Home » Newcomers » Newcomers » question on using ant plugin for Eclipse
question on using ant plugin for Eclipse [message #262064] Sun, 27 July 2008 21:58 Go to next message
Originally posted by: chaklun_siu.ml.com
Hey Guys,
Was trying to use ant on my installed eclipse (version 3.2) with ant
plugin as 1.7. After finished the build.xml and tried to execute the ant
task a message popped "Source Not found"
Checked from the classpath tab when select "Run As" -> ""Ant Build" (the
execution dialog), I found that there is an item under user entries:
Addition Tasks & Support, and that the classpath for 1 of the task is not
poinnted correctly...
org.eclipse.swt.win32.win32.x86_3.2.2.v3236.jar. But it does exist in my
plugin folder....(on c:\program Files\eclipse\plugins\, but the path
showing up there is: (\\eyy649 is my machine name)
\\eyy649\program files\eclipse\\eyy649\program
files\eclipse\plugin\org.eclipse.swt.win32.win32.x86_3.2.2.v 3236.jar
It seems like the path is duplicating itself...
it is also strange that all the path for ant is not in form of
"c:\program..."etc, it started with my machinename, which is \\eyy649....
any through? Sorry for my bad English, and thanks you all =)
Re: question on using ant plugin for Eclipse [message #262136 is a reply to message #262064] Mon, 28 July 2008 21:33 Go to previous message
anyone can help? thanks guys...
Previous Topic:Need help using 'adapt' in core expression
Next Topic:Eclipse Europa package: where is the org.eclipse.platform.doc.isv_xxxx gone ?
Current Time: Sun Nov 09 12:38:05 EST 2025
Powered by FUDForum. Page generated in 0.08446 seconds
