Home » Eclipse Projects » e(fx)clipse » Locale changes at runtime(How to handle labels in Applicatin.e4xmi ?)
Locale changes at runtime [message #1451057] Thu, 23 October 2014 05:09 Go to next message
I'm trying out the method to change language at runtime as described here: http://tomsondev.bestsolution.at/2014/10/13/effeciently-dealing-with-translations-in-an-e4-app-with-the-help-of-java8/.
First of all, it works really great, very nice job !
But I do have one question : can I handle the labels of Application.e4xmi with this method ?
I thought at least the part labels should be manageable with
@Inject MPart part ;
registry.register(part::setLabel, registry::PartNameKey) ;
But this doesn't seem to work. And of course, menus etc. couldn't be done at all like this.
If I use the standard OSGi-resource bundle, I lose the benefit of the at-runtime language change.
Any tips on how to proceed ... ?
Thomas
Re: Locale changes at runtime [message #1451069 is a reply to message #1451057] Thu, 23 October 2014 05:25 Go to previous messageGo to next message
In theory this should work what I don't understand is why you loose
runtime locale change when you use OSGi-Resource Bundle. If you
application model is internalized it should simply work.
If you provide a demo application I can run, I can try to see what's
wrong and what needs to be fixed.
Tom
On 23.10.14 11:09, Thomas Elskens wrote:
> Hello,
> here:
> Thomas
Re: Locale changes at runtime [message #1451142 is a reply to message #1451069] Thu, 23 October 2014 07:50 Go to previous messageGo to next message
I've joined a little demo in attachment : the only things to translate are the name of the pane & the menu items. The resource bundles are found at the default localion, OSGI-INF/I10n/.
I wonder if the problem is not simply the way I try to set the new Locale (code in handlers.SwitchLanguage :
"context.set(TranslationService.LOCALE, param);" works for the translation of source code, perhaps not for the translation of Application.e4xmi ?
I also tried (without succes either) :
  • System.setProperty("osgi.nl", param) ;
  • Locale.setDefault(Locale.forLanguageTag(param));
Re: Locale changes at runtime [message #1451151 is a reply to message #1451142] Thu, 23 October 2014 08:09 Go to previous messageGo to next message
Well to change the locale you need to use the ILocaleChangeService
@Inject
ILocaleChangeService lcs;
lcs.changeApplicationLocale(...)
Tom
Re: Locale changes at runtime [message #1451186 is a reply to message #1451151] Thu, 23 October 2014 09:02 Go to previous messageGo to next message
Much better now, all the menu items are automatically translated, and the part labels in the demo work fine too.
There is, however, one thing that still not works: the part labels in case the parts are shared elements, and are referenced to by placeholders in perspectives. Is this something I should report or is it more likely I'm doing something wrong ... ?
Thomas
Re: Locale changes at runtime [message #1451190 is a reply to message #1451186] Thu, 23 October 2014 09:07 Go to previous messageGo to next message
Yes - sounds like a bug in the renderers.
Tom
> Thomas
Re: Locale changes at runtime [message #1451216 is a reply to message #1451190] Thu, 23 October 2014 09:46 Go to previous messageGo to next message
Done: https://bugs.eclipse.org/bugs/show_bug.cgi?id=448499.
Re: Locale changes at runtime [message #1451217 is a reply to message #1451190] Thu, 23 October 2014 09:47 Go to previous messageGo to next message
Re: Locale changes at runtime [message #1451218 is a reply to message #1451190] Thu, 23 October 2014 09:48 Go to previous message
Done https://bugs.eclipse.org/bugs/show_bug.cgi?id=448499.
Previous Topic:No repository found at http://download.eclipse.org/efxclipse/compiler-released.
Next Topic:Suggestion to modify your releng/pom.xml
Current Time: Wed Nov 05 10:48:54 EST 2025
Powered by FUDForum. Page generated in 0.04587 seconds
