Home » Newcomers » Newcomers » Regular exceptions in Eclipse.
Regular exceptions in Eclipse. [message #259845] Thu, 03 July 2008 01:08 Go to next message
Originally posted by: screw.gorodok.net
Hi, everybody.
At this week i reinstall my home computer system (Debian/Lenny) and was
suprized by avalance of errors, wich eclipse start to generate. (At past,
I worked in Eclipse successfuly. No errors occured. Problems became after
OS reinstallation.) I use Eclipse PDT all in one Version: 3.3.2 Build id:
M20080221-1800. An now I can't work, 'cause error pop-up messages irritate
me.
Here is log:
!ENTRY org.eclipse.core.resources 4 1 2008-07-03 11:23:36.248
!MESSAGE Internal Error
!STACK 0
at java.io.File.<init>(libgcj.so.90)
org.eclipse.core.internal.filesystem.local.LocalFile.getChil d(LocalFile.java:154)
org.eclipse.core.filesystem.provider.FileStore.childStores(F ileStore.java:124)
org.eclipse.core.filesystem.provider.FileStore.childInfos(Fi leStore.java:103)
org.eclipse.core.internal.localstore.UnifiedTree.getLocalLis t(UnifiedTree.java:324)
org.eclipse.core.internal.localstore.UnifiedTree.addChildren (UnifiedTree.java:122)
org.eclipse.core.internal.localstore.UnifiedTree.addNodeChil drenToQueue(UnifiedTree.java:226)
org.eclipse.core.internal.localstore.UnifiedTree.accept(Unif iedTree.java:100)
org.eclipse.core.internal.localstore.FileSystemResourceManag er.refreshResource(FileSystemResourceManager.java:733)
org.eclipse.core.internal.localstore.FileSystemResourceManag er.refresh(FileSystemResourceManager.java:717)
org.eclipse.core.internal.resources.Resource.refreshLocal(Re source.java:1420)
at org.eclipse.php.internal.ui.actions.RefreshAction$1.run(Unkn own
Source)
org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1797)
org.eclipse.php.internal.ui.actions.WorkbenchRunnableAdapter .run(Unknown
Source)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:113)
!ENTRY org.eclipse.php.ui 4 10001 2008-07-03 11:23:36.327
!MESSAGE PHP ui plugin internal error
!STACK 0
java.lang.reflect.InvocationTargetException
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:350)
org.eclipse.jface.dialogs.ProgressMonitorDialog.run(Progress MonitorDialog.java:495)
org.eclipse.ui.internal.progress.ProgressMonitorJobsDialog.r un(ProgressMonitorJobsDialog.java:268)
org.eclipse.ui.internal.progress.ProgressManager$3.run(Progr essManager.java:909)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.ui.internal.progress.ProgressManager.busyCursorW hile(ProgressManager.java:944)
org.eclipse.ui.internal.progress.ProgressManager.busyCursorW hile(ProgressManager.java:919)
org.eclipse.ui.internal.progress.ProgressManager.run(Progres sManager.java:1127)
at org.eclipse.php.internal.ui.actions.RefreshAction.run(Unknow n Source)
org.eclipse.php.internal.ui.actions.SelectionDispatchAction. dispatchRun(Unknown
Source)
org.eclipse.php.internal.ui.actions.SelectionDispatchAction. run(Unknown
Source)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
org.eclipse.ui.actions.RetargetAction.runWithEvent(RetargetA ction.java:229)
org.eclipse.jface.commands.ActionHandler.execute(ActionHandl er.java:119)
at org.eclipse.core.commands.Command.executeWithChecks(Command. java:475)
org.eclipse.core.commands.ParameterizedCommand.executeWithCh ecks(ParameterizedCommand.java:429)
org.eclipse.ui.internal.handlers.HandlerService.executeComma nd(HandlerService.java:165)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.executeComman d(WorkbenchKeyboard.java:470)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.press(Workben chKeyboard.java:821)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.processKeyEve nt(WorkbenchKeyboard.java:879)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.filterKeySequ enceBindings(WorkbenchKeyboard.java:568)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.access$3(Work benchKeyboard.java:510)
org.eclipse.ui.internal.keys.WorkbenchKeyboard$KeyDownFilter .handleEvent(WorkbenchKeyboard.java:126)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:142 3)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1100)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1125)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1110)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1137 )
at org.eclipse.swt.widgets.Widget.gtk_key_press_event(Widget.ja va:663)
org.eclipse.swt.widgets.Control.gtk_key_press_event(Control. java:2533)
org.eclipse.swt.widgets.Composite.gtk_key_press_event(Compos ite.java:679)
at org.eclipse.swt.widgets.Tree.gtk_key_press_event(Tree.java:1 845)
at org.eclipse.swt.widgets.Widget.windowProc(Widget.java:1486)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4234 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:3973 )
Caused by: java.lang.NullPointerException
Source)
Source)
Root exception:
Source)
Source)
!ENTRY org.eclipse.wst.sse.ui 4 2 2008-07-03 11:32:53.267
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.wst.sse.ui".
!STACK 0
java.lang.NoClassDefFoundError:
org.eclipse.wst.dtd.core.internal.contentmodel.DTDImpl
at java.lang.Class.initializeClass(libgcj.so.90)
org.eclipse.wst.dtd.core.internal.contentmodel.CMDocumentFac toryDTD.createCMDocument(CMDocumentFactoryDTD.java:37)
org.eclipse.wst.xml.core.internal.contentmodel.ContentModelM anager.createCMDocument(ContentModelManager.java:56)
org.eclipse.wst.xml.core.internal.contentmodel.modelqueryimp l.CMDocumentManagerImpl.buildCMDocument(CMDocumentManagerImp l.java:267)
org.eclipse.wst.xml.core.internal.contentmodel.modelqueryimp l.CMDocumentManagerImpl.loadCMDocument(CMDocumentManagerImpl .java:252)
org.eclipse.wst.xml.core.internal.contentmodel.modelqueryimp l.CMDocumentManagerImpl.getCMDocument(CMDocumentManagerImpl. java:188)
org.eclipse.wst.xml.core.internal.contentmodel.modelqueryimp l.XMLAssociationProvider.getCMDocument(XMLAssociationProvide r.java:149)
org.eclipse.wst.xml.core.internal.contentmodel.modelqueryimp l.XMLAssociationProvider.getCMElementDeclaration(XMLAssociat ionProvider.java:220)
org.eclipse.wst.html.core.internal.modelquery.HTMLModelQuery Impl.getCMElementDeclaration(HTMLModelQueryImpl.java:153)
org.eclipse.wst.xml.ui.internal.editor.CMImageUtil.getDeclar ation(CMImageUtil.java:48)
org.eclipse.wst.xml.ui.internal.contentoutline.JFaceNodeAdap ter.getLabelImage(JFaceNodeAdapter.java:145)
org.eclipse.wst.xml.ui.internal.contentoutline.JFaceNodeLabe lProvider.getImage(JFaceNodeLabelProvider.java:56)
org.eclipse.wst.sse.ui.StructuredTextEditor.updateStatusLine (StructuredTextEditor.java:3495)
org.eclipse.wst.sse.ui.StructuredTextEditor$10.selectionChan ged(StructuredTextEditor.java:2464)
org.eclipse.wst.sse.ui.StructuredTextEditor$6.run(Structured TextEditor.java:907)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
org.eclipse.wst.sse.ui.StructuredTextEditor$StructuredSelect ionProvider.fireSelectionChanged(StructuredTextEditor.java:9 05)
org.eclipse.wst.sse.ui.StructuredTextEditor$StructuredSelect ionProvider.handlePostSelectionChanged(StructuredTextEditor. java:963)
org.eclipse.wst.sse.ui.StructuredTextEditor$5.selectionChang ed(StructuredTextEditor.java:886)
org.eclipse.jface.text.TextViewer.firePostSelectionChanged(T extViewer.java:2546)
org.eclipse.jface.text.TextViewer.firePostSelectionChanged(T extViewer.java:2498)
at org.eclipse.jface.text.TextViewer$5.run(TextViewer.java:2477 )
at org.eclipse.swt.widgets.Display.timerProc(Display.java:3766)
Please someone, tell me what's wrong? I hope, that I can get help here.
Re: Regular exceptions in Eclipse. [message #259859 is a reply to message #259845] Thu, 03 July 2008 02:53 Go to previous messageGo to next message
Originally posted by: subs._nospam_consertum.com
Looks like your Java is GCJ, which is not supported by Eclipse. Try
switching to a supported version of Java.
Vladimir wrote:
> Hi, everybody.
> past, I worked in Eclipse successfuly. No errors occured. Problems
> became after OS reinstallation.) I use Eclipse PDT all in one Version:
> 3.3.2 Build id: M20080221-1800. An now I can't work, 'cause error pop-up
> messages irritate me.
> Here is log:
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1797)
> at
> Source)
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.swt.widgets.Control.gtk_key_press_event(Control. java:2533)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Derek
Re: Regular exceptions in Eclipse. [message #259876 is a reply to message #259859] Thu, 03 July 2008 05:03 Go to previous messageGo to next message
Yep. Allready done. At this moment VM fall down with message:
JVM terminated. Exit code=1
/usr/lib/jvm/java-6-sun/bin/java
-Xms40m
-Xmx256m
-jar
/home/screw/eclipse/plugins/org.eclipse.equinox.launcher_1.0 .1.R33x_v20080118.jar
-os linux
-ws gtk
-arch x86
-showsplash
-launcher /home/screw/eclipse/eclipse
-name Eclipse
--launcher.library
/home/screw/eclipse/plugins/org.eclipse.equinox.launcher.gtk .linux.x86_1.0.3.R33x_v20080118/eclipse_1023.so
-startup
-exitdata 228001
-vm /usr/lib/jvm/java-6-sun/bin/java
-vmargs
-Xms40m
-Xmx256m
-jar
Eclipse killing me...
Re: Regular exceptions in Eclipse. [message #259887 is a reply to message #259876] Thu, 03 July 2008 05:12 Go to previous messageGo to next message
What's in the log file?
> -Xms40m
> -Xmx256m
> -jar
> -os linux
> -ws gtk
> -arch x86
> -showsplash
> -name Eclipse
> --launcher.library
> -startup
> -exitdata 228001
> -vmargs
> -Xms40m
> -Xmx256m
> -jar
Derek
Re: Regular exceptions in Eclipse. [message #259953 is a reply to message #259887] Thu, 03 July 2008 12:32 Go to previous messageGo to next message
I remove from my system dublicate eclipse exeplar, which was installed by
apt-get. Looks like pdt-all-in-one version conflict with the debian
distributed version. Crashes brcame rarely, but unless it still happend.
Here is the .log file: (I'm not see anything strange... Maybe you will)
!ENTRY org.eclipse.osgi 2 1 2008-07-03 18:00:28.100
!MESSAGE NLS missing message: DebugServerTestEvent_timeOutMessage in:
org.eclipse.php.internal.debug.core.PHPDebugCoreMessages
!SESSION 2008-07-03 21:29:10.616
eclipse.buildId=M20080221-1800
java.version=1.6.0_06
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=ru_RU
Command-line arguments: -os linux -ws gtk -arch x86
!ENTRY org.eclipse.core.resources 2 10035 2008-07-03 21:29:16.096
!MESSAGE The workspace exited with unsaved changes in the previous
session; refreshing workspace to recover changes.
!ENTRY org.eclipse.core.resources 4 567 2008-07-03 21:29:37.834
!MESSAGE Workspace restored, but some problems occurred.
!SUBENTRY 1 org.eclipse.core.resources 4 567 2008-07-03 21:29:37.835
!MESSAGE Could not read metadata for
'/home/screw/workspace/.metadata/.plugins/org.eclipse.core.r esources/.projects/avtoplaza/.syncinfo'.
