Home » Eclipse Projects » RCP Testing Tool » New ECL command(creation of new ECL command )
New ECL command [message #1449331] Tue, 21 October 2014 03:37 Go to next message
I am referencing this site https://www.eclipse.org/rcptt/documentation/userguide/ecl/new-command-guide/for new ECL command creation.
I am facing few issues,
1. After I import RCPTT sources plugins from RCPTT Git repository into my eclipse workspace, few errors are there in the follwing plugins,
org.eclipse.rcptt.ecl.parser which says Unsatisfied version constraint org.antlr.runtime[3.2.0,3.3.0]
Also, when we start new eclipse instance with the following plugins installed as mentioned in that guide, what is meant by this line"Connect to the ECL telnet server started in this Eclipse (on the 2323 port by default) using any telnet client"?
◦org.eclipse.rcptt.ecl.example.view
◦org.eclipse.rcptt.ecl.core
◦org.eclipse.rcptt.ecl.parser
◦org.eclipse.rcptt.ecl.shell
◦org.eclipse.rcptt.ecl.telnet.server
◦org.eclipse.rcptt.ecl.telnet.server.ui
◦org.eclipse.rcptt.tesla.jface.fragment
◦org.eclipse.rcptt.tesla.swt.fragment
Re: New ECL command [message #1449376 is a reply to message #1449331] Tue, 21 October 2014 05:03 Go to previous message
Thank you for contacing us!
1. You should install antlr runtime 3.2 version from here.
2. Try to execute cmd command telnet localhost 2323 . Telnet client is available for every platform, you can read about Telnet client for Windows here.
Previous Topic:[TUTO] Super contexts with groups
Next Topic:Unable to assert tree/table structure of nebula nettable in AUT unlike jface tables
Current Time: Sat Sep 20 23:06:41 EDT 2025
Powered by FUDForum. Page generated in 0.05033 seconds
