Re: How to know when file is out of sync [message #25983 is a reply to message #25942] |
Mon, 18 August 2008 10:27 |
Martin Oberhuber Messages: 1007 Registered: July 2009 |
This is a very good use-case, and we should handle it better as part of
our "usability" Theme in 3.1.
I think we have had similar requests before, and if I'm not mistaken
https://bugs.eclipse.org/bugs/show_bug.cgi?id=143503 was addressed as
part of these requests. Please check if that helps you.
If not, please file an enhancement request in bugzilla, with [usability]
tag in the Summary, explaining your case.
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Denise wrote:
> OK, I have the following scenario. I use RSE to edit a remote file.
> While I'm editting, I lose my connection. I save the file which gives
> me an error because it couldn't save remotely but it does save the
> changes locally. Now I reconnect to the remote system. Is there any
> way to know that my local version of the file is not in sync with the
> remote version of the file? The file doesn't look like it has pending
> changes because it saved locally. If I edit it again and try to save,
> it will tell me but otherwise I don't see a way to say "hey RSE, check
> to see if the files I have open are in sync with the corresponding files
> on the remote system and if not, prompt me to sync each up".
> I guess I'm considering a failure case where I'm happily editing, lose
> my connection and can't get it back so I save the files locally in the
> RemoteSystemsTempFiles to deal with later. Then when I finally get my
> connection back, it would be good if there was an easy way to know that
> the stuff in RemoteSystemsTempFiles is out of sync with the remote
> system. Is there a way to do this without having to save each file that
> may have been open?
> Thanks!
Re: How to know when file is out of sync [message #576657 is a reply to message #25942] |
> may have been open?
> Thanks!
FUDForum. Page generated in 0.03512 seconds
