Re: Help me to fix reset list of command execution [message #1457429 is a reply to message #1456467] |
Fri, 31 October 2014 10:09 |
Are your columns representing different models (model A, model B, model C), showing these models' content? or are they showing the content of three distinct EObjects of the same model?
Whatever the case, this is not an EMF Compare question, but a more generic EMF one.
I am not that well versed into EMF transaction... But I think that if you have one command stack, you could record its "starting state" when you open the dialog and revert to that state (undoing every command one after the other) when the dialog is cancelled... you'd probably have better luck on the EMF forum though.
Laurent Goubet
Obeo
FUDForum. Page generated in 0.02402 seconds
