| [buckminster-dev] CQuery and "svn update" operation [message #25618] |
Tue, 23 September 2008 14:38  |
Originally posted by: Mark.Addleman.ca.com
------_=_NextPart_001_01C91DAB.9F16551A
Content-Type: text/plain;
charset="us-ascii"
Hi, folks -
=20
We're trying to hook up Buckminster to do our headless build. We'd like
Buckminster to control as much of the process as possible including
checking out from Subversion. It appears that Buckminster does a great
job of checking out from Subversion into a clean workspace but it does
not perform the equivalent of an "svn update" if the necessary projects
already exist in the workspace.
=20
>From the documentation, it looks like an MSpec has a conflictResolution
node that will perform an update, but we can't get that to work, either.
=20
Below is our CQuery:
=20
<?xml version=3D"1.0" encoding=3D"UTF-8"?>
<cq:componentQuery
xmlns:cq=3D"http://www.eclipse.org/buckminster/CQuery-1.0"
resourceMap=3D"file:/C:/Documents%20and%20Settings/ADDMA03/Desktop/m365.r=
m
ap">
<cq:rootRequest name=3D"m365.reports" =
componentType=3D"osgi.bundle"/>
</cq:componentQuery>
=20
Here is our RMap:
<rmap
xmlns=3D"http://www.eclipse.org/buckminster/RMap-1.0"
xmlns:xsi=3D"http://www.w3.org/2001/XMLSchema-instance"
xmlns:mp=3D"http://www.eclipse.org/buckminster/MavenProvider-1.0"
xmlns:bc=3D"http://www.eclipse.org/buckminster/Common-1.0">
=20
<searchPath name=3D"m365">
<provider
readerType=3D"svn"
componentTypes=3D"eclipse.feature,osgi.bundle"
source=3D"true" mutable=3D"true">
<uri
format=3D"https://machine/svn/m365subversion/trunk/{0}">
<bc:propertyRef key=3D"buckminster.component" />
</uri>
</provider>
</searchPath>
=20
<locator searchPathRef=3D"m365" pattern=3D"^lib.*" />
<locator searchPathRef=3D"m365" pattern=3D"^m365.*" />
<locator searchPathRef=3D"m365" pattern=3D"^com.*" />
<locator searchPathRef=3D"m365" pattern=3D"^org.apache.commons.dbcp" =
<locator searchPathRef=3D"m365" pattern=3D"^wily.*" />
=20
<redirect
href=3D" http://www.eclipse.org/buckminster/samples/rmaps/dogfood2.rm ap"
pattern=3D".*" />
</rmap>
=20
=20
=20
=20
Content-Type: text/html;
charset="us-ascii"
<html xmlns:v=3D"urn:schemas-microsoft-com:vml" =
xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DGenerator content=3D"Microsoft Word 11 (filtered medium)">
<style>
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{margin:0in;
margin-bottom:.0001pt;
font-size:12.0pt;
font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;}
a:visited, span.MsoHyperlinkFollowed
{color:#606420;
span.EmailStyle17
{mso-style-type:personal-compose;
font-family:Arial;
color:windowtext;}
@page Section1
{size:8.5in 11.0in;
margin:1.0in 1.25in 1.0in 1.25in;}
div.Section1
{page:Section1;}
</style>
<!--[if gte mso 9]><xml>
<o:shapedefaults v:ext=3D"edit" spidmax=3D"1026" />
</xml><![endif]--><!--[if gte mso 9]><xml>
<o:shapelayout v:ext=3D"edit">
<o:idmap v:ext=3D"edit" data=3D"1" />
</o:shapelayout></xml><![endif]-->
</head>
<body lang=3DEN-US link=3Dblue vlink=3D"#606420">
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span =
style=3D'font-size:10.0pt;
font-family:Arial'>Hi, folks –<o:p></o:p></span></font></p>
font-family:Arial'><o:p> </o:p></span></font></p >
font-family:Arial'>We’re trying to hook up Buckminster to do our =
headless
build. We’d like Buckminster to control as much of the =
process as
possible including checking out from Subversion. It appears that
Buckminster does a great job of checking out from Subversion into a =
clean
