Home » Archived » BIRT » How to convert NULL values from DB to ""?
How to convert NULL values from DB to ""? [message #261784] Tue, 20 November 2007 11:11 Go to next message
In a cell in a table, I want to display this:
"".concat(dataSetRow["STOREID"], " / ", params["sewingStoreNr"])
This throws a TypeError: "Can't find default value for object" if STOREID
in the query returns NULL. How do I solve that?
Re: How to convert NULL values from DB to ""? [message #261861 is a reply to message #261784] Wed, 21 November 2007 09:06 Go to previous messageGo to next message
Apparently, the problem is not that the query returns NULL but that it
returns nothing (the row is not in the database). What is the type of
dataSetRow["STOREID"], if no data could be fetched from the DB?
Aaron Digulla
Re: How to convert NULL values from DB to ""? [message #261885 is a reply to message #261861] Wed, 21 November 2007 10:54 Go to previous messageGo to next message
Aaron,
If this cell is in a table that returns no data for the dataset the
expression you have should not be throwing an exception. Where are you
seeing the error?
Jason
>> STOREID in the query returns NULL. How do I solve that?
Re: How to convert NULL values from DB to ""? [message #261956 is a reply to message #261885] Thu, 22 November 2007 08:10 Go to previous messageGo to next message
> seeing the error?
In the log. The problem is that the cell is rendered but
dataSetRow["STOREID"] is not initialized because the DB didn't return any
rows.
I tried
dataSetRow["STOREID"] == undefined ? "" : dataSetRow["STOREID"]
and variants thereof, but it seems that dataSetRow itself is not set up
correctly in this case.
Aaron Digulla
Re: How to convert NULL values from DB to ""? [message #262055 is a reply to message #261956] Mon, 26 November 2007 10:12 Go to previous message
Aaron,
Can you post the report?
Jason
>> you seeing the error?
> any rows.
> I tried
Previous Topic:TOC in pdf
Next Topic:Change css style through script (Expression Builder)
Current Time: Sat Jul 26 09:27:44 EDT 2025
Powered by FUDForum. Page generated in 0.67617 seconds