!STACK 0
java.io.EOFException
at java.io.DataInputStream.readInt(DataInputStream.java:375)
org.eclipse.core.internal.resources.SyncInfoReader.readVersi onNumber(SyncInfoReader.java:76)
org.eclipse.core.internal.resources.SyncInfoReader.readSyncI nfo(SyncInfoReader.java:70)
org.eclipse.core.internal.resources.Synchronizer.restoreFrom Save(Synchronizer.java:155)
org.eclipse.core.internal.resources.Synchronizer.restore(Syn chronizer.java:142)
org.eclipse.core.internal.resources.SaveManager.restoreSyncI nfo(SaveManager.java:893)
org.eclipse.core.internal.resources.SaveManager.restore(Save Manager.java:658)
org.eclipse.core.internal.resources.SaveManager.startup(Save Manager.java:1319)
org.eclipse.core.internal.resources.Workspace.startup(Worksp ace.java:1949)
at org.eclipse.core.internal.resources.Workspace.open(Workspace .java:1713)
org.eclipse.core.resources.ResourcesPlugin.start(ResourcesPl ugin.java:363)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:999)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:993)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:974)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:260)
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:417)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:189)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:340)
org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:37)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:405)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319 )
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:107)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
!ENTRY org.eclipse.php.core 4 10001 2008-07-03 21:30:02.269
!MESSAGE PHPCore plugin internal error
!STACK 0
at java.io.DataInputStream.readBoolean(DataInputStream.java:227 )
org.eclipse.php.internal.core.util.SerializationUtil.readStr ing(Unknown
Source)
org.eclipse.php.internal.core.util.SerializationUtil.deseria lizePHPVariableData(Unknown
Source)
org.eclipse.php.internal.core.util.SerializationUtil.deseria lizePHPVariableDataArray(Unknown
Source)
org.eclipse.php.internal.core.util.SerializationUtil.deseria lizeVariableTypeManager(Unknown
Source)
org.eclipse.php.internal.core.util.SerializationUtil.deseria lizePHPFileData(Unknown
Source)
org.eclipse.php.internal.core.util.SerializationUtil.deseria lizePHPFileDataArray(Unknown
Source)
org.eclipse.php.internal.core.util.DefaultCacheManager.inner LoadModel(Unknown
Source)
at org.eclipse.php.internal.core.util.DefaultCacheManager.load( Unknown
Source)
org.eclipse.php.internal.core.phpModel.parser.PHPUserModelMa nager. <init>(Unknown
Source)
org.eclipse.php.internal.core.phpModel.parser.PHPUserModel.i nitialize(Unknown
Source)
org.eclipse.php.internal.core.phpModel.parser.PHPProjectMode l.initialize(Unknown
Source)
org.eclipse.php.internal.core.phpModel.parser.PHPWorkspaceMo delManager.putModel(Unknown
Source)
org.eclipse.php.internal.core.phpModel.parser.PHPWorkspaceMo delManager.getModelForProject(Unknown
Source)
org.eclipse.php.internal.core.phpModel.parser.PHPWorkspaceMo delManager.access$0(Unknown
Source)
org.eclipse.php.internal.core.phpModel.parser.PHPWorkspaceMo delManager$3.runInWorkspace(Unknown
Source)
org.eclipse.core.internal.resources.InternalWorkspaceJob.run (InternalWorkspaceJob.java:38)
!ENTRY org.eclipse.jface 2 0 2008-07-03 21:31:01.510
!MESSAGE Keybinding conflicts occurred. They may interfere with normal
accelerator operation.
!SUBENTRY 1 org.eclipse.jface 2 0 2008-07-03 21:31:01.510
!MESSAGE A conflict occurred for F3:
Binding(F3,
ParameterizedCommand(Command(org.eclipse.jdt.ui.edit.text.ja va.open.editor,Open
Declaration,
Open an editor on the selected element,
Category(org.eclipse.ui.category.navigate,Navigate,null,true ),
,,true),null),
org.eclipse.ui.defaultAcceleratorConfiguration,
org.eclipse.ui.contexts.window,,,system)
Binding(F3,
ParameterizedCommand(Command(org.eclipse.php.ui.edit.text.op en.editor,Open
Selection,
,,true),null),
org.eclipse.php.ui.contexts.window,,,system)
Binding(F3,
ParameterizedCommand(Command(org.eclipse.php.ui.edit.text.Op enDeclaration,Open
Declaration,
Open the declaration of the selected element,
Category(org.eclipse.ui.category.edit,Edit,null,true),
LegacyHandlerWrapper(ActionHandler(action=org.eclipse.php.internal.ui.actions.OpenDeclarationAction@249e4f)),
,,true),null),
org.eclipse.php.ui.phpEditorScope,,,system)
!MESSAGE A conflict occurred for ALT+SHIFT+V:
Binding(ALT+SHIFT+V,
ParameterizedCommand(Command(org.eclipse.jdt.ui.edit.text.ja va.move.element,Move
- Refactoring ,
Move the selected element to a new location,
Category(org.eclipse.jdt.ui.category.refactoring,Refactor - Java,Java
Refactoring Actions,true),
,,true),null),
ParameterizedCommand(Command(org.eclipse.php.ui.edit.text.mo ve.element,Move
- Refactoring ,
Category(org.eclipse.php.ui.category.refactoring,Refactor - PHP,PHP
LegacyHandlerWrapper(ActionHandler(action=org.eclipse.php.internal.ui.actions.MoveAction@1557af)),
,,true),null),
- Refactoring ,
,,true),null),
!MESSAGE A conflict occurred for ALT+SHIFT+R:
Binding(ALT+SHIFT+R,
ParameterizedCommand(Command(org.eclipse.jdt.ui.edit.text.ja va.rename.element,Rename
- Refactoring ,
Rename the selected element,
,,true),null),
ParameterizedCommand(Command(org.eclipse.php.ui.edit.text.re name.element,Rename
- Refactoring ,
LegacyHandlerWrapper(ActionHandler(action=org.eclipse.php.internal.ui.actions.RenameAction@12fca35)),
,,true),null),
- Refactoring ,
,,true),null),
Re: Regular exceptions in Eclipse. [message #260005 is a reply to message #259953] Fri, 04 July 2008 02:40 Go to previous messageGo to next message
Well, this looks strange:
> by apt-get. Looks like pdt-all-in-one version conflict with the debian
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
> !STACK 0
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> org.eclipse.php.internal.core.util.DefaultCacheManager.load( Unknown Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> Binding(F3,
> Declaration,
> ,,true),null),
> Binding(F3,
> Selection,
> ,,true),null),
> Binding(F3,
> Declaration,
> ,,true),null),
> - Refactoring ,
> Java,Java Refactoring Actions,true),
> ,,true),null),
> - Refactoring ,
> PHP,PHP Refactoring Actions,true),
> ,,true),null),
> - Refactoring ,
> ,,true),null),
> - Refactoring ,
> ,,true),null),
> - Refactoring ,
> ,,true),null),
> - Refactoring ,
> ,,true),null),
Derek
Re: Regular exceptions in Eclipse. [message #260167 is a reply to message #260005] Sun, 06 July 2008 08:18 Go to previous messageGo to next message
That's right. There is no such file. Eclipse falling down not just because
this error.
I remover the .metadata dir, and start eclipse. Here is the fail log:
!SESSION 2008-07-06 18:47:28.316
!ENTRY org.eclipse.php.core 4 4 2008-07-06 18:52:03.583
!MESSAGE null
!STACK 0
java.lang.ArrayStoreException
at java.util.LinkedList.toArray(LinkedList.java:915)
org.eclipse.php.internal.core.phpModel.parser.VariableContex tBuilder.getPHPVariablesTypeManager(Unknown
Source)
org.eclipse.php.internal.core.phpModel.parser.DefaultParserC lient.finishParsing(Unknown
Source)
org.eclipse.php.internal.core.phpModel.parser.ParserClientCo mposite.finishParsing(Unknown
Source)
org.eclipse.php.internal.core.phpModel.parser.ParserExecuter .run(Unknown
Source)
org.eclipse.php.internal.core.phpModel.parser.PHPParserManag er.parseNow(Unknown
Source)
org.eclipse.php.internal.core.phpModel.parser.management.Pro jectParsingManager.fileAdded(Unknown
Source)
org.eclipse.php.internal.core.phpModel.parser.PHPProjectMode l.fireFileDataAdded(Unknown
Source)
org.eclipse.php.internal.core.phpModel.parser.PHPProjectMode l.addFileToModel(Unknown
Source)
org.eclipse.php.internal.core.phpModel.parser.PHPWorkspaceMo delManager.addFileToModel(Unknown
Source)
org.eclipse.php.internal.core.project.build.PhpResourceDelta BuildVisitor.processFileDelta(Unknown
Source)
org.eclipse.php.internal.core.project.build.PhpResourceDelta BuildVisitor.visit(Unknown
Source)
org.eclipse.core.internal.events.ResourceDelta.accept(Resour ceDelta.java:67)
org.eclipse.core.internal.events.ResourceDelta.accept(Resour ceDelta.java:76)
org.eclipse.core.internal.events.ResourceDelta.accept(Resour ceDelta.java:48)
org.eclipse.php.internal.core.project.build.DefaultPHPBuilde rExtension.buildDelta(Unknown
Source)
org.eclipse.php.internal.core.project.build.DefaultPHPBuilde rExtension.build(Unknown
Source)
org.eclipse.php.internal.core.project.build.PHPIncrementalPr ojectBuilder.internalBuild(Unknown
Source)
org.eclipse.php.internal.core.project.build.PHPIncrementalPr ojectBuilder.build(Unknown
Source)
org.eclipse.core.internal.events.BuildManager$2.run(BuildMan ager.java:624)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:166)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:197)
org.eclipse.core.internal.events.BuildManager$1.run(BuildMan ager.java:246)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:249)
org.eclipse.core.internal.events.BuildManager.basicBuildLoop (BuildManager.java:302)
org.eclipse.core.internal.events.BuildManager.build(BuildMan ager.java:334)
org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBu ildJob.java:137)
org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJ ob.java:235)
!ENTRY org.eclipse.ui 4 4 2008-07-06 18:58:22.952
!MESSAGE Part already exists in page layout:
org.eclipse.debug.ui.PHPStackView.
!ENTRY org.eclipse.osgi 2 1 2008-07-06 19:13:58.025
!MESSAGE NLS missing message: DebugConnectionThread_oldDebuggerVersion in:
!ENTRY org.eclipse.osgi 2 1 2008-07-06 19:13:58.026
!MESSAGE NLS missing message: DebugServerTestEvent_success in:
Here is VM log.