workspace but it does not perform the equivalent of an “svn =
update”
if the necessary projects already exist in the =
workspace.<o:p></o:p></span></font></p>
font-family:Arial'>From the documentation, it looks like an MSpec has a
conflictResolution node that will perform an update, but we can’t =
get
that to work, either.<o:p></o:p></span></font></p>
font-family:Arial'>Below is our CQuery:<o:p></o:p></span></font></p>
<p class=3DMsoNormal style=3D'margin-left:.5in'><font size=3D2 =
face=3D"Courier New"><span
style=3D'font-size:10.0pt;font-family:"Courier New"'><?xml
version=3D"1.0" =
encoding=3D"UTF-8"?><o:p></o:p></span ></font></p>
style=3D'font-size:10.0pt;font-family:"Courier =
New"'><cq:componentQuery
resourceMap=3D"file:/C:/Documents%20and%20Settings/ ADDMA03/Desktop/m=
365.rmap"><o:p></o:p></span></font></p>
componentType=3D"osgi.bundle"/><o:p ></o:p></span></font></p>=
New"'></cq:componentQuery><o:p></o:p></span ></font></p>
<p class=3DMsoNormal><font size=3D2 face=3D"Courier New"><span =
font-family:"Courier New"'><o:p> </o:p></span></font></p>
font-family:Arial'>Here is our RMap:<o:p></o:p></span></font></p>
version=3D"1.0" =
New"'><rmap<o:p></o:p></span></font></p>
New"'> xmlns=3D"http://www.eclipse.org/buckminster/RMap-1.0&quo=
t;<o:p></o:p></span></font></p>
New"'> xmlns:xsi=3D"http://www.w3.org/2001/XMLSchema-instance&q=
uot;<o:p></o:p></span></font></p>
New"'> xmlns:mp=3D"http://www.eclipse.org/buckminster/MavenProv=
ider-1.0"<o:p></o:p></span></font></p>
New"'> xmlns:bc=3D"http://www.eclipse.org/buckminster/Common-1.=
0"><o:p></o:p></span></font></p>
style=3D'font-size:10.0pt;font-family:"Courier New"'> =
<searchPath
name=3D"m365"><o:p></o:p></span> </font></p>
<provider<o:p></o:p></span></font></p>
New"'>
readerType=3D"svn"<o:p></o:p></span></font ></p>
New"'>
componentTypes=3D"eclipse.feature,osgi.bundle&q uot; <o:p></o:p></span=
></font></p>
New"'>
source=3D"true" =
mutable=3D"true"><o:p></o:p></span ></font></p>
New"'>
<uri<o:p></o:p></span></font></p>
New"'>
format=3D"https://machine/svn/m365subversion/trunk/{0}"><o:p=
New"'>
<bc:propertyRef key=3D"buckminster.component" =
/><o:p></o:p></span></font></p>
New"'>
</uri><o:p></o:p></span></font></p>
</provider><o:p></o:p></span></font></p>
</searchPath><o:p></o:p></span></font></p >
style=3D'font-size:10.0pt;font-family:"Courier New"'> <locator
searchPathRef=3D"m365" pattern=3D"^lib.*" =
style=3D'font-size:10.0pt;font-family:"Courier New"'> <locator =
pattern=3D"^m365.*" /><o:p></o:p></span></font></p>
searchPathRef=3D"m365" pattern=3D"^com.*" =
searchPathRef=3D"m365" =
searchPathRef=3D"m365" pattern=3D"^wily.*" =
<redirect<o:p></o:p></span></font></p>
href=3D" http://www.eclipse.org/buckminster/samples/rmaps/dogfood2.rm =
ap"<o:p></o:p></span></font></p>
pattern=3D".*" /><o:p></o:p></span></font></p>
New"'></rmap><o:p></o:p></span></font></p >
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'><o:p> </o:p></span></fo=
nt></p>
face=3DArial><span
nt></p>
</div>
</body>
</html>
------_=_NextPart_001_01C91DAB.9F16551A--
| Re: [buckminster-dev] CQuery and "svn update" operation [message #25658 is a reply to message #25618] |
Wed, 24 September 2008 06:23   |
Hi Mark,
The MSPEC approach does not work properly at present (see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=192657) but you can still make it happen. If
you define an AdvisorNode in you cquery that covers the components in question and where
you prohibit resolution against the workspace, then SVN check-outs will be made always.
