Home » Archived » OHF » Documentation is misleading on audit calls
Documentation is misleading on audit calls [message #25650] Fri, 01 December 2006 17:14 Go to next message
The documentation on
http://wiki.eclipse.org/index.php/OHF_Bridge_Documentation doesn't seem
to match the wsdl and may need to be updated. For example, the
documentation lists auditPatientRecordReadEvent as:
auditPatientRecordReadEvent(int eventOutcome, String initiatingUser,
String patientId)
* eventOutcome event outcome from AtnaAuditClient
* initatingUser User Id passed along to the IHE Actor
* patientId the id of the patient the record pertains to
However, the wsdl appears to want a patient Id object instead of a
string, and a sessionContext instead of a username. Audit also needs to
have its first letter capitalized.
<wsdl:message name="AuditPatientRecordReadEventRequest">
<wsdl:part name="sessionContext" type="tns1:sessionContext"/>
<wsdl:part name="eventOutcome" type="xsd:int"/>
<wsdl:part name="patientId" type="tns1:patientIdType"/>
</wsdl:message>
I assume these are both referring to the same functions for use through
the bridge. I wrote my auditing module based on the documentation page
instead of the wsdl, and needless to say the server wasn't happy with me.
Oops! *slaps head*
-Dan
Re: Documentation is misleading on audit calls [message #25772 is a reply to message #25650] Sat, 02 December 2006 23:37 Go to previous message
Originally posted by: eishays.us.ibm.com
Copy paste is the source of all evil...
Thanks Dan for the comment, and sorry for the misleading extra parameter
in the documentation. I fixed the error.
The error actually came from me copying internal code documentation. The
method signature are identical to the web service, but without the
initiatingUser param which is taken from the SessionContext object.
--eishay
> String patientId)
> </wsdl:message>
> Oops! *slaps head*
> -Dan
Re: Documentation is misleading on audit calls [message #576592 is a reply to message #25650] Sat, 02 December 2006 23:37 Go to previous message
--eishay
> String patientId)
> </wsdl:message>
> Oops! *slaps head*
> -Dan
Previous Topic:Documentation is misleading on audit calls
Next Topic:Next Connectathon : April 15-20th 2007 in Berlin, Germany
Current Time: Sun Nov 09 06:06:06 EST 2025
Powered by FUDForum. Page generated in 0.02708 seconds