# An unexpected error has been detected by Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x061b9011, pid=4167, tid=3045026704
# Java VM: Java HotSpot(TM) Client VM (10.0-b22 mixed mode, sharing
linux-x86)
# Problematic frame:
# V [libjvm.so+0x1b9011]
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
--------------- T H R E A D ---------------
Current thread (0x0807f800): VMThread [stack: 0xb5776000,0xb57f7000]
[id=4169]
siginfo:si_signo=SIGSEGV: si_errno=0, si_code=1 (SEGV_MAPERR),
si_addr=0x00000064
Registers:
EAX=0x00000008, EBX=0x00015339, ECX=0x00000001, EDX=0x00000001
ESP=0xb57f59e4, EBP=0xb57f59e8, ESI=0x902f32c8, EDI=0x0644053c
EIP=0x061b9011, CR2=0x00000064, EFLAGS=0x00010202
Top of Stack: (sp=0xb57f59e4)
0xb57f59e4: 00015339 b57f5a18 062ee2d9 00015339
0xb57f59f4: 902f32c8 00000003 00000003 902fa3e8
0xb57f5a04: 902fa2c8 b57f5a38 00000003 902fb298
0xb57f5a14: 94f37e80 b57f5a38 061ba129 902fb2a8
0xb57f5a24: 00000041 018c0bc4 00001153 06423308
0xb57f5a34: 00001140 b57f5a68 062ee381 94f37e80
0xb57f5a44: 902fb298 00001140 00001140 b57f5aa0
0xb57f5a54: b57f5ac0 b57f5a88 00000003 0805cfc0
Instructions: (pc=0x061b9011)
0x061b9001: 74 2c 8b 45 0c ba 01 00 00 00 8b 40 04 83 c0 08
0x061b9011: 8b 40 5c 83 e0 07 83 f8 05 74 13 31 d2 49 75 09
Stack: [0xb5776000,0xb57f7000], sp=0xb57f59e4, free space=510k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native
code)
V [libjvm.so+0x2ee2d9]
V [libjvm.so+0x1ba129]
V [libjvm.so+0x2ee381]
V [libjvm.so+0x376816]
V [libjvm.so+0x39e868]
V [libjvm.so+0x345d0d]
V [libjvm.so+0x1e1217]
V [libjvm.so+0x1e3951]
V [libjvm.so+0x1e3192]
V [libjvm.so+0x1eb8b8]
V [libjvm.so+0x1e0e32]
V [libjvm.so+0x1e1d68]
V [libjvm.so+0x3beb8a]
V [libjvm.so+0x3cbaa7]
V [libjvm.so+0x3cb0bc]
V [libjvm.so+0x3cb291]
V [libjvm.so+0x3cae6f]
V [libjvm.so+0x3113f9]
C [libpthread.so.0+0x54fb]
VM_Operation (0xb7e25dcc): GenCollectFull, mode: safepoint, requested by
thread 0x08059000
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x08638000 JavaThread "Timer-8" daemon [_thread_blocked, id=4555,
stack(0xaf51d000,0xaf56e000)]
0x09766000 JavaThread "Timer-7" daemon [_thread_blocked, id=4546,
stack(0xaf801000,0xaf852000)]
0x09a81c00 JavaThread "Timer-6" daemon [_thread_blocked, id=4545,
stack(0xb0db1000,0xb0e02000)]
0x0965f000 JavaThread "Worker-12" [_thread_blocked, id=4544,
stack(0xb0d60000,0xb0db1000)]
0x08e43000 JavaThread "Thread-23" daemon [_thread_in_native, id=4543,
stack(0xb4142000,0xb4193000)]
0x093cf400 JavaThread "Thread-22" daemon [_thread_blocked, id=4542,
stack(0xb03af000,0xb0400000)]
0x0a087c00 JavaThread "Worker-10" [_thread_blocked, id=4345,
stack(0xb013f000,0xb0190000)]
0xb04a7800 JavaThread "Worker-9" [_thread_blocked, id=4344,
stack(0xaf6e2000,0xaf733000)]
0x0995b000 JavaThread "Timer-4" daemon [_thread_blocked, id=4268,
stack(0xaf7b0000,0xaf801000)]
0x095fac00 JavaThread "Timer-1" daemon [_thread_blocked, id=4260,
stack(0xb006b000,0xb00bc000)]
0x099bdc00 JavaThread "Worker-8" [_thread_blocked, id=4252,
stack(0xb40df000,0xb4130000)]
0x09a2e000 JavaThread "PHP Debugger Daemon Thread - Port: 9000" daemon
[_thread_in_native, id=4250, stack(0xb0e02000,0xb0e53000)]
0x09a1f000 JavaThread "PHP Debugger Daemon Thread - Port: 10000" daemon
[_thread_in_native, id=4249, stack(0xb419e000,0xb41ef000)]
0x08aa6800 JavaThread "Java indexing" daemon [_thread_blocked, id=4182,
stack(0xb3f07000,0xb3f58000)]
0x08383000 JavaThread "Start Level Event Dispatcher" daemon
[_thread_blocked, id=4178, stack(0xb473a000,0xb478b000)]
0x0837d400 JavaThread "Framework Event Dispatcher" daemon
[_thread_blocked, id=4177, stack(0xb478b000,0xb47dc000)]
0x0837c800 JavaThread "State Data Manager" daemon [_thread_blocked,
id=4176, stack(0xb47dc000,0xb482d000)]
0x08096400 JavaThread "Low Memory Detector" daemon [_thread_blocked,
id=4174, stack(0xb5477000,0xb54c8000)]
0x0808b800 JavaThread "CompilerThread0" daemon [_thread_blocked,
id=4173, stack(0xb54c8000,0xb5549000)]
0x0808a400 JavaThread "Signal Dispatcher" daemon [_thread_blocked,
id=4172, stack(0xb5549000,0xb559a000)]
0x08082000 JavaThread "Finalizer" daemon [_thread_blocked, id=4171,
stack(0xb56d4000,0xb5725000)]
0x08081000 JavaThread "Reference Handler" daemon [_thread_blocked,
id=4170, stack(0xb5725000,0xb5776000)]
0x08059000 JavaThread "main" [_thread_blocked, id=4168,
stack(0xb7dd7000,0xb7e28000)]
Other Threads:
=>0x0807f800 VMThread [stack: 0xb5776000,0xb57f7000] [id=4169]
0x080a9c00 WatcherThread [stack: 0xb53f6000,0xb5477000] [id=4175]
VM state:at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: ([mutex/lock_event])
[0x08056ce0/0x08056d08] Threads_lock - owner thread: 0x0807f800
[0x080571a0/0x080571b8] Heap_lock - owner thread: 0x08059000
Heap
def new generation total 21312K, used 16294K [0x450c0000, 0x467e0000,
0x4ad00000)
eden space 18944K, 82% used [0x450c0000, 0x45fff848, 0x46340000)
from space 2368K, 28% used [0x46340000, 0x463ea138, 0x46590000)
to space 2368K, 0% used [0x46590000, 0x46590000, 0x467e0000)
tenured generation total 283584K, used 214264K [0x4ad00000, 0x5c1f0000,
0x900c0000)
the space 283584K, 75% used [0x4ad00000, 0x57e3e368, 0x57e3e400,
0x5c1f0000)
compacting perm gen total 45824K, used 45823K [0x900c0000, 0x92d80000,
0x940c0000)
the space 45824K, 99% used [0x900c0000, 0x92d7ff88, 0x92d80000,
0x92d80000)
ro space 8192K, 73% used [0x940c0000, 0x946a34a0, 0x946a3600,
0x948c0000)
rw space 12288K, 58% used [0x948c0000, 0x94fb8668, 0x94fb8800,
0x954c0000)
Dynamic libraries:
06000000-0641b000 r-xp 00000000 08:05 161510
/usr/lib/jvm/java-6-sun-1.6.0.06/jre/lib/i386/client/libjvm. so
0641b000-06435000 rwxp 0041a000 08:05 161510
06435000-06855000 rwxp 06435000 00:00 0
08048000-08052000 r-xp 00000000 08:05 161667
/usr/lib/jvm/java-6-sun-1.6.0.06/jre/bin/java
08052000-08053000 rwxp 00009000 08:05 161667
08053000-0a2bd000 rwxp 08053000 00:00 0 [heap]
450c0000-467e0000 rwxp 450c0000 00:00 0
467e0000-4ad00000 rwxp 467e0000 00:00 0
4ad00000-5c1f0000 rwxp 4ad00000 00:00 0
5c1f0000-900c0000 rwxp 5c1f0000 00:00 0
900c0000-92d80000 rwxp 900c0000 00:00 0
92d80000-940c0000 rwxp 92d80000 00:00 0
940c0000-946a4000 r-xs 00001000 08:05 161936
/usr/lib/jvm/java-6-sun-1.6.0.06/jre/lib/i386/client/classes .jsa
946a4000-948c0000 rwxp 946a4000 00:00 0
948c0000-94fb9000 rwxp 005e5000 08:05 161936
94fb9000-954c0000 rwxp 94fb9000 00:00 0
954c0000-95599000 rwxp 00cde000 08:05 161936
95599000-958c0000 rwxp 95599000 00:00 0
958c0000-958c4000 r-xs 00db7000 08:05 161936
958c4000-95cc0000 rwxp 958c4000 00:00 0
ac436000-ac437000 ---p ac436000 00:00 0
ac437000-acf37000 rwxp ac437000 00:00 0
acf37000-adc37000 ---p acf37000 00:00 0
adc37000-ae3af000 r-xp 00000000 08:09 606857
/home/screw/.mozilla/plugins/libflashplayer.so
ae3af000-ae3f3000 rwxp 00777000 08:09 606857
ae3f3000-ae4ca000 rwxp ae3f3000 00:00 0
ae4ca000-ae4cb000 ---p ae4ca000 00:00 0
ae4cb000-aeccb000 rwxp ae4cb000 00:00 0
aeccb000-aeccc000 ---p aeccb000 00:00 0
aeccc000-af4cc000 rwxp aeccc000 00:00 0
af4cc000-af4cf000 rwxp af4cc000 00:00 0
af4cf000-af51d000 rwxp af4cf000 00:00 0
af51d000-af520000 ---p af51d000 00:00 0
af520000-af56e000 rwxp af520000 00:00 0
af56e000-af570000 r-xp 00000000 08:02 3555 /lib/libkeyutils-1.2.so
af570000-af571000 rwxp 00001000 08:02 3555 /lib/libkeyutils-1.2.so
af571000-af578000 r-xp 00000000 08:05 15317
/usr/lib/libkrb5support.so.0.1
af578000-af579000 rwxp 00006000 08:05 15317
af579000-af582000 r-xp 00000000 08:02 3495
/lib/i686/cmov/libcrypt-2.7.so
af582000-af584000 rwxp 00008000 08:02 3495
af584000-af5ab000 rwxp af584000 00:00 0
af5ab000-af5cd000 r-xp 00000000 08:05 15314
/usr/lib/libk5crypto.so.3.1
af5cd000-af5ce000 rwxp 00022000 08:05 15314
af5ce000-af65a000 r-xp 00000000 08:05 15316 /usr/lib/libkrb5.so.3.3
af65a000-af65c000 rwxp 0008c000 08:05 15316 /usr/lib/libkrb5.so.3.3
af65c000-af684000 r-xp 00000000 08:05 15313
/usr/lib/libgssapi_krb5.so.2.2
af684000-af685000 rwxp 00028000 08:05 15313
