Using SysML requirements table [message #1446898] |
Fri, 17 October 2014 13:26 |
I try to create a SysML requirements table in Papyrus (version 1.0.0).
I have created the table and added some requirements in my model, but I did not found how I can do certain things :
- Is it possible to sort the table content by column (for example by Id) ?
- On some complex requirements, the 'Text' property is written on several lines. Is it possible to directly edit in the table a multi line text and then to enter carriage return ?
- Is it possible to align the text to the left for some columns ? Currently all the values are centred.
- Is it possible to display in the table a 'tree' of requirements to represent the nested ones ?
Jonathan
ALL4TEC
Re: Using SysML requirements table [message #1446967 is a reply to message #1446945] |
Fri, 17 October 2014 15:25 |
Hi Jonathan,
I confirm you that changing default alignment in table is currently not possible for the users, and this feature is currently not planned for Eclipse Mars, but it would be useful.
Concerning Tree Table, as Camille said, it will be possible on Eclipse Mars, but it will be a new kind of Requirement Table.
I think that current Requirement Tables will not have the possibility to be displayed as Tree.
Vincent Lorenzo
FUDForum. Page generated in 0.02724 seconds
