Home » Language IDEs » AspectJ » aspectj editor problem
aspectj editor problem [message #25793] Fri, 12 September 2003 15:20 Go to next message
Originally posted by: james22.poczta.onet.pl
hi.
i have a problem with color syntax of comments in aspectj editor.
the problem is, the comments have no color, only black default color
insted of my custom color set in java preferences.
what's up?
how to force comment to be colorful?
thx
dave
Re: aspectj editor problem [message #25843 is a reply to message #25793] Mon, 15 September 2003 04:35 Go to previous messageGo to next message
On Fri, 12 Sep 2003 21:20:02 +0200, james22 <james22@poczta.onet.pl> wrote:
> hi.
> what's up?
> thx
> dave
Hi Dave,
Not heard of this problem before. Could you let us know the following
information so that we can try and verify what you are seeing :-
(a) Version of Eclipse
(b) Version of AJDT
(c) Operating System
Is it the case that this problem does *not* occur when you use the Java
editor ? If so, can you improve things by going into
Windows-Preferences-Java-Editor-Syntax tab and selecting your comments
colouring ?
George
George
Re: aspectj editor problem [message #25884 is a reply to message #25843] Tue, 16 September 2003 14:01 Go to previous messageGo to next message
hi
it is:
Windows XP PL,
Eclipse Platform
Version: 3.0.0
Build id: 200309090010
AJDT 1.1.3
in java editor i can see colorful comments - no problem (get my custom
colors), but aspect editor gives me everything colored but comments :-O
still i can't say why...
bregs,
dave
Re: aspectj editor problem [message #25925 is a reply to message #25884] Wed, 17 September 2003 04:46 Go to previous messageGo to next message
On Tue, 16 Sep 2003 20:01:29 +0200, james22 <james22@poczta.onet.pl> wrote:
> hi
> it is:
> Windows XP PL,
> Eclipse Platform
> Version: 3.0.0
> AJDT 1.1.3
> bregs,
> dave
Hi Dave,
Thanks for the information. I have just tried out the setup you describe
and I got the very same problem you describe. AJDT 1.1.3 is still fine on
the Eclipse 2.x stream so I assume that we have fallen foul of some API
change(s) between Eclipse 2.x and 3.x. A new bug report will be raised on
this today.
George
Re: aspectj editor problem [message #25964 is a reply to message #25925] Wed, 17 September 2003 05:08 Go to previous messageGo to next message
On Wed, 17 Sep 2003 09:46:16 +0100, George Harley <gharley@uk.ibm.com>
> wrote:
>> hi
>> it is:
>> Windows XP PL,
>> Eclipse Platform
>> Version: 3.0.0
>> AJDT 1.1.3
>> bregs,
>> dave
> Hi Dave,
> on the Eclipse 2.x stream so I assume that we have fallen foul of some
> API change(s) between Eclipse 2.x and 3.x. A new bug report will be
> raised on this today.
> Best regards,
Just checked and there is already an open Bugzilla report on this item.
The bug id is 42957. For status please point your browser at :-
https://bugs.eclipse.org/bugs/show_bug.cgi?id=42957
It looks like the problem is caused by new functionality that went into
Eclipse 3.0 M3 (we were apparently OK on the M2 build). We will look into
this and try to get a speedy resolution.
George
Re: aspectj editor problem [message #26046 is a reply to message #25964] Wed, 17 September 2003 15:38 Go to previous messageGo to next message
ok thx :)
Re: aspectj editor problem [message #26086 is a reply to message #26046] Thu, 18 September 2003 07:32 Go to previous message
On Wed, 17 Sep 2003 21:38:13 +0200, james22 <james22@poczta.onet.pl> wrote:
> ok thx :)
A fix for this problem is now integrated with the latest AJDT code base
(see bug status on Bugzilla for info). Improved editor behaviour on
Eclipse 3.0 should be available in AJDT 1.1.4 which will be available very
soon.
George
Re: aspectj editor problem [message #571121 is a reply to message #25793] Mon, 15 September 2003 04:35 Go to previous message
> hi.
> what's up?
> thx
> dave
Hi Dave,
(b) Version of AJDT
colouring ?
George
George
Re: aspectj editor problem [message #571205 is a reply to message #25843] Tue, 16 September 2003 14:01 Go to previous message
hi
it is:
Windows XP PL,
Eclipse Platform
Version: 3.0.0
AJDT 1.1.3
bregs,
dave
Re: aspectj editor problem [message #571222 is a reply to message #25884] Wed, 17 September 2003 04:46 Go to previous message
> hi
> it is:
> Windows XP PL,
> Eclipse Platform
> Version: 3.0.0
> AJDT 1.1.3
> bregs,
> dave
Hi Dave,
this today.
George
Re: aspectj editor problem [message #571242 is a reply to message #25925] Wed, 17 September 2003 05:08 Go to previous message
> wrote:
>> hi
>> it is:
>> Windows XP PL,
>> Eclipse Platform
>> Version: 3.0.0
>> AJDT 1.1.3
>> bregs,
>> dave
> Hi Dave,
> Best regards,
George
Re: aspectj editor problem [message #571369 is a reply to message #25964] Wed, 17 September 2003 15:38 Go to previous message
ok thx :)
Re: aspectj editor problem [message #571387 is a reply to message #26046] Thu, 18 September 2003 07:32 Go to previous message
> ok thx :)
soon.
George
Previous Topic:AJDT Example: Autocompletion Doesn't Work
Next Topic:AJDT Example: Autocompletion Doesn't Work
Current Time: Tue Aug 12 12:46:03 EDT 2025
Powered by FUDForum. Page generated in 0.04816 seconds