af685000-af6b8000 r-xp 00000000 08:05 15340 /usr/lib/libcups.so.2
af6b8000-af6ba000 rwxp 00033000 08:05 15340 /usr/lib/libcups.so.2
af6c0000-af6c4000 r-xp 00000000 08:02 3501
/lib/i686/cmov/libnss_dns-2.7.so
af6c4000-af6c6000 rwxp 00003000 08:02 3501
af6c6000-af6c8000 r-xp 00000000 08:02 4354
/lib/libnss_mdns4_minimal.so.2
af6c8000-af6c9000 rwxp 00001000 08:02 4354
af6cd000-af6d9000 r-xp 00000000 08:05 27575
/usr/lib/gtk-2.0/2.10.0/printbackends/libprintbackend-cups.s o
af6d9000-af6da000 rwxp 0000b000 08:05 27575
af6da000-af6dd000 r-xp 00000000 08:05 27577
/usr/lib/gtk-2.0/2.10.0/printbackends/libprintbackend-file.s o
af6dd000-af6de000 rwxp 00002000 08:05 27577
af6de000-af6e2000 r-xs 000ca000 08:05 161329
/usr/lib/jvm/java-6-sun-1.6.0.06/jre/lib/ext/localedata.jar
af6e2000-af6e5000 ---p af6e2000 00:00 0
af6e5000-af733000 rwxp af6e5000 00:00 0
af7b0000-af7b3000 ---p af7b0000 00:00 0
af7b3000-af801000 rwxp af7b3000 00:00 0
af801000-af804000 ---p af801000 00:00 0
af804000-af852000 rwxp af804000 00:00 0
af852000-af855000 r-xs 0000c000 08:09 604972
/home/screw/eclipse/plugins/org.eclipse.wst.javascript.core_ 1.0.101.v200706071955.jar
af855000-af85d000 r-xs 00055000 08:09 604887
/home/screw/eclipse/plugins/org.eclipse.jst.jsp.ui_1.1.201.v 200709061102.jar
af85d000-af865000 r-xs 00052000 08:09 605095
/home/screw/eclipse/plugins/org.eclipse.datatools.sqltools.s qleditor_1.0.0.200709061.jar
af865000-af874000 r-xs 000a9000 08:09 604979
/home/screw/eclipse/plugins/org.eclipse.wst.xml.ui_1.0.302.v 200802140626.jar
af8f1000-af8f2000 r-xs 00003000 08:09 605793
/home/screw/eclipse/plugins/org.eclipse.php.server.core_1.0. 3.v20080603.jar
af8f2000-af8fe000 r-xs 00054000 08:09 605795
/home/screw/eclipse/plugins/org.eclipse.php.debug.core_1.0.3 .v20080603.jar
afb00000-afb29000 rwxp afb00000 00:00 0
afb29000-afc00000 ---p afb29000 00:00 0
afc39000-afcce000 r-xp 00000000 08:05 15537
/usr/share/fonts/truetype/ttf-dejavu/DejaVuSans.ttf
afcce000-afcd0000 r-xp 00000000 08:05 27503
/usr/lib/pango/1.6.0/modules/pango-syriac-fc.so
afcd0000-afcd1000 rwxp 00001000 08:05 27503
afcd1000-aff81000 rwxp afcd1000 00:00 0
aff81000-b003e000 r-xp 00000000 08:05 29385
/usr/lib/libasound.so.2.0.0
b003e000-b0043000 rwxp 000bc000 08:05 29385
b0051000-b0053000 r-xp 00000000 08:05 27502
/usr/lib/pango/1.6.0/modules/pango-arabic-fc.so
b0053000-b0054000 rwxp 00001000 08:05 27502
b0054000-b0055000 r-xp 00000000 08:05 27513
/usr/lib/pango/1.6.0/modules/pango-arabic-lang.so
b0055000-b0056000 rwxp 00000000 08:05 27513
b0068000-b006a000 r-xp 00000000 08:02 230 /lib/libcom_err.so.2.1
b006a000-b006b000 rwxp 00001000 08:02 230 /lib/libcom_err.so.2.1
b006b000-b006e000 ---p b006b000 00:00 0
b006e000-b00bc000 rwxp b006e000 00:00 0
b013c000-b013e000 r-xp 00000000 08:05 27505
/usr/lib/pango/1.6.0/modules/pango-hangul-fc.so
b013e000-b013f000 rwxp 00001000 08:05 27505
b013f000-b0142000 ---p b013f000 00:00 0
b0142000-b0190000 rwxp b0142000 00:00 0
b0190000-b0192000 r-xs 00009000 08:09 604908
/home/screw/eclipse/plugins/org.eclipse.wst.internet.cache_1 .0.201.v200705302225.jar
b0192000-b0194000 r-xs 0001d000 08:09 604875
/home/screw/eclipse/plugins/org.eclipse.wst.standard.schemas _1.0.1.v200705302225.jar
b0194000-b0196000 r-xs 00034000 08:09 605004
/home/screw/eclipse/plugins/org.eclipse.jst.standard.schemas _1.0.0.v200706221355.jar
b0196000-b01ae000 r-xs 000fc000 08:09 604952
/home/screw/eclipse/plugins/org.eclipse.wst.xsd.ui_1.2.2.v20 0802141800.jar
b01ae000-b01b0000 r-xs 00008000 08:09 604699
/home/screw/eclipse/plugins/org.eclipse.wst.common.uriresolv er_1.1.203.v200802200327.jar
b01b0000-b01b2000 r-xs 00016000 08:09 605705
/home/screw/eclipse/plugins/org.eclipse.ant.core_3.1.200.v20 070522.jar
b01b2000-b01b7000 r-xs 00037000 08:09 604922
/home/screw/eclipse/plugins/org.eclipse.wst.css.ui_1.0.201.v 200705302225.jar
b01b7000-b01ba000 r-xp 00000000 08:02 135 /lib/libattr.so.1.1.0
b01ba000-b01bb000 rwxp 00002000 08:02 135 /lib/libattr.so.1.1.0
b01bb000-b01c3000 r-xp 00000000 08:05 28275 /usr/lib/libfam.so.0.0.0
b01c3000-b01c4000 rwxp 00007000 08:05 28275 /usr/lib/libfam.so.0.0.0
b01c4000-b01ca000 r-xp 00000000 08:02 131 /lib/libacl.so.1.1.0
b01ca000-b01cb000 rwxp 00005000 08:02 131 /lib/libacl.so.1.1.0
b01cb000-b01cc000 r-xp b01cb000 00:00 0
b01cc000-b01de000 r-xs 0007f000 08:09 604742
/home/screw/eclipse/plugins/org.eclipse.wst.javascript.ui_1. 0.103.v200802142230.jar
b01de000-b01ea000 r-xp 00000000 08:05 28683
/usr/lib/gnome-vfs-2.0/modules/libfile.so
b01ea000-b01eb000 rwxp 0000b000 08:05 28683
b01eb000-b01fc000 r-xs 00000000 08:05 46382 /usr/share/mime/mime.cache
b01fc000-b01ff000 r-xp 00000000 08:09 26617
/home/screw/eclipse/configuration/org.eclipse.osgi/bundles/1 88/1/.cp/libswt-gnome-gtk-3349.so
b01ff000-b0200000 rwxp 00002000 08:09 26617
b0200000-b020e000 r-xs 00087000 08:09 604700
/home/screw/eclipse/plugins/org.eclipse.wst.html.core_1.1.10 3.v200801092102.jar
b020e000-b0218000 r-xs 00072000 08:09 604871
/home/screw/eclipse/plugins/org.eclipse.wst.css.core_1.1.102 .v200710121808.jar
b0218000-b021b000 r-xs 00011000 08:09 605788
/home/screw/eclipse/plugins/org.eclipse.php.server.ui_1.0.3. v20080603.jar
b021b000-b022c000 r-xs 000f9000 08:09 605772
/home/screw/eclipse/plugins/org.eclipse.ant.ui_3.2.200.v2007 0825_r331.jar
b022c000-b0230000 r-xs 00026000 08:09 605139
/home/screw/eclipse/plugins/org.eclipse.datatools.sqltools.r outineeditor_1.0.0.200708161.jar
b0230000-b0233000 r-xs 0000d000 08:09 604886
/home/screw/eclipse/plugins/org.eclipse.jst.server.generic.u i_1.0.205.v200709061325.jar
b0233000-b023d000 r-xs 0006f000 08:09 605782
/home/screw/eclipse/plugins/org.eclipse.jdt.junit_3.3.2.r332 _20080109-0800.jar
b023d000-b0246000 r-xs 0003b000 08:09 605787
/home/screw/eclipse/plugins/org.eclipse.php.debug.ui_1.0.3.v 20080603.jar
b0246000-b024a000 r-xs 0001a000 08:09 604896
/home/screw/eclipse/plugins/org.eclipse.jst.server.tomcat.ui _1.1.0.v200705302225.jar
b024a000-b024c000 r-xs 00009000 08:09 604926
/home/screw/eclipse/plugins/org.eclipse.jst.server.preview.a dapter_1.0.2.v20071017b.jar
b024c000-b0264000 r-xs 00120000 08:09 605780
/home/screw/eclipse/plugins/org.eclipse.jdt.debug.ui_3.2.102 .v20071002_r332.jar
b0264000-b0266000 r-xs 00008000 08:09 604867
/home/screw/eclipse/plugins/org.eclipse.wst.server.preview.a dapter_1.0.1.v20070814b.jar
b0266000-b026a000 r-xs 00022000 08:09 605704
/home/screw/eclipse/plugins/org.eclipse.ui.console_3.2.2.v20 071031_r332.jar
b026a000-b0272000 r-xs 0005c000 08:09 604885
/home/screw/eclipse/plugins/org.eclipse.wst.dtd.core_1.1.101 .v200705302225.jar
b0272000-b0280000 r-xs 000a4000 08:09 604970
/home/screw/eclipse/plugins/org.eclipse.wst.sse.ui_1.0.305.v 200802142230.jar
b0280000-b0286000 r-xs 00033000 08:09 604980
/home/screw/eclipse/plugins/org.eclipse.wst.html.ui_1.0.202. v200708292012.jar
b0286000-b0288000 r-xs 0000f000 08:09 604901
/home/screw/eclipse/plugins/org.eclipse.wst.xsd.core_1.1.202 .v200710011705.jar
b0288000-b028a000 r-xs 00010000 08:09 604916
/home/screw/eclipse/plugins/org.eclipse.wst.wsi.ui_1.0.300.v 200706062140.jar
b028a000-b028e000 r-xs 00019000 08:09 604915
/home/screw/eclipse/plugins/javax.wsdl_1.4.0.v200706111329.j ar
b028e000-b02ab000 r-xs 0013b000 08:09 604913
/home/screw/eclipse/plugins/org.apache.xerces_2.8.0.v2007053 01630.jar
b02ab000-b02af000 r-xs 00029000 08:09 604994
/home/screw/eclipse/plugins/org.eclipse.wst.wsdl.validation_ 1.1.201.v200706062140.jar
b02af000-b02b5000 r-xs 0003f000 08:09 605010
/home/screw/eclipse/plugins/org.eclipse.wst.common.modulecor e_1.1.104.v200802192030.jar
b02b5000-b02c2000 r-xs 0008f000 08:09 604863
/home/screw/eclipse/plugins/org.eclipse.wst.xml.core_1.1.202 .v200802140626.jar
b02c2000-b02c6000 r-xs 0001f000 08:09 604831
/home/screw/eclipse/plugins/org.eclipse.jem.ui_2.0.0.v200705 302225.jar
b02c6000-b02cc000 r-xs 0003e000 08:09 604989
/home/screw/eclipse/plugins/org.eclipse.jem_2.0.100.v2007090 51030.jar
