Eclipse wont start (yet another thread) [message #1444961] |
Tue, 14 October 2014 20:39 |
Michael Conz Messages: 6 Registered: October 2014 |
Junior Member |
Hey everyone,
at first i'll excuse in advance for any bad english because it's not my native language.
But now to my problem:
I need to start in java programming, so I recently installed eclipse succesfully on 2 machines (at work and in a virtual machine).
The last few hours i tryed to install it on my personal computer at home and it's going to drive me nuts :(
After I did, what I did 2 times before (download and unpack eclipse, install java jdk, setup eclipse.ini, start eclipse, be happy) it seems that nothing I'm going to try leads to a starting eclipse.exe
There is no error message, no splash screen, nothing.
If I start the eclipse.exe by double click in explorer, I get an explorer.exe which consumes 25% of my cpu (one core) and nothing changes this until I restart my system. Same thing happens when I try to start eclipse.exe via console (cmd), only difference is a cmd.exe in taskmanager consuming 25% CPU.
My system specs are:
Windows 8.1 x64 (not running any UAC or sth, as user with admin rights)
16GB Ram
Intel i5-3570K
(if u need more details, just tell me)
A few things i tryed:
- complety cleaned my system of all java installations and eclipse to da a "fresh" restart (again) -> nothing
- reset PATH value to default -> nothing (even after another reinstall of java with clean PATH)
- set path to javaw.exe in eclipse.ini (-vm -> next line the path)
- start ecplisec.exe over cmd -> not a single output line displayed in the prompt
- start eclipse.exe with parameters -clean or -cleanPersistedState or even both -> again not a single output line ... just a cmd.exe consuming my CPU until I restart the system
I attached some screenshots of my problem to this post.
I hope anyone here can help me on this.
Greetz Michael
Re: Eclipse wont start (yet another thread) [message #1446929 is a reply to message #1446920] |
Fri, 17 October 2014 14:16 |
Junior Member |
Seems like i'm doing sth. wrong ...
Windows won't accept it with the " ./ "
Just let me check if i got u right -> you want me to go to the path where i unpacked eclipse in command prompt and execute the command you gave me "./eclipse.exe -consoleLog" ... right?
Cause if i enter this i get an cmd error like "command "." is written the wrong way or couldn't be found" (own translation from the german output i get).
[Updated on: Fri, 17 October 2014 14:16] Report message to a moderator
FUDForum. Page generated in 0.10761 seconds
