[EMFStore] [ECP] Add user via UI gives exception in 1.4 [message #1449911] |
Tue, 21 October 2014 23:58 |
Pouya Bozorgmehr Messages: 10 Registered: June 2014 |
I upgraded to emfstore and ecp 1.4 and when I try to add user via the Model Repository->Manage Users/Groups I get exception after I click add user.
This worked in 1.2 and it would add New User that I could edit the user name.
Does anyone else see this issue? Any feedback is appreciated.
-Pouya
org.eclipse.emf.emfstore.server.exceptions.ESException: Password is empty.
at org.eclipse.emf.emfstore.internal.client.ui.dialogs.admin.action.CreateUserAction.createOrgUnit(CreateUserAction.java:104)
at org.eclipse.emf.emfstore.internal.client.ui.dialogs.admin.action.CreateOrgUnitAction.run(CreateOrgUnitAction.java:95)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:499)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$6.handleEvent(ActionContributionItem.java:452)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1057)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4170)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3759)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:826)
at org.eclipse.jface.window.Window.open(Window.java:802)
at org.eclipse.emf.emfstore.internal.client.ui.dialogs.admin.ManageOrgUnitsDialog.open(ManageOrgUnitsDialog.java:67)
at org.eclipse.emf.emfstore.internal.client.ui.controller.UIManageOrgUnitsController.doRun(UIManageOrgUnitsController.java:69)
at org.eclipse.emf.emfstore.internal.client.ui.controller.UIManageOrgUnitsController.doRun(UIManageOrgUnitsController.java:1)
at org.eclipse.emf.emfstore.internal.client.ui.common.MonitoredEMFStoreAction$1.run(MonitoredEMFStoreAction.java:70)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372)
at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:507)
at org.eclipse.ui.internal.progress.ProgressMonitorJobsDialog.run(ProgressMonitorJobsDialog.java:275)
at org.eclipse.ui.internal.progress.ProgressManager.run(ProgressManager.java:1162)
at org.eclipse.emf.emfstore.internal.client.ui.common.MonitoredEMFStoreAction.execute(MonitoredEMFStoreAction.java:67)
at org.eclipse.emf.ecp.emfstore.internal.ui.handler.ManageUserGroupHelper.mangeUser(ManageUserGroupHelper.java:40)
at org.eclipse.emf.ecp.emfstore.internal.ui.handler.ManagerUserGroupHandler.execute(ManagerUserGroupHandler.java:35)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:290)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:90)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:243)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:224)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:167)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:499)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:213)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.executeItem(HandledContributionItem.java:850)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.handleWidgetSelection(HandledContributionItem.java:743)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.access$7(HandledContributionItem.java:727)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem$4.handleEvent(HandledContributionItem.java:662)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1113)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:140)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:611)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
[Updated on: Wed, 22 October 2014 19:07] Report message to a moderator
FUDForum. Page generated in 0.02845 seconds