b0319000-b0349000 r-xp 00000000 08:05 95133
/usr/share/fonts/X11/misc/cu12.pcf.gz
b0349000-b036f000 r-xs 0021c000 08:09 604661
/home/screw/eclipse/plugins/org.eclipse.jst.j2ee.core_1.1.10 4.v200802192030.jar
b036f000-b038d000 r-xs 0016a000 08:09 604883
/home/screw/eclipse/plugins/org.eclipse.jst.j2ee_1.1.106.v20 0802192030.jar
b038d000-b0390000 r-xs 0000d000 08:09 604899
/home/screw/eclipse/plugins/org.eclipse.jst.common.framework s_1.1.102.v200709122200.jar
b0390000-b0393000 r-xs 0000b000 08:09 604965
/home/screw/eclipse/plugins/org.eclipse.wst.web.ui_1.1.101.v 200706071630.jar
b0393000-b03a1000 r-xs 000b3000 08:09 604957
/home/screw/eclipse/plugins/org.eclipse.jst.j2ee.ui_1.1.103. v200802192030.jar
b03a1000-b03a4000 r-xs 00019000 08:09 604978
/home/screw/eclipse/plugins/org.eclipse.jst.servlet.ui_1.1.1 03.v200802192030.jar
b03a4000-b03a8000 r-xs 0002d000 08:09 604881
/home/screw/eclipse/plugins/org.eclipse.wst.validation_1.1.1 02.v200709122200.jar
b03a8000-b03ac000 r-xs 00021000 08:09 604932
/home/screw/eclipse/plugins/org.eclipse.jst.j2ee.navigator.u i_1.1.102.v200709122200.jar
b03ac000-b03ae000 r-xp 00000000 08:09 605847
/home/screw/eclipse/configuration/org.eclipse.osgi/bundles/2 09/1/.cp/os/linux/x86/liblocalfile_1_0_0.so
b03ae000-b03af000 rwxp 00001000 08:09 605847
b03af000-b03b2000 ---p b03af000 00:00 0
b03b2000-b04fd000 rwxp b03b2000 00:00 0
b04fd000-b0500000 ---p b04fd000 00:00 0
b0500000-b0502000 r-xs 00010000 08:09 604999
/home/screw/eclipse/plugins/org.eclipse.jem.workbench_2.0.1. v200710051600.jar
b0502000-b0503000 r-xs 00005000 08:09 605717
/home/screw/eclipse/plugins/org.eclipse.core.filesystem.linu x.x86_1.1.0.v20070416.jar
b0503000-b0505000 r-xs 00009000 08:09 605593
/home/screw/eclipse/plugins/org.eclipse.core.filesystem_1.1. 0.v20070606.jar
b0505000-b0507000 r-xs 00009000 08:09 604942
/home/screw/eclipse/plugins/org.eclipse.wst.common.environme nt_1.0.200.v200705302225.jar
b0507000-b050b000 r-xs 0001e000 08:09 604870
/home/screw/eclipse/plugins/org.eclipse.wst.common.framework s.ui_1.1.101.v200709122200.jar
b050b000-b050c000 ---p b050b000 00:00 0
b050c000-b0d0c000 rwxp b050c000 00:00 0
b0d0c000-b0d1d000 r-xs 000da000 08:09 605791
/home/screw/eclipse/plugins/org.eclipse.php.core_1.0.3.v2008 0603.jar
b0d1d000-b0d27000 r-xs 0008a000 08:09 605718
/home/screw/eclipse/plugins/org.eclipse.update.core_3.2.101. R33x_v20070911.jar
b0d27000-b0d30000 r-xs 00057000 08:09 604909
/home/screw/eclipse/plugins/org.eclipse.wst.sse.core_1.1.203 .v200802140626.jar
b0d30000-b0d53000 r-xs 00148000 08:09 605789
/home/screw/eclipse/plugins/org.eclipse.php.ui_1.0.3.v200806 03.jar
b0d53000-b0d60000 r-xs 0007c000 08:09 604976
/home/screw/eclipse/plugins/org.eclipse.jst.jsf.core_1.0.2.v 200802201120.jar
b0d60000-b0d63000 ---p b0d60000 00:00 0
b0d63000-b0db1000 rwxp b0d63000 00:00 0
b0db1000-b0db4000 ---p b0db1000 00:00 0
b0db4000-b0e02000 rwxp b0db4000 00:00 0
b0e02000-b0e05000 ---p b0e02000 00:00 0
b0e05000-b0e53000 rwxp b0e05000 00:00 0
b0e6a000-b0e9e000 r-xp 00000000 08:05 15563
/usr/share/fonts/truetype/ttf-dejavu/DejaVuSansMono-BoldObli que.ttf
b0e9e000-b0e9f000 ---p b0e9e000 00:00 0
b0e9f000-b169f000 rwxp b0e9f000 00:00 0
b169f000-b16a1000 r-xs 00001000 08:05 161328
/usr/lib/jvm/java-6-sun-1.6.0.06/jre/lib/ext/dnsns.jar
b16a1000-b16a7000 r-xs 00091000 08:05 161325
/usr/lib/jvm/java-6-sun-1.6.0.06/jre/lib/jsse.jar
b16a7000-b16a8000 ---p b16a7000 00:00 0
b16a8000-b1ea8000 rwxp b16a8000 00:00 0
b1ea8000-b1eb2000 r-xp 00000000 08:05 28762
/usr/share/locale/ru/LC_MESSAGES/libgnome-2.0.mo
b1eb2000-b1ec7000 r-xp 00000000 08:05 28150
/usr/share/locale/ru/LC_MESSAGES/GConf2.mo
b1ec7000-b1ec8000 ---p b1ec7000 00:00 0
b1ec8000-b26c8000 rwxp b1ec8000 00:00 0
b26c8000-b26dc000 r-xp 00000000 08:05 41967 /usr/lib/libnssutil3.so.1d
b26dc000-b26df000 rwxp 00013000 08:05 41967 /usr/lib/libnssutil3.so.1d
b26df000-b27f9000 r-xp 00000000 08:05 41966 /usr/lib/libnss3.so.1d
b27f9000-b27fe000 rwxp 0011a000 08:05 41966 /usr/lib/libnss3.so.1d
b27fe000-b2820000 r-xp 00000000 08:05 41968 /usr/lib/libsmime3.so.1d
b2820000-b2822000 rwxp 00022000 08:05 41968 /usr/lib/libsmime3.so.1d
b2822000-b284b000 r-xp 00000000 08:05 41969 /usr/lib/libssl3.so.1d
b284b000-b284d000 rwxp 00029000 08:05 41969 /usr/lib/libssl3.so.1d
b284d000-b284f000 r-xs 00006000 08:09 605714
/home/screw/eclipse/plugins/org.eclipse.update.scheduler_3.2 .100.v20070615.jar
b284f000-b2850000 r-xs 00002000 08:09 605792
/home/screw/eclipse/plugins/org.eclipse.php.debug.daemon_1.0 .3.v20080603.jar
b2850000-b2852000 r-xs 00008000 08:09 605715
/home/screw/eclipse/plugins/org.eclipse.ui.net_1.0.0.I200705 16.jar
b2852000-b2858000 r-xs 00040000 08:09 605288
/home/screw/eclipse/plugins/org.eclipse.ui.forms_3.3.0.v2007 0511.jar
b2858000-b285f000 r-xp 00000000 08:05 48613
/usr/lib/xulrunner/components/libpippki.so
b285f000-b2860000 rwxp 00006000 08:05 48613
b2860000-b28b9000 r-xp 00000000 08:05 48612
/usr/lib/xulrunner/components/libpipnss.so
b28b9000-b28bd000 rwxp 00059000 08:05 48612
b28bd000-b28c2000 r-xp 00000000 08:05 48645
/usr/lib/xulrunner/components/libnkgnomevfs.so
b28c2000-b28c3000 rwxp 00004000 08:05 48645
b28c3000-b28cb000 r-xp 00000000 08:05 48607
/usr/lib/xulrunner/components/libcookie.so
b28cb000-b28cc000 rwxp 00007000 08:05 48607
b28cc000-b28d2000 r-xp 00000000 08:05 48608
/usr/lib/xulrunner/components/libfileview.so
b28d2000-b28d3000 rwxp 00005000 08:05 48608
b28d3000-b28e2000 r-xp 00000000 08:05 48614
/usr/lib/xulrunner/components/libspellchecker.so
b28e2000-b28e3000 rwxp 0000f000 08:05 48614
b28e3000-b28f4000 r-xp 00000000 08:05 48617
/usr/lib/xulrunner/components/libuniversalchardet.so
b28f4000-b28fe000 rwxp 00011000 08:05 48617
b28fe000-b294d000 r-xp 00000000 08:05 48616
/usr/lib/xulrunner/components/libtransformiix.so
b294d000-b2951000 rwxp 0004f000 08:05 48616
b2951000-b29c4000 r-xp 00000000 08:05 48618
/usr/lib/xulrunner/components/libwebsrvcs.so
b29c4000-b29ca000 rwxp 00072000 08:05 48618
b29ca000-b2a08000 r-xp 00000000 08:05 47575
/usr/lib/libhunspell-1.2.so.0.0.0
b2a08000-b2a0c000 rwxp 0003e000 08:05 47575
b2a0c000-b2a11000 r-xp 00000000 08:05 48619
/usr/lib/xulrunner/components/libxmlextras.so
b2a11000-b2a12000 rwxp 00004000 08:05 48619
b2a12000-b2a14000 r-xp 00000000 08:05 48620
/usr/lib/xulrunner/components/libxulutil.so
b2a14000-b2a15000 rwxp 00001000 08:05 48620
b2a15000-b2a19000 r-xp 00000000 08:05 48644
/usr/lib/xulrunner/components/libmozgnome.so
b2a19000-b2a1a000 rwxp 00003000 08:05 48644
b2a1a000-b2a1e000 r-xp 00000000 08:05 48605
/usr/lib/xulrunner/components/libauth.so
b2a1e000-b2a1f000 rwxp 00004000 08:05 48605
b2a1f000-b2a23000 r-xp 00000000 08:05 48609
/usr/lib/xulrunner/components/libmyspell.so
b2a23000-b2a24000 rwxp 00004000 08:05 48609
b2a24000-b2a28000 r-xp 00000000 08:05 27960
/usr/lib/libORBitCosNaming-2.so.0.1.0
b2a28000-b2a29000 rwxp 00003000 08:05 27960
b2a29000-b2a8f000 r-xp 00000000 08:05 3764
/usr/lib/libgcrypt.so.11.4.4
b2a8f000-b2a91000 rwxp 00066000 08:05 3764
b2a91000-b2a94000 r-xp 00000000 08:05 3816
/usr/lib/libgpg-error.so.0.3.0
b2a94000-b2a95000 rwxp 00002000 08:05 3816
b2a95000-b2aa4000 r-xp 00000000 08:05 4054
/usr/lib/libtasn1.so.3.0.15
b2aa4000-b2aa5000 rwxp 0000e000 08:05 4054
b2aa5000-b2aab000 r-xp 00000000 08:05 28892
/usr/lib/libgailutil.so.18.0.1
b2aab000-b2aac000 rwxp 00006000 08:05 28892
b2aac000-b2af5000 r-xp 00000000 08:05 27961
/usr/lib/libORBit-2.so.0.1.0
b2af5000-b2afe000 rwxp 00049000 08:05 27961
b2afe000-b2aff000 rwxp b2afe000 00:00 0
b2aff000-b2b07000 r-xp 00000000 08:02 793 /lib/libpopt.so.0.0.0
b2b07000-b2b08000 rwxp 00007000 08:02 793 /lib/libpopt.so.0.0.0
b2b08000-b2b28000 r-xp 00000000 08:05 28231
/usr/lib/libaudiofile.so.0.0.2
b2b28000-b2b2b000 rwxp 0001f000 08:05 28231
b2b2b000-b2b33000 r-xp 00000000 08:05 28254 /usr/lib/libesd.so.0.2.36
b2b33000-b2b34000 rwxp 00007000 08:05 28254 /usr/lib/libesd.so.0.2.36