The check-out command will detect the current content and perform an update.
Thomas Hallgren
Addleman, Mark J wrote:
> Hi, folks –
> We’re trying to hook up Buckminster to do our headless build. We’d like
> not perform the equivalent of an “svn update” if the necessary projects
> node that will perform an update, but we can’t get that to work, either.
> <cq:componentQuery
> xmlns:cq="http://www.eclipse.org/buckminster/CQuery-1.0"
> resourceMap=" file:/C:/Documents%20and%20Settings/ADDMA03/Desktop/m365.rma p ">
> <cq:rootRequest name="m365.reports" componentType="osgi.bundle"/>
> Here is our RMap:
> <rmap
> xmlns="http://www.eclipse.org/buckminster/RMap-1.0"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:mp="http://www.eclipse.org/buckminster/MavenProvider-1.0"
> xmlns:bc="http://www.eclipse.org/buckminster/Common-1.0">
> <searchPath name="m365">
> <provider
> readerType="svn"
> componentTypes="eclipse.feature,osgi.bundle"
> source="true" mutable="true">
> <uri
> format="https://machine/svn/m365subversion/trunk/{0}">
> <bc:propertyRef key="buckminster.component" />
> </uri>
> </provider>
> </searchPath>
> <locator searchPathRef="m365" pattern="^lib.*" />
> <locator searchPathRef="m365" pattern="^m365.*" />
> <locator searchPathRef="m365" pattern="^com.*" />
> <locator searchPathRef="m365" pattern="^org.apache.commons.dbcp" />
> <locator searchPathRef="m365" pattern="^wily.*" />
> <redirect
> href=" http://www.eclipse.org/buckminster/samples/rmaps/dogfood2.rm ap"
> pattern=".*" />
> </rmap>
| RE: [buckminster-dev] CQuery and "svn update" operation [message #25690 is a reply to message #25658] |
Wed, 24 September 2008 12:01  |
Thanks, Thomas.
I just want to say that Buckminster has turned our eclipse headless
build from a nightmare to set up to nearly a pleasure. It took us about
two man-weeks to set up the traditional Eclipse headless build. It took
us about one man-day to reach the same state with Buckminster. Thanks!
Keep up the good work.
-----Original Message-----
[mailto:buckminster-dev-bounces@eclipse.org] On Behalf Of Thomas
Hallgren
Sent: Wednesday, September 24, 2008 3:24 AM
To: Buckminster developer discussions
Subject: Re: [buckminster-dev] CQuery and "svn update" operation
Hi Mark,
make it happen. If
question and where
be made always.
update.
Thomas Hallgren
> Hi, folks -
like
great
projects
conflictResolution
either.
> <cq:componentQuery
resourceMap="file:/C:/Documents%20and%20Settings/ADDMA03/Desktop/m365.rm
ap">
> Here is our RMap:
> <rmap
> <provider
> readerType="svn"
> <uri
> </uri>
> </provider>
> </searchPath>
> <redirect
> pattern=".*" />
> </rmap>
_______________________________________________
buckminster-dev mailing list
buckminster-dev@eclipse.org
https://dev.eclipse.org/mailman/listinfo/buckminster-dev
FUDForum. Page generated in 0.03588 seconds
