Home » Archived » Hudson » How to test REST Client using Hudson
icon2.gif  How to test REST Client using Hudson [message #1453106] Sun, 26 October 2014 07:47 Go to next message
I would like to know if I can use Hudson as a REST Client for online service?
Moreover, can I create job that takes its input from the previous job result?
Re: How to test REST Client using Hudson [message #1469688 is a reply to message #1453106] Tue, 11 November 2014 15:37 Go to previous messageGo to next message
Can you explain "Online Service"? Hudson has enough REST API to create client of your own. Either you could use the classic REST Api or the API exported via the REST plugin.
Re: How to test REST Client using Hudson [message #1469780 is a reply to message #1469688] Tue, 11 November 2014 17:21 Go to previous messageGo to next message
Any normal online service with GET, POST, PUT requests.
Re: How to test REST Client using Hudson [message #1469864 is a reply to message #1469780] Tue, 11 November 2014 19:04 Go to previous message
You might want to check the REST API provided by Hudson REST plugin
http://ci.hudson-ci.org/plugin/rest-plugin/api/rest.html
Previous Topic:change to default port
Next Topic:"Build when Maven dependencies have been updated" uses transitive dependencies?
Current Time: Wed Sep 24 04:59:51 EDT 2025
Powered by FUDForum. Page generated in 0.25432 seconds