b2b34000-b2b46000 r-xp 00000000 08:05 27979
/usr/lib/libbonobo-activation.so.4.0.0
b2b46000-b2b48000 rwxp 00012000 08:05 27979
b2b48000-b2b9a000 r-xp 00000000 08:05 27980
/usr/lib/libbonobo-2.so.0.0.0
b2b9a000-b2ba4000 rwxp 00051000 08:05 27980
b2ba4000-b2ba6000 r-xp 00000000 08:02 3512
/lib/i686/cmov/libutil-2.7.so
b2ba6000-b2ba8000 rwxp 00001000 08:02 3512
b2ba8000-b2bb7000 r-xp 00000000 08:02 3508
/lib/i686/cmov/libresolv-2.7.so
b2bb7000-b2bb9000 rwxp 0000f000 08:02 3508
b2bb9000-b2bbb000 rwxp b2bb9000 00:00 0
b2bbb000-b2bc9000 r-xp 00000000 08:05 15296
/usr/lib/libavahi-client.so.3.2.4
b2bc9000-b2bca000 rwxp 0000e000 08:05 15296
b2bca000-b2bd4000 r-xp 00000000 08:05 15279
/usr/lib/libavahi-common.so.3.5.0
b2bd4000-b2bd5000 rwxp 0000a000 08:05 15279
b2bd5000-b2bd7000 r-xp 00000000 08:05 28264
/usr/lib/libavahi-glib.so.1.0.1
b2bd7000-b2bd8000 rwxp 00001000 08:05 28264
b2bd8000-b2c4b000 r-xp 00000000 08:05 3810
/usr/lib/libgnutls.so.26.1.6
b2c4b000-b2c51000 rwxp 00072000 08:05 3810
b2c51000-b2c86000 r-xp 00000000 08:05 15288
/usr/lib/libdbus-1.so.3.4.0
b2c86000-b2c88000 rwxp 00034000 08:05 15288
b2c88000-b2ca3000 r-xp 00000000 08:05 19588
/usr/lib/libdbus-glib-1.so.2.1.0
b2ca3000-b2ca4000 rwxp 0001b000 08:05 19588
b2ca4000-b2dbd000 r-xp 00000000 08:05 14417 /usr/lib/libxml2.so.2.6.32
b2dbd000-b2dc2000 rwxp 00119000 08:05 14417 /usr/lib/libxml2.so.2.6.32
b2dc2000-b2dc3000 rwxp b2dc2000 00:00 0
b2dc3000-b2dd2000 r-xp 00000000 08:05 29012
/usr/lib/libgnome-keyring.so.0.1.1
b2dd2000-b2dd3000 rwxp 0000e000 08:05 29012
b2dd3000-b2e02000 r-xp 00000000 08:05 28221
/usr/lib/libgconf-2.so.4.1.5
b2e02000-b2e05000 rwxp 0002e000 08:05 28221
b2e05000-b2e1a000 r-xp 00000000 08:05 27820
/usr/lib/libart_lgpl_2.so.2.3.20
b2e1a000-b2e1b000 rwxp 00014000 08:05 27820
b2e1b000-b2e4a000 r-xp 00000000 08:05 28998
/usr/lib/libgnomecanvas-2.so.0.2001.0
b2e4a000-b2e4b000 rwxp 0002f000 08:05 28998
b2e4b000-b2ea6000 r-xp 00000000 08:05 29004
/usr/lib/libbonoboui-2.so.0.0.0
b2ea6000-b2ea9000 rwxp 0005a000 08:05 29004
b2ea9000-b2ebd000 r-xp 00000000 08:05 28802
/usr/lib/libgnome-2.so.0.1999.2
b2ebd000-b2ebe000 rwxp 00013000 08:05 28802
b2ebe000-b2f14000 r-xp 00000000 08:05 28678
/usr/lib/libgnomevfs-2.so.0.2200.0
b2f14000-b2f17000 rwxp 00055000 08:05 28678
b2f17000-b2f9e000 r-xp 00000000 08:05 29123
/usr/lib/libgnomeui-2.so.0.2000.1
b2f9e000-b2fa2000 rwxp 00086000 08:05 29123
b2fa2000-b2fa3000 r-xs 00007000 08:09 605712
/home/screw/eclipse/plugins/org.eclipse.core.net_1.0.1.r33x_ 20070709.jar
b2fa3000-b2fa5000 r-xp 00000000 08:05 48610
/usr/lib/xulrunner/components/libpermissions.so
b2fa5000-b2fa6000 rwxp 00002000 08:05 48610
b2fa6000-b2fad000 r-xp 00000000 08:05 48611
/usr/lib/xulrunner/components/libpipboot.so
b2fad000-b2fae000 rwxp 00006000 08:05 48611
b2fae000-b2fb4000 r-xp 00000000 08:05 48606
/usr/lib/xulrunner/components/libautoconfig.so
b2fb4000-b2fb5000 rwxp 00006000 08:05 48606
b2fb5000-b2fbc000 r-xp 00000000 08:05 48643
/usr/lib/xulrunner/components/libimgicon.so
b2fbc000-b2fbd000 rwxp 00006000 08:05 48643
b2fbd000-b2fc2000 r-xp 00000000 08:05 48615
/usr/lib/xulrunner/components/libsystem-pref.so
b2fc2000-b2fc3000 rwxp 00004000 08:05 48615
b2fc3000-b2fd7000 r-xp 00000000 08:05 20658 /usr/lib/libICE.so.6.3.0
b2fd7000-b2fd8000 rwxp 00014000 08:05 20658 /usr/lib/libICE.so.6.3.0
b2fd8000-b2fda000 rwxp b2fd8000 00:00 0
b2fda000-b3026000 r-xp 00000000 08:05 20670 /usr/lib/libXt.so.6.0.0
b3026000-b3029000 rwxp 0004c000 08:05 20670 /usr/lib/libXt.so.6.0.0
b3029000-b302a000 rwxp b3029000 00:00 0
b302a000-b303c000 r-xp 00000000 08:05 20889 /usr/lib/libXft.so.2.1.2
b303c000-b303d000 rwxp 00011000 08:05 20889 /usr/lib/libXft.so.2.1.2
b303d000-b306e000 r-xp 00000000 08:05 41944 /usr/lib/libnspr4.so.0d
b306e000-b306f000 rwxp 00031000 08:05 41944 /usr/lib/libnspr4.so.0d
b306f000-b3071000 rwxp b306f000 00:00 0
b3071000-b3116000 r-xp 00000000 08:05 47609 /usr/lib/libmozjs.so.0d
b3116000-b311b000 rwxp 000a5000 08:05 47609 /usr/lib/libmozjs.so.0d
b311b000-b3139000 r-xp 00000000 08:05 15341 /usr/lib/libjpeg.so.62.0.0
b3139000-b313a000 rwxp 0001e000 08:05 15341 /usr/lib/libjpeg.so.62.0.0
b313a000-b3c72000 r-xp 00000000 08:05 48621 /usr/lib/libxul.so.0d
b3c72000-b3d1d000 rwxp 00b38000 08:05 48621 /usr/lib/libxul.so.0d
b3d1d000-b3d26000 rwxp b3d1d000 00:00 0
b3d26000-b3d28000 r-xp 00000000 08:05 4209 /usr/lib/gconv/UTF-16.so
b3d28000-b3d2a000 rwxp 00001000 08:05 4209 /usr/lib/gconv/UTF-16.so
b3d2a000-b3d37000 r-xp 00000000 08:09 605861
/home/screw/eclipse/configuration/org.eclipse.osgi/bundles/1 88/1/.cp/libswt-xulrunner-gtk-3349.so
b3d37000-b3d39000 rwxp 0000c000 08:09 605861
b3d39000-b3d45000 r-xp 00000000 08:02 233 /lib/libgcc_s.so.1
b3d45000-b3d46000 rwxp 0000b000 08:02 233 /lib/libgcc_s.so.1
b3d46000-b3e28000 r-xp 00000000 08:05 1500
/usr/lib/libstdc++.so.6.0.10
b3e28000-b3e2b000 r-xp 000e2000 08:05 1500
b3e2b000-b3e2d000 rwxp 000e5000 08:05 1500
b3e2d000-b3e34000 rwxp b3e2d000 00:00 0
b3e34000-b3e3b000 r-xp 00000000 08:05 20664 /usr/lib/libSM.so.6.0.0
b3e3b000-b3e3c000 rwxp 00006000 08:05 20664 /usr/lib/libSM.so.6.0.0
b3e3c000-b3e3f000 r-xp 00000000 08:05 41945 /usr/lib/libplc4.so.0d
b3e3f000-b3e40000 rwxp 00002000 08:05 41945 /usr/lib/libplc4.so.0d
b3e40000-b3e42000 r-xp 00000000 08:05 41946 /usr/lib/libplds4.so.0d
b3e42000-b3e43000 rwxp 00001000 08:05 41946 /usr/lib/libplds4.so.0d
b3e43000-b3e45000 r-xp 00000000 08:05 48622 /usr/lib/libxpcom.so.0d
b3e45000-b3e46000 rwxp 00002000 08:05 48622 /usr/lib/libxpcom.so.0d
b3e46000-b3e4b000 r-xp 00000000 08:09 605860
/home/screw/eclipse/configuration/org.eclipse.osgi/bundles/1 88/1/.cp/libswt-xpcominit-gtk-3349.so
b3e4b000-b3e4d000 rwxp 00005000 08:09 605860
b3e4d000-b3e52000 r-xs 0003f000 08:09 605606
/home/screw/eclipse/plugins/org.eclipse.ui.intro_3.2.101.v20 070827_33x.jar
b3e52000-b3e55000 r-xs 00013000 08:09 605589
/home/screw/eclipse/plugins/org.eclipse.ui.intro.universal_3 .2.100.v20070530A/universal.jar
b3e55000-b3e5c000 r-xs 00042000 08:09 605731
/home/screw/eclipse/plugins/org.eclipse.debug.core_3.3.2.v20 080117_r332.jar
b3e5c000-b3e6d000 r-xs 000a6000 08:09 604990
/home/screw/eclipse/plugins/org.eclipse.wst.server.ui_1.0.20 6.v20080206b.jar
b3e6d000-b3e70000 r-xs 00020000 08:09 605728
/home/screw/eclipse/plugins/org.eclipse.ui.externaltools_3.1 .200.v20070416.jar
b3e70000-b3e78000 r-xs 00056000 08:09 605607
/home/screw/eclipse/plugins/org.eclipse.team.core_3.3.1.r33x _20080128.jar
b3e78000-b3e7b000 r-xs 00018000 08:09 605648
/home/screw/eclipse/plugins/org.eclipse.core.filebuffers_3.3 .1.r331_v20070829.jar
b3e7b000-b3e81000 r-xs 00034000 08:09 604924
/home/screw/eclipse/plugins/org.eclipse.wst.common.project.f acet.core_1.2.2.v200802200327.jar
b3e81000-b3e85000 r-xs 0002b000 08:09 605025
/home/screw/eclipse/plugins/org.eclipse.emf.ecore.xmi_2.3.2. v200802051830.jar
b3e85000-b3e8b000 r-xs 0002e000 08:09 605005
/home/screw/eclipse/plugins/org.eclipse.wst.common.emf_1.1.1 04.v200709131115.jar
b3e8b000-b3e8e000 r-xs 00016000 08:09 604895
/home/screw/eclipse/plugins/org.eclipse.jem.util_2.0.2.v2008 02192030.jar
b3e8e000-b3e92000 r-xs 0001a000 08:09 604884
/home/screw/eclipse/plugins/org.eclipse.wst.common.framework s_1.1.103.v200802192030.jar
b3e92000-b3e96000 r-xs 0001e000 08:09 604987
/home/screw/eclipse/plugins/org.eclipse.wst.common.emfworkbe nch.integration_1.1.105.v200802192030.jar
b3e96000-b3e9c000 r-xs 00039000 08:09 604985
/home/screw/eclipse/plugins/org.eclipse.jst.j2ee.webservice_ 1.1.102.v200802192030.jar
b3e9c000-b3ea2000 r-xs 00041000 08:09 605061
/home/screw/eclipse/plugins/org.eclipse.datatools.enablement .sybase.asa_1.0.0.200706071.jar
b3ea2000-b3ea4000 r-xs 0000a000 08:09 604761
/home/screw/eclipse/plugins/org.eclipse.jst.j2ee.webservice. ui_1.1.103.v200802192030.jar
b3ea4000-b3ea7000 r-xs 0000a000 08:09 605785
/home/screw/eclipse/plugins/org.eclipse.jdt.core.manipulatio n_1.1.0.v20070606-0010.jar
