3b45fb13e2b$1@www.eclipse.org...
> Hi there,
> chart.
> Y-axis : amount of sales X-axis : month and year
> bar's Y-Series values. For example, for the month of November 2007 I have
> 4 bars (Client segments) with values of 20, 10, 10, 40 I want to display
> 80 at the top of the stacked bar.
> Thanks.
How can I build the BIRT viewer source code? [message #263180 is a reply to message #262353] Wed, 12 December 2007 17:04 Go to previous message
Originally posted by: sprudhom.nortel.com
Greetings,
I have successfully installed the BIRT viewer and created some reports. Now
I would like to do some customization of the viewer. Therefore I need to
build the source code.
I downloaded birt-report-designer-all-in-one-2.1.3.zip and I tried building
BIRT_2_1_3_Release_20070705 from CVS (I also tried building 2.2.1 with the
2.2.1 all-in-one but had some many problems I switched to 2.1.3 which seemed
more promising.)
I am using Sun Java SDK (and JRE) 1.4.2_16
I have followed the instructions here:
http://www.eclipse.org/birt/phoenix/build/buildInstructions. php
And the build of the overall project works but I cannot build the WebViewer.
When I invoke "ant.." on BuildWebViewer.xml as suggested on the web page I
get the following error (see below).
Question: what is the procedure to build the BIRT viewer? I see post/blogs
from different people on the web that did it so I know it is possible but
how??
I cannot find org.eclipse.birt.data.oda anywhere, where is that coming from?
Serge
Here is the build Error:
Buildfile: D:\Profiles\SPRUDHOM.AMERICASE\Eclipse
Workspaces\BIRT_2_1_3\org.eclipse.birt.report.viewer\BuildWe bViewer.xml
init:
[delete] Deleting directory D:\Profiles\SPRUDHOM.AMERICASE\Eclipse
Workspaces\BIRT_2_1_3\org.eclipse.birt.report.viewer\birt_we b
[copy] Copying 545 files to D:\Profiles\SPRUDHOM.AMERICASE\Eclipse
[copy] Copied 52 empty directories to 4 empty directories under
enginesdk:
[mkdir] Created dir: D:\Profiles\SPRUDHOM.AMERICASE\Eclipse
Workspaces\BIRT_2_1_3\org.eclipse.birt.report.viewer\birt_we b\WEB-INF\platform
ExportSDK:
Workspaces\BIRT_2_1_3\org.eclipse.birt.report.viewer\birt_we b\WEB-INF\platform\configuration
[copy] Copying 1 file to D:\Profiles\SPRUDHOM.AMERICASE\Eclipse
Workspaces\BIRT_2_1_3\org.eclipse.birt.report.viewer\birt_we b\WEB-INF\platform\plugins
[copy] Copying 25 files to D:\Profiles\SPRUDHOM.AMERICASE\Eclipse
[copy] Copying 9 files to D:\Profiles\SPRUDHOM.AMERICASE\Eclipse
Workspaces\BIRT_2_1_3\org.eclipse.birt.report.viewer\birt_we b\WEB-INF\platform\plugins\com.lowagie.itext
[copy] Copying 4 files to D:\Profiles\SPRUDHOM.AMERICASE\Eclipse
Workspaces\BIRT_2_1_3\org.eclipse.birt.report.viewer\birt_we b\WEB-INF\platform\plugins\org.apache.commons.codec
[copy] Copying 15 files to D:\Profiles\SPRUDHOM.AMERICASE\Eclipse
Workspaces\BIRT_2_1_3\org.eclipse.birt.report.viewer\birt_we b\WEB-INF\platform\plugins\org.apache.xerces
[copy] Copying 21 files to D:\Profiles\SPRUDHOM.AMERICASE\Eclipse
Workspaces\BIRT_2_1_3\org.eclipse.birt.report.viewer\birt_we b\WEB-INF\platform\plugins\org.apache.batik
[copy] Copying 6 files to D:\Profiles\SPRUDHOM.AMERICASE\Eclipse
Workspaces\BIRT_2_1_3\org.eclipse.birt.report.viewer\birt_we b\WEB-INF\platform\plugins\org.apache.batik.pdf
Workspaces\BIRT_2_1_3\org.eclipse.birt.report.viewer\birt_we b\WEB-INF\platform\plugins\org.mozilla.rhino
Workspaces\BIRT_2_1_3\org.eclipse.birt.report.viewer\birt_we b\WEB-INF\platform\plugins\org.w3c.sac
Workspaces\BIRT_2_1_3\org.eclipse.birt.report.viewer\birt_we b\WEB-INF\platform\plugins\org.apache.derby.core
init:
compileSource:
Jar:
Export:
[jar] Building jar: D:\Profiles\SPRUDHOM.AMERICASE\Eclipse
Workspaces\BIRT_2_1_3\org.eclipse.birt.report.viewer\birt_we b\WEB-INF\platform\plugins\org.eclipse.birt.core_2.1.3.quali fier.jar
BUILD FAILED
Workspaces\BIRT_2_1_3\org.eclipse.birt.report.viewer\BuildWe bViewer.xml:252:
The following error occurred while executing this line:
Workspaces\BIRT_2_1_3\org.eclipse.birt.report.engine\BuildEn gine.xml:346:
java.io.FileNotFoundException: D:\Profiles\SPRUDHOM.AMERICASE\Eclipse
Workspaces\BIRT_2_1_3\org.eclipse.birt.data.oda\BuildOda.xml (The system
cannot find the file specified)
Total time: 30 seconds
Previous Topic:including a datasource within a java application
Next Topic:custom javascript functions library
Current Time: Sun Nov 09 09:04:53 EST 2025
Powered by FUDForum. Page generated in 0.03015 seconds