b3ea7000-b3eb1000 r-xs 0006a000 08:09 605632
/home/screw/eclipse/plugins/org.eclipse.search_3.3.1.r331_v2 0070831-0800.jar
b3eb1000-b3edb000 r-xs 001e2000 08:09 605287
/home/screw/eclipse/plugins/org.eclipse.debug.ui_3.3.2.v2008 0117_r332.jar
b3edb000-b3ee5000 r-xs 00077000 08:09 605597
/home/screw/eclipse/plugins/org.eclipse.ui.workbench.textedi tor_3.3.2.r332_20080109-0800.jar
b3ee5000-b3eeb000 r-xs 00034000 08:09 605151
/home/screw/eclipse/plugins/org.eclipse.text_3.3.0.v20070606 -0010.jar
b3eeb000-b3ef6000 r-xs 00079000 08:09 605598
/home/screw/eclipse/plugins/org.eclipse.ui.editors_3.3.2.r33 2_20080109-0800.jar
b3ef6000-b3f07000 r-xs 000be000 08:09 605709
/home/screw/eclipse/plugins/org.eclipse.jface.text_3.3.2.r33 2_20071017-0800.jar
b3f07000-b3f0a000 ---p b3f07000 00:00 0
b3f0a000-b3f58000 rwxp b3f0a000 00:00 0
b3f58000-b3f59000 r-xs 0000c000 08:09 605786
/home/screw/eclipse/plugins/org.eclipse.jdt.compiler.tool_1. 0.1.v_793_R33x.jar
b3f59000-b3f5c000 r-xs 00022000 08:09 605775
/home/screw/eclipse/plugins/org.eclipse.jdt.compiler.apt_1.0 .1.R33x_v20071002-2100.jar
b3f5c000-b3f83000 r-xs 003ca000 08:09 605781
/home/screw/eclipse/plugins/org.eclipse.jdt.core_3.3.3.v_793 _R33x.jar
b3f83000-b4009000 r-xs 0083d000 08:09 605774
/home/screw/eclipse/plugins/org.eclipse.jdt.ui_3.3.2.r332_20 080128.jar
b4009000-b4010000 r-xs 00046000 08:09 605700
/home/screw/eclipse/plugins/org.eclipse.ui.navigator_3.3.2.M 20080207-0800.jar
b4010000-b4013000 r-xs 00010000 08:09 605720
/home/screw/eclipse/plugins/org.eclipse.ui.views_3.2.101.M20 080207-0800.jar
b4013000-b4017000 r-xs 00017000 08:09 605702
/home/screw/eclipse/plugins/org.eclipse.ui.navigator.resourc es_3.3.1.M20070831-2000.jar
b4017000-b4021000 r-xp 00000000 08:09 605849
/home/screw/eclipse/configuration/org.eclipse.osgi/bundles/1 88/1/.cp/libswt-cairo-gtk-3349.so
b4021000-b4022000 rwxp 00009000 08:09 605849
b4022000-b4028000 r-xp 00000000 08:09 605848
/home/screw/eclipse/configuration/org.eclipse.osgi/bundles/1 88/1/.cp/libswt-atk-gtk-3349.so
b4028000-b4029000 rwxp 00005000 08:09 605848
b4029000-b4047000 r-xs 003c5000 08:09 605727
/home/screw/eclipse/plugins/com.ibm.icu_3.6.1.v20070906.jar
b4047000-b404c000 r-xs 0003e000 08:09 605044
/home/screw/eclipse/plugins/org.eclipse.emf.codegen_2.3.1.v2 00802051830.jar
b404c000-b4050000 r-xs 0001d000 08:09 605024
/home/screw/eclipse/plugins/org.eclipse.emf.mapping.ui_2.3.0 .v200802051830.jar
b4050000-b4051000 r-xs 00001000 08:09 605034
/home/screw/eclipse/plugins/org.eclipse.emf.mapping.ecore_2. 3.0.v200802051830.jar
b4051000-b4055000 r-xs 0001d000 08:09 605016
/home/screw/eclipse/plugins/org.eclipse.emf.edit.ui_2.3.1.v2 00802051830.jar
b4055000-b4057000 r-xs 00009000 08:09 605773
/home/screw/eclipse/plugins/org.eclipse.jdt_3.3.1.r332_v2008 0131.jar
b4057000-b4059000 r-xs 00002000 08:09 605603
/home/screw/eclipse/plugins/org.eclipse.rcp_3.2.1.r33x_r2008 0131.jar
b4059000-b405c000 r-xs 00017000 08:09 605146
/home/screw/eclipse/plugins/org.eclipse.datatools.sqltools.c ommon.ui_1.0.0.200708161.jar
b405c000-b4060000 r-xs 0002a000 08:09 605125
/home/screw/eclipse/plugins/org.eclipse.datatools.connectivi ty_1.0.1.200802191.jar
b4060000-b4066000 r-xs 0002c000 08:09 605049
/home/screw/eclipse/plugins/org.eclipse.xsd.edit_2.3.0.v2008 02051830.jar
b4066000-b4067000 r-xs 00000000 08:09 605790
/home/screw/eclipse/plugins/org.eclipse.php_1.0.3.v20080603. jar
b4067000-b4078000 r-xs 000a7000 08:09 605055
/home/screw/eclipse/plugins/org.eclipse.gef_3.2.102.v2008011 6.jar
b4078000-b407a000 r-xs 00002000 08:09 605738
/home/screw/eclipse/plugins/org.eclipse.cvs_1.0.2.r33x_r2008 0129.jar
b407a000-b4082000 r-xs 0005c000 08:09 605063
/home/screw/eclipse/plugins/org.eclipse.datatools.modelbase. sql_1.0.0.200708161.jar
b4082000-b4085000 r-xs 00013000 08:09 605141
/home/screw/eclipse/plugins/org.eclipse.datatools.enablement .oda.xml_1.0.3.200802141.jar
b4085000-b4087000 r-xs 00013000 08:09 605051
/home/screw/eclipse/plugins/org.eclipse.xsd.editor_2.3.0.v20 0802051830.jar
b4087000-b408e000 r-xs 000d1000 08:09 605026
/home/screw/eclipse/plugins/org.eclipse.emf.codegen.ecore_2. 3.2.v200802051830.jar
b408e000-b4090000 r-xs 00012000 08:09 605039
/home/screw/eclipse/plugins/org.eclipse.emf.ecore.editor_2.3 .1.v200802051830.jar
b4090000-b4091000 r-xs 00001000 08:09 605047
/home/screw/eclipse/plugins/org.eclipse.xsd.mapping_2.3.0.v2 00802051830.jar
b4091000-b4092000 r-xs 00003000 08:09 604827
/home/screw/eclipse/plugins/org.eclipse.jst_1.0.2.v200706120 315.jar
b4092000-b4093000 r-xs 00001000 08:09 605031
/home/screw/eclipse/plugins/org.eclipse.emf.mapping.ecore.ed itor_2.3.0.v200802051830.jar
b4093000-b4095000 r-xs 00026000 08:09 605012
/home/screw/eclipse/plugins/org.eclipse.emf.ecore.sdo_2.3.0. v200802051830.jar
b4095000-b4098000 r-xs 00017000 08:09 605028
/home/screw/eclipse/plugins/org.eclipse.emf.ecore.edit_2.3.1 .v200802051830.jar
b4098000-b409b000 r-xs 00018000 08:09 605030
/home/screw/eclipse/plugins/org.eclipse.emf.common.ui_2.3.1. v200802051830.jar
b409b000-b409f000 r-xs 00027000 08:09 605018
/home/screw/eclipse/plugins/org.eclipse.emf.common_2.3.2.v20 0802051830.jar
b409f000-b40a0000 r-xs 00001000 08:09 605048
/home/screw/eclipse/plugins/org.eclipse.xsd.mapping.editor_2 .3.0.v200802051830.jar
b40a0000-b40a3000 r-xs 0001d000 08:09 605127
/home/screw/eclipse/plugins/org.eclipse.datatools.connectivi ty.oda.design.ui_3.0.6.200710051.jar
b40a3000-b40a4000 r-xs 00005000 08:09 605015
/home/screw/eclipse/plugins/org.eclipse.emf.ecore.sdo.edit_2 .3.0.v200802051830.jar
b40a4000-b40a7000 r-xs 00018000 08:09 605131
/home/screw/eclipse/plugins/org.eclipse.datatools.enablement .oda.xml.ui_1.0.3.200711191.jar
b40a7000-b40a8000 r-xs 00007000 08:09 605068
/home/screw/eclipse/plugins/org.eclipse.datatools.intro_1.0. 0.200706071.jar
b40a8000-b40a9000 r-xs 00001000 08:09 605050
/home/screw/eclipse/plugins/org.eclipse.xsd.ecore.converter_ 2.3.0.v200802051830.jar
b40a9000-b40ac000 r-xs 00011000 08:09 605032
/home/screw/eclipse/plugins/org.eclipse.emf.converter_2.3.0. v200802051830.jar
b40ac000-b40b0000 r-xs 00026000 08:09 605064
/home/screw/eclipse/plugins/org.eclipse.datatools.enablement .sybase_1.0.1.200707131.jar
b40b0000-b40b5000 r-xs 00034000 08:09 605014
/home/screw/eclipse/plugins/org.eclipse.emf.edit_2.3.2.v2008 02051830.jar
b40b5000-b40b6000 r-xs 00001000 08:09 605042
/home/screw/eclipse/plugins/org.eclipse.emf_2.3.0.v200802051 830.jar
b40b6000-b40bd000 r-xs 000aa000 08:09 605052
/home/screw/eclipse/plugins/org.eclipse.xsd_2.3.2.v200802051 830.jar
b40bd000-b40c0000 r-xs 00014000 08:09 605091
/home/screw/eclipse/plugins/org.eclipse.datatools.connectivi ty.oda_3.1.1.200711081.jar
b40c0000-b40c3000 r-xs 00014000 08:09 605022
/home/screw/eclipse/plugins/org.eclipse.emf.ecore.sdo.editor _2.3.0.v200802051830.jar
b40c3000-b40c4000 r-xs 00003000 08:09 604892
/home/screw/eclipse/plugins/org.eclipse.wst_1.0.2.v200706120 315.jar
b40c4000-b40c5000 r-xs 00006000 08:09 605041
/home/screw/eclipse/plugins/org.eclipse.emf.codegen.ui_2.3.0 .v200802051830.jar
b40c5000-b40d2000 r-xs 000cf000 08:09 605027
/home/screw/eclipse/plugins/org.eclipse.emf.ecore_2.3.2.v200 802051830.jar
b40d2000-b40d6000 r-xs 00026000 08:09 605084
/home/screw/eclipse/plugins/org.eclipse.datatools.doc.user_1 .0.0.200706071.jar
b40d6000-b40d7000 r-xs 00002000 08:09 605058
/home/screw/eclipse/plugins/org.eclipse.datatools.enablement .finfo_1.5.1.200708161.jar
b40d7000-b40da000 r-xs 00019000 08:09 605040
/home/screw/eclipse/plugins/org.eclipse.emf.codegen.ecore.ui _2.3.0.v200802051830.jar
b40da000-b40df000 r-xs 00027000 08:09 605021
/home/screw/eclipse/plugins/org.eclipse.emf.mapping_2.3.0.v2 00802051830.jar
b40df000-b40e2000 ---p b40df000 00:00 0
b40e2000-b4130000 rwxp b40e2000 00:00 0
b4130000-b4135000 r-xs 00029000 08:09 605612
/home/screw/eclipse/plugins/org.eclipse.ui.browser_3.2.100.v 20070524A.jar
b4135000-b413c000 r-xs 00049000 08:09 605725
/home/screw/eclipse/plugins/org.eclipse.ui.cheatsheets_3.3.1 .v20080125_33x.jar
b413c000-b4140000 r-xs 0001f000 08:09 605594
/home/screw/eclipse/plugins/org.eclipse.help_3.3.2.v20071126 _33x.jar
b4140000-b4142000 r-xs 00012000 08:09 605604
/home/screw/eclipse/plugins/org.eclipse.core.expressions_3.3 .0.v20070606-0010.jar
b4142000-b4145000 ---p b4142000 00:00 0
b4145000-b4193000 rwxp b4145000 00:00 0
b4193000-b419a000 r-xs 00036000 08:09 605289
/home/screw/eclipse/plugins/org.eclipse.core.databinding_1.0 .1.M20070822-0800.jar
b419a000-b419e000 r-xs 0001a000 08:09 605605
/home/screw/eclipse/plugins/org.eclipse.jface.databinding_1. 1.1.M20080207-0800.jar
b419e000-b41a1000 ---p b419e000 00:00 0
b41a1000-b41ef000 rwxp b41a1000 00:00 0
b41ef000-b41f2000 r-xs 00012000 08:09 605733
/home/screw/eclipse/plugins/org.eclipse.core.contenttype_3.2 .100.v20070319.jar
b41f2000-b41f5000 r-xs 0001b000 08:09 605633
/home/screw/eclipse/plugins/org.eclipse.core.resources.compa tibility_3.2.100.v20070502.jar
b41f5000-b41ff000 r-xs 0009c000 08:09 605651
/home/screw/eclipse/plugins/org.eclipse.core.resources_3.3.1 .R33x_v20080205.jar
b4202000-b4249000 r-xp 00000000 08:05 15540
/usr/share/fonts/truetype/ttf-dejavu/DejaVuSansMono-Bold.ttf
b4249000-b4257000 r-xs 00656000 08:05 161337
/usr/lib/jvm/java-6-sun-1.6.0.06/jre/lib/charsets.jar
b4257000-b42e0000 r-xp 00000000 08:05 15538
/usr/share/fonts/truetype/ttf-dejavu/DejaVuSans-Bold.ttf
b42e0000-b42fc000 r-xs 0016b000 08:09 605737
/home/screw/eclipse/plugins/org.eclipse.team.cvs.ui_3.3.1.r3 3x_20070807.jar
b42fc000-b42fe000 r-xs 00008000 08:09 604893
/home/screw/eclipse/plugins/org.eclipse.jst.jee.ui_1.0.2.v20 0802192030.jar
b42fe000-b4303000 r-xs 00037000 08:09 604966
/home/screw/eclipse/plugins/org.eclipse.jst.ejb.ui_1.1.102.v 200709122200.jar
b4309000-b4355000 r-xp 00000000 08:05 15539
/usr/share/fonts/truetype/ttf-dejavu/DejaVuSansMono.ttf
b4368000-b4380000 r-xp 00000000 08:05 95026
/usr/share/fonts/X11/misc/10x20.pcf.gz
b4380000-b4383000 r-xp 00000000 08:05 27507
/usr/lib/pango/1.6.0/modules/pango-hebrew-fc.so
b4383000-b4384000 rwxp 00002000 08:05 27507
b4384000-b438c000 r-xp 00000000 08:05 95010
/usr/share/fonts/X11/misc/6x12.pcf.gz
b43d2000-b444f000 r-xp 00000000 08:05 15561
/usr/share/fonts/truetype/ttf-dejavu/DejaVuSans-BoldOblique. ttf
b444f000-b4451000 r-xp 00000000 08:05 27506
/usr/lib/pango/1.6.0/modules/pango-basic-fc.so
b4451000-b4452000 rwxp 00001000 08:05 27506
b4463000-b44e0000 r-xp 00000000 08:05 15562
/usr/share/fonts/truetype/ttf-dejavu/DejaVuSans-Oblique.ttf
b44e7000-b44ed000 r-xs 00000000 08:06 6123
/var/cache/fontconfig/945677eb7aeaf62f1d50efc3fb3ec7d8-x86.c ache-2
b44ed000-b4503000 r-xs 00000000 08:06 6137
/var/cache/fontconfig/cabbd14511b9e8a55e92af97fb3a0461-x86.c ache-2
b4503000-b4516000 r-xs 00000000 08:06 10621
/var/cache/fontconfig/e13b20fdb08344e0e664864cc2ede53d-x86.c ache-2
b4516000-b456a000 r-xs 00000000 08:06 6125
/var/cache/fontconfig/eeebfc908bd29a90773fd860017aada4-x86.c ache-2
b456a000-b45b4000 r-xs 00000000 08:06 6119
/var/cache/fontconfig/21a99156bb11811cef641abeda519a45-x86.c ache-2
b45b4000-b45c2000 r-xs 00000000 08:06 10475
/var/cache/fontconfig/865f88548240fee46819705c6468c165-x86.c ache-2
b45c2000-b4622000 rwxs 00000000 00:08 2719748 /SYSV00000000 (deleted)
b4622000-b4625000 rwxs 00000000 00:08 2686979 /SYSV00000000 (deleted)
b4625000-b4642000 r-xs 0018c000 08:09 605608
/home/screw/eclipse/plugins/org.eclipse.ui.ide_3.3.2.M200802 07-0800.jar
b4642000-b4646000 r-xp 00000000 08:05 21107 /usr/lib/libXtst.so.6.1.0
b4646000-b4647000 rwxp 00003000 08:05 21107 /usr/lib/libXtst.so.6.1.0
b4647000-b464a000 r-xp 00000000 08:05 19565
/usr/lib/libgthread-2.0.so.0.1600.3
b464a000-b464b000 rwxp 00003000 08:05 19565
b464b000-b464c000 r-xs 00003000 08:09 604943
/home/screw/eclipse/plugins/org.eclipse.jpt_1.0.2.v200802140 100.jar
b464c000-b4653000 r-xs 00000000 08:06 6134
/var/cache/fontconfig/6d41288fd70b0be22e8c3a91e032eec0-x86.c ache-2
b4653000-b4654000 r-xs 00000000 08:06 8869
/var/cache/fontconfig/9451a55048e8dbe8633e64d34165fdf2-x86.c ache-2
b4654000-b4655000 r-xs 00000000 08:06 6133
/var/cache/fontconfig/4794a0821666d79190d59a36cb4f44b5-x86.c ache-2
b4655000-b4657000 r-xs 00000000 08:06 10397
/var/cache/fontconfig/de9486f0b47a4d768a594cb4198cb1c6-x86.c ache-2
b4657000-b465c000 r-xs 00000000 08:06 10051
/var/cache/fontconfig/105b9c7e6f0a4f82d8c9b6e39c52c6f9-x86.c ache-2
b465c000-b465e000 rwxp b465c000 00:00 0
b465e000-b46af000 r-xp 00000000 08:09 605838
/home/screw/eclipse/configuration/org.eclipse.osgi/bundles/1 88/1/.cp/libswt-pi-gtk-3349.so
b46af000-b46b1000 rwxp 00050000 08:09 605838
b46b1000-b46b2000 rwxp b46b1000 00:00 0
b46b2000-b46b5000 r-xp 00000000 08:09 605837
/home/screw/eclipse/configuration/org.eclipse.osgi/bundles/1 88/1/.cp/libswt-gtk-3349.so
b46b5000-b46b6000 rwxp 00003000 08:09 605837
b46b6000-b46ba000 r-xs 00016000 08:09 605220
/home/screw/eclipse/plugins/org.eclipse.core.commands_3.3.0. I20070605-0010.jar
b46ba000-b46be000 r-xs 0001f000 08:09 605716
/home/screw/eclipse/plugins/org.eclipse.ui_3.3.1.M20071128-0 800.jar
b46be000-b46d0000 r-xs 001c2000 08:09 605592
/home/screw/eclipse/plugins/org.eclipse.swt.gtk.linux.x86_3. 3.2.v3349.jar
b46d0000-b46d1000 r-xs 00003000 08:09 605634
/home/screw/eclipse/plugins/org.eclipse.swt_3.3.2.v3349d.jar
b46d1000-b46e4000 r-xs 000dc000 08:09 605611
/home/screw/eclipse/plugins/org.eclipse.jface_3.3.2.M2008020 7-0800.jar
b46e4000-b4725000 r-xs 00353000 08:09 605645
/home/screw/eclipse/plugins/org.eclipse.ui.workbench_3.3.2.M 20080207-0800.jar
b4725000-b4727000 r-xs 0000a000 08:09 605713
/home/screw/eclipse/plugins/org.eclipse.ui.ide.application_1 .0.0.I20070530-0100.jar
b4727000-b472a000 r-xs 00014000 08:09 605703
/home/screw/eclipse/plugins/org.eclipse.core.runtime.compati bility_3.1.200.v20070502.jar
b472a000-b472c000 r-xs 00011000 08:09 605591
/home/screw/eclipse/plugins/org.eclipse.equinox.app_1.0.1.R3 3x_v20070828.jar
b472c000-b472e000 r-xs 00012000 08:09 605595
/home/screw/eclipse/plugins/org.eclipse.core.jobs_3.3.1.R33x _v20070709.jar
b472e000-b4731000 r-xs 00017000 08:09 605726
/home/screw/eclipse/plugins/org.eclipse.equinox.preferences_ 3.2.101.R33x_v20080117.jar
b4731000-b4733000 r-xs 00004000 08:09 605652
/home/screw/eclipse/plugins/org.eclipse.core.runtime.compati bility.auth_3.2.100.v20070502.jar
b4733000-b4734000 r-xs 00002000 08:09 605621
/home/screw/eclipse/plugins/org.eclipse.core.runtime.compati bility.registry_3.2.100.v20070316/runtime_registry_compatibi lity.jar
b4734000-b4738000 r-xs 00024000 08:09 605291
/home/screw/eclipse/plugins/org.eclipse.equinox.registry_3.3 .1.R33x_v20070802.jar
b4738000-b473a000 r-xs 00010000 08:09 605596
/home/screw/eclipse/plugins/org.eclipse.core.runtime_3.3.100 .v20070530.jar
b473a000-b473d000 ---p b473a000 00:00
Re: Regular exceptions in Eclipse. [message #260191 is a reply to message #260167] Sun, 06 July 2008 14:39 Go to previous message
Originally posted by: subs._nospam_consertum.com
That points to where the problem is - the PHP plugin.
Suggest you ask on the PHP newgroup.
> because this error. I remover the .metadata dir, and start eclipse. Here
> is the fail log:
> !MESSAGE null
> !STACK 0
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
> at
> at
> at
> at
> at
> at
> at
> at
> in: org.eclipse.php.internal.debug.core.PHPDebugCoreMessages
> Here is VM log.
> linux-x86)
> [id=4169]
> si_addr=0x00000064
> Registers:
> C=native code)
> thread 0x08059000
> daemon [_thread_in_native, id=4249, stack(0xb419e000,0xb41ef000)]
> Other Threads:
> Heap
> 0x4ad00000)
> 0x5c1f0000, 0x900c0000)
> 0x5c1f0000)
> 0x940c0000)
> 0x92d80000)
> 0x948c0000)
> 0x954c0000)
> Dynamic libraries:
Previous Topic:How do I make Eclipse 3.4 stop indenting for me?
Next Topic:Really disable Team/CVS
Current Time: Wed Sep 24 13:59:30 EDT 2025
Powered by FUDForum. Page generated in 0.12052 seconds
